Box Design for 2 Sundown SA-15 in a Tahoe - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Vendors > (Sundown Audio)
(Sundown Audio) Sundown Audio's Online Forum
Old 01-14-2012, 03:33 AM
bigdogjk's Avatar
Bigdogjk Designs
0/11 ssssss226
Arrow Box Design for 2 Sundown SA-15 in a Tahoe
This box was design for CarAudioFanatic. If this will work for your build you are welcome to use it. Let me know what you guys think about it.
It's 7.1^ft tune to 30hz (after sub displacement)
Box dimensions are 19 3/4"H x 44"W x 26"D
Port dimensions are 2 1/2"H x 42 1/2"W x 35"L
Port area 15 sq" per ^ft
Cut out specs for the wood.
tops are 44" x 26"
bottom is 44" x 26"
back is 42 1/2" x 17 1/2"
front is 42 1/2" x 15"
sides are 26" x 17 1/2"
bottom port is 42 1/2" x 22"
back port is 42 1/2" x 9"
center box brace is 4" w x 14 1/4" h
bottom port braces are 12" w x 2 1/2" h
back port braces is 4" w x 2 1/2" h (only 1 brace is in the picture, but go ahead and use 2 braces for the back port)
(braces have rounded edges)
rounded corners are 3" x 42 1/2" with 45 degree ends
If you use this design, let me know how it turns out for you.
Bigdogjk Designs
I wish this would fit my car, I'm also going to be using 2 SA-15s. Guess I'll have to design one like this for my car.
Old 01-14-2012, 03:05 PM
Bigbodylexus's Avatar
Saving 2nd Bass
0/11 sssss1253
Not a bad design, I've got way too much space in my Suburban for just 2 though
Currently I have: a 1990 Chevy Suburban with 4 Sundown Audio Zv5 18's, powered by 2 Sundown Audio SCV-7500D's. a Sundown Audio SAX-100.4 powering 4 Neo Pro 6.5's, (1) Sundown Audio SAE-50.4 on 2 ST-1 tweeters.
Trunk rattling is not a sport
Old 01-14-2012, 06:19 PM
bigdogjk's Avatar
Bigdogjk Designs
0/11 ssssss226
Yeah you need at least 4, if I had a Suburban I would go with 12 of them.
Old 01-14-2012, 06:26 PM
Saving 2nd Bass
0/11 sssss1253
Yeah, I'm doing 6 12's
Sent with my 2 thumbs
Old 01-15-2012, 11:52 AM
0/11 sssss1286
no need to post in 2 different sections
Old 05-21-2012, 05:16 AM
0/11 sssss1090
anybody build this? how to the sa 15s like the Port area 15 sq" per ^ft??
doin my research for my ports for 4 15's
Old 12-11-2012, 01:59 AM
Brand New Members
0/11 ssssssss4
I like this desing of box and seen your other post for the 2 SA-8's
Box Design for 2 Sundown SA-8 v.2
Little build for 2 SA-8's
Was wondering if a port desing like this could be done for 2-4 SA-8's? I have a '88 S-10 extended cab and like the looks of this box better, the subs firing up and the port firing forward.
Can ya help me out, I can get measurements of what I have to work with if that helps at all?
Old 10-17-2018, 08:10 PM
0/11 ssssssss5
how could i tweak the port lenth and make this box 32 to 35hz
box design for my 5 sundown audio 8s deepsilencer Enclosure Discussion & Design Construction Help 3 01-01-2011 08:53 PM
4 sa 15 2500w tahoe box design xcaliber (Sundown Audio) 8 11-28-2010 08:14 PM
Box Design for omarquez510/Sundown E8's omarquez510 Box Requests 6 03-14-2009 12:21 AM
Free box design: Sundown e8 Supergumby5000 Enclosure Discussion & Design Construction Help 4 03-10-2009 03:08 AM
