Is this a decent eq for front stage - Car Audio Classifieds!
Old 09-11-2014, 01:54 PM
maverickdog8's Avatar
0/11 sssss2979
Default Is this a decent eq for front stage
I picked up a Audio control EQT BNIB this morning. Anyway this would be a good eq for a front stage?
I will be running a pair of soundqubed coaxials and a sound digital nano 250.2.
I've never had a eq before so its a new experience for me.
Old 09-12-2014, 12:35 AM
Yeah, those are great EQs. The only problem is that you need two. There's only a mono input/output, so you need one for the left channel and one for the right channel.
Old 09-12-2014, 02:09 AM
0/11 sssss2979
I'm only doing 1 amp for my 2 door speakers so can I just Y split it off?
Old 09-12-2014, 02:35 AM
I guess technically you could, but you would just be playing either the left or right channel through both speakers. You can only connect either the left OR right RCA to the input on that EQ.* If all of your music is recorded in pure mono it wouldn't be a problem, but all music is going to be recorded with some sort of panning or phasic differences to present a soundstage.
*If you do decide to just run mono, make sure you only split a signal using y-adapters. Never try to combine a signal (like combining the L and R channels) with y-adapters.
Old 09-12-2014, 11:51 AM
0/11 sssss2979
I was going to try running why splitters in and out.
Old 09-12-2014, 12:12 PM
It isn't a good idea to sum two channels together (L+R) like that. You'll get an output impedance mismatch from each channel on the headunit which could potentially damage it. Just choose which channel you want to run or build or buy a summing circuit, although I'm not aware of an inexpensive commercial summing box for car audio, only pro audio.
Why Not Wye?
Old 09-12-2014, 02:21 PM
0/11 sssss2979
Okay. I may sell it then.
Old 09-12-2014, 03:16 PM
BigBen's Avatar
0/11 sssss3006
Feedback Score: 24 reviews
I have a dqxs I'm selling. 6 in, 8 out. With dash controller. Mint condition. 350 shipped
Old 09-12-2014, 04:10 PM
0/11 sssss2979
If I do a crossover between the eqt and the speakers would that clear up the impedence issue?
Old 09-12-2014, 04:22 PM
BigBen's Avatar
0/11 sssss3006
It's not the impedance that's the issue. It's a single channel eq. You will lose l/r. Summing them is a bad idea. And once summed you cant break them back apart.
Enough for my front stage bluephigomab General Car Audio Discussion & Questions 10 09-21-2013 10:43 AM
Help with front stage Biggs Sound Quality Area 21 04-19-2013 12:28 PM
well here goes a decent front stage. cav950015s Wanting to Buy (WTB) 19 03-21-2013 04:55 PM
I need some front stage help... grimreper912003 General Car Audio Discussion & Questions 8 12-27-2011 01:36 PM
I need front stage help! got160s? General Car Audio Discussion & Questions 41 04-12-2010 02:10 PM
