CAT5 vs RCA, balanced and unbalanced - Car Audio Classifieds!
Old 05-06-2010, 10:58 PM
RyanD's Avatar
0/11 ssssss138
Default CAT5 vs RCA, balanced and unbalanced
Old but interesting read on CAT5 and RCA.
http://www.installer.com/tech/cat5.html
Common sense is not so common.
Old 05-07-2010, 07:59 AM
Hertz5400LincolnLS's Avatar
0/11 sssss3029
Good read. I wonder if shielded Cat 5e/6/7 would eliminate the little bit of noise they found?
SOLD TO: orangelss, SPY, 98GMC, MLyons-Jr (2x), laserred97gt, kmanian1, sotelomichael, dB-r_Electronics, EpicenterDesigns
BOUGHT FROM: SPY, fasfocus00, bones22, dbdragguy, kmanian1, TeamPSI (2x), 80inches, pioneer~saturn, sotelomichael, vic713, dB-r_Electronics, Lance_aka_64
Originally Posted by 80INCHES
just build the box and sit back and let the bass flex the $hit out of ur ride
Old 05-07-2010, 09:25 AM
nismos14's Avatar
Super Moderators
0/11 ssss18247
Feedback Score: 64 reviews
good stuff there.
My Car, My Ears.
Old 05-07-2010, 11:58 AM
0/11 sssssss56
Sounds like that guy is trying to have the last word outside of a closed forum topic pissing match...
I'm of the opinion (and experience) that if you keep your wires away from the "noise makers" in the car, it doesn't really matter what cables you run. I've used the cheapest RCAs imaginable...to "Zero Noise" by a famous company...to "twisted pairs"...and I now have IXOS cables since they were $6/each, they look cool and have sweet looking ends, and I actually have matching cables
Of course, the simplest test is to run the cable on top of the seats and away from any electronics (ECU, fuel pump, climate control module, antenna lead, etc) and see if it's REALLY the cable picking up the noise.
Old 05-07-2010, 10:43 PM
RyanD's Avatar
0/11 ssssss138
Well, I have a crap load the Cat5e (non-shielded) in the garage so, I'll give it a go.
RCA connectors
http://cgi.ebay.com/2-Pair-Audio-Int...item5ad5456d9a
Anyone know of a cheap flexible shielded conduit to run the Cat5 through?
Old 05-19-2010, 07:18 PM
0/11 ssssss149
It has to do with the way the 4 sets of wires are twisted. each pair is twisted at a different rate. It really is amazing the things you can do with Cat5e. I am cert. installer of "Smart Panels" in new homes, and we use Cat5e for everything. Audio, Video, Network and Voice of course.
The technology is just going to keep getting better with Cat5e.
Old 05-20-2010, 12:03 PM
Man Behind the Curtain
0/11 sssss1699
Some RCA's already use Cat5 in them.
Old 05-20-2010, 12:36 PM
0/11 sssss1258
Money talks and science goes out the window
indeed
Old 05-21-2010, 03:35 AM
ghostmechanic's Avatar
0/11 sssss1193
Feedback Score: 36 reviews
That is a great link! I might have learned something there, I think.
I agree with this but, I don't. I too have used every kind of cable imaginable & I've had mixed results. True staying away from the main noise makers usually helps a bunch, though it's almost impossible to do that the entire length of the cable. Also I've found some car's electrical systems are just way worse than other's no matter what when it comes to producing noise. And if an alternator has various issues like worn out brushes, it'll sometimes produce noise. I just do everything I can to try to eliminate it.
Right now I have a very slight alternator whine that you can only hear when the volume is at zero. I know for sure it's speaker wire going to the door speakers that's causing it because I installed my system in steps over a 3 day period during the week while I drove it to work. The only thing installed were the door speakers & the wire from them to where the crossovers were going under the seats & the noise began then. There were no amps or head unit installed at all.
Also I think a lot of the twisted pair scheme came from most of the guys that do electronics repair & EE's usually twist power wires as a precaution to try to prevent noise. I have a buddy that used to work where I work that is a Ham & also repaired electronics there & he does that out of habit when he's building something for a project.
u need a flux capacitor to do that bro
i swear i thought you guys were serious until i googled flux capacitor
Old 05-21-2010, 05:21 AM
Real Talk
0/11 ssssss291
Couldn't agree with you more. I ran cat5 everywhere in my new home that I could, and I'm happy I did, because my XM receiver would not get signal in the basement, so I made soldered my IR bud and RCAs to the cat5, so its like it never left the equipment room . It helps alot with the home automation system, because I can have IR control of anything in any room.
NICE weiner
I have a mini-weiner
. I'll post pics in a min.
[SOLD] FS - Eclipse CD8053 w/ Balanced Line Adaptor SPY Head Units, Processors & EQs 19 02-21-2010 08:48 AM
WTB: 1500' cat5 RollerDJ Miscellaneous Stuff For Sale 22 08-29-2009 08:30 PM
