Sundown X and Z v.4 Sound Difference : Visualized - Page 3 - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Vendors > (Sundown Audio)
(Sundown Audio) Sundown Audio's Online Forum
  #21
Old 05-23-2014, 09:10 AM
0/11 ssssss637
Originally Posted by sundownz View Post
The NS v.3 is the successor to the Monster motor.
If I sleeved it out in steel it would get a 300+ BL^2/RE figure; but the inductance is super high that way.
The TEAM motor will get crazy high BL^2/RE with the right coil.
I was asking murphy the other day about motor bl..and he too said its pretty much coil dependant. Are we talking impedance..or coil dimensions. Can you briefly explain to me how and why this takes precedent over the size of the gap..in which I've always thought to be the deciding factor.
Old 05-23-2014, 09:39 AM
sundownz's Avatar
vendor
0/11 ssss11704
BL = Product of B field (magnetic field generated by the motor) and L (number of windings in the gap)
So for a given B field -- say a fixed gap size -- you can cram more wire in there various ways to increase the BL product.
You can also expand the gap and cram in ~2x the windings -- you won't lose half of the B field so you have a net gain in BL by doing so.
The problem with adding more and more wire is two-fold ; inductance and mass. I was able to resolve inductance with a pole sleeve in the NS v.3 with fat coil option but I did lose a good bit of the B field as the sleeve is 1mm thick so the gap expanded alot since the aluminum has no magnetic properties it acts like air to the B field. It still has more BL than a thinner coil.
Mass is unavoidable by adding more wire if you keep length the same. So the fat coil in the NS v.3 motor is still heavy.
Also... if you look simply at BL alone; you can make it higher by going to a higher impedance coil -- smaller wire = more wire in the gap. So the real figure is, of course, BL^2/RE
Here is an example for you :
* BL^2/RE = 495.40
* LE = 6.261 mH
* Xmag = 30.33mm (82% BL)
* 4-Layer Coil x 100mm long with 107.9mm top plate ID
* BL^2/RE = 710.46
* LE = 12.634 mH (this would be a big problem)
* Xmag = 18.54mm (82% BL)
* 8-Layer Coil x 49mm long with 114.0mm top plate ID
Notice how the B field decrease as I widened the gap but there is ALOT more wire in there in the highest concentration area between the top plate and pole.
I avoided extra mass by making the coil half as long; but Le went pretty wild and we lost a ton of linear x-max.
I can largely fix the LE problem with a pole sleeve; but we are still left with a coil 1/2 as long so linear x-max suffers and we lost some of our BL advantage.
- Jacob Fuller
- Owner,
The Following User Says Thank You to sundownz For This Useful Post:
Robertvon (10-30-2015)
  #23
Old 05-23-2014, 10:24 AM
0/11 ssssss637
This is great. What program is this? I can see there is no "one motor do it all" you gain something beneficial..you lose something beneficial! Where's the middle ground
  #24
Old 08-15-2014, 03:21 PM
Julian@MotoCARR's Avatar
0/11 sssssss17
Originally Posted by craiggus365 View Post
More like the sound at a concert with good sound system? More air movement on the lows? I have not been lucky enough to experience...yet
Originally Posted by T3mpest View Post
I tried to pay attention, but I already knew all this and once you mentioned linear BL drivers, I lost concentration
Like these two, some of this explaination(and ones on other forums as well) went right over my head
Other's mention that they sound "different" than traditional drivers. For the potential non Klippel savy users, what is "different" sounding/experience/sensation about them to the ear?
'91 300zx | '04 G35x | '04 GSX-R 600
  #25
Old 02-16-2015, 03:42 PM
sundownz's Avatar
vendor
0/11 ssss11704
I made this thread a sticky for future reference.
- Jacob Fuller
- Owner,
  #26
Old 02-16-2015, 04:23 PM
Austin175's Avatar
0/11 sssss4224
Read all this an now brain hurts an only understand half of this stuff
Ref's- Bass14(smd), ddbump(caco), GearGuy2001(caco),extremechevyman67(caco),pieper88(caco),
southparkgucci(caco),
(caco),
(caco),Mythyone(caco)
Zookporter17(caco), White91Formula(caco),dgaf(caco),Dman3047(caco),
  #27
Old 06-22-2016, 02:00 PM
Bigbodylexus's Avatar
Saving 2nd Bass
0/11 sssss1253
thank God I am in the medical field, that was all french to me, All I got from it was Sundown Audio makes some damn good subs
Currently I have: a 1990 Chevy Suburban with 4 Sundown Audio Zv5 18's, powered by 2 Sundown Audio SCV-7500D's. a Sundown Audio SAX-100.4 powering 4 Neo Pro 6.5's, (1) Sundown Audio SAE-50.4 on 2 ST-1 tweeters.
Trunk rattling is not a sport
  #28
Old 05-18-2017, 11:55 PM
0/11 ssssssss5
for reals.. please explain this shit in plain english.. i'm also in the medical field and dont no wtf all that crap was
  #29
Old 01-21-2018, 01:39 AM
Brand New Members
0/11 ssssssss1
nice!
  #30
Old 03-06-2018, 05:47 PM
Brand New Members
0/11 ssssssss4
*UPDATED 2/21/15*
Furthermore; many folks are putting these drivers in large (over sized) enclosures AND also tuning them LOW (30 Hz and below) -- this creates a bottom-end that is SO strong that the upper-end is much quieter by comparison. The drivers are very neutral in terms of what they do to the input (low distortion design = true to original source) -- so the enclosure is really dictating the response and giving the illusion of a lacking upper-end response.
I prefer a more moderate enclosure size and tuning -- this evens out the response and doesn't create such a massive peak under 30 Hz.
Of course -- this falls on the taste of the listener
So can I assume when you say you prefer a more moderate enclosure size you that these drivers can be put in a smaller than recommended enclosure and perform well?
Sundown/TC Sound killer6 18" Subwoofers 2 06-11-2013 10:45 PM
Sundown rebuilt for sound quality barros57 eBay 0 12-16-2012 11:47 PM
Sound difference between a 12" and a 15"? andes11 General Car Audio Discussion & Questions 11 12-18-2010 12:06 PM
difference between tc sounds lms-r 12 and sound splinter rlp 12 cwruck General Car Audio Discussion & Questions 6 10-02-2010 04:19 PM
sundown amps old vs. new heatsink difference? murkr General Car Audio Discussion & Questions 1 09-26-2010 04:28 PM
