Which of the (3) routes is best? - Car Audio Classifieds!
Old 05-14-2015, 06:37 AM
0/11 ssssssss7
Default Which of the (3) routes is best?
so my alpine double din just broke and I have just replaced it with a pioneer. The problem is that it only has one set of rca preouts in the back and I am running two amps, one for subs and one for mids and highs.. As far as sound quality which route is best
A) rca y splitter in the back of the head unit because I already have my rca's ran
B) a line output converter for one of the rca's .... If so should I use it for the mono subwoofer amplifier or should I use it for my mids and highs?
C) or should I just use the preouts on one of my amplifiers, because both of my amps have them? And if so should I hook up the sub amp first and then use its line out preouts to connect to the amp for my mids n highs? Or should I use my mids and highs amp first then line out to the mono amp? E
Either route would work no problem because I have all wires already ran and have some LOC's laying around I can easily hookup... So let me know what you think! Unfortunately when I tried looking it up it seems that every forum about this subject is just one big argument over who is right or wrong over these three routes ha...Thx for reading
Old 06-25-2015, 04:20 AM
0/11 ssssss231
C is what I would do, using the crossovers on the amps. Use the output on the mids and highs amp to the mono amp input.
Pioneer 80PRS,2 sets of Pioneer TS-110 tweeters, Fountek FR89EX 3" midrange, Silver Flute 6.5s, 3HP, 4HP, Zv4s and other stuff.....
Old 06-25-2015, 04:42 AM
I would probably just split the signal from the headunit using Y splitters. You can do that in the back by the amps so you don't have to run another RCA. Signal loss due to the split is negligible; on the order of a couple millivolts.
If you don't want to buy splitters I would do option C which is just as good if the preamp in/out is just a parallel connection.
