sub for .6 cubes - Car Audio Classifieds!
Old 08-21-2018, 08:25 PM
0/11 ssssss200
Default sub for .6 cubes
Ok i am running a SQ set up in a 06 range rover. i needed to keep everything in the stock locations. I only have .6 cubes to run a sub.Yes it is ported. I am currently running a morel ultimo sc 10 and it sound good but just short of great. The sub doesn't have enough air space.
I have about 600 to 800 watts to the sub. So my thoughts are to try ether a Sundown Sa8 or 2 sa-6.5. I think the sa 8 might be a bit too tall to fit. Anyone have any thoughts or other sub ideas? Im mostly looking for smooth low end.
Old 08-22-2019, 09:33 PM
0/11 sssssss15
There are several options for that space. The newer “flat” or thin subwoofers from higher end companies will easily work in that space.
Several standar 10” subs out there also.
ia warden 15 in 5 cubes vs atomic apxx 15 in 8 cubes? snoopysnooper General Car Audio Discussion & Questions 23 06-18-2014 01:02 AM
Best sub for 3.5 cubes jheist1991 General Car Audio Discussion & Questions 30 02-06-2013 09:53 PM
aq 2200d, got around 6 cubes, what sub 98Expo General Car Audio Discussion & Questions 28 09-24-2012 05:14 PM
12'' sub for 2-2.5 cubes @ ~28hz on 2k Bobby32 General Car Audio Discussion & Questions 5 11-28-2010 02:26 PM
15" sub that works in 3 - 3.5 cubes k3n12ock General Car Audio Discussion & Questions 10 07-11-2010 01:03 AM
