sealed or ported - Car Audio Classifieds!
Old 12-28-2014, 08:57 PM
blkmrideon22s's Avatar
0/11 ssssss487
Default sealed or ported
I am going to use 2 sundown audio e8v3 in my car. I was wondering if it would be better for sq to put the sub's in a sealed box instead of a ported box?
1999 mitsubsihi montero sport
1 ct sounds m75.4
2 ct sounds at1400.1
1 ct sounds 6.5 pro audio comp set
Old 12-29-2014, 03:50 PM
0/11 ssssss627
You may need to cut on your EQ to bring down the upper bass to reduce boominess, but I'd go with a ported enclosure tuned to the low 30s. Many people follow a rule of "sealed for SQ, ported to get loud", but you can make a ported enclosure sound very good. You want the deep bass that a pair of 8s in a sealed enclosure may have a hard time reproducing, even with cabin gain.
Old 01-06-2015, 12:43 PM
0/11 ssssss427
What kind of bass are you used to? Sealed might not be enough for you.
Old 01-06-2015, 01:18 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7525
Feedback Score: 22 reviews
sealed or buy some freeair subs for sq
Old 01-06-2015, 01:35 PM
0/11 ssssss542
I used to have 2 e8's in a 40hz tuned t-line, and was very impressed with them. Ran them on Focal FPS mono amp, was extremely clean kick drums, and smooth low end response down to the upper 20hz range. over- excursion killed the surrounds after about 3 years.
Ported 12 vs sealed 18? Fatboy501 General Car Audio Discussion & Questions 10 03-12-2014 07:12 PM
2 12s ported, 2 15s sealed or 1 15 ported? macandcheese General Car Audio Discussion & Questions 25 01-19-2013 09:19 PM
sealed or ported?? bydapoundatl Enclosure Discussion & Design Construction Help 2 01-06-2011 06:00 AM
Sealed or Ported SKDooley General Car Audio Discussion & Questions 3 12-05-2010 08:04 PM
Ported or Sealed??? joebobclark Enclosure Discussion & Design Construction Help 3 06-23-2010 07:29 AM
