Sundown X and Z v.4 Sound Difference : Visualized - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Vendors > (Sundown Audio)
(Sundown Audio) Sundown Audio's Online Forum
Old 05-21-2014, 09:13 AM
sundownz's Avatar
vendor
0/11 ssss11704
Default Sundown X and Z v.4 Sound Difference : Visualized
I know alot of folks have a hard time understanding my explanation of this all in text format; so lets visualize it based on some Klippel results.
I had the first Z v.4 15" prototype Klippel tested; as explained on the image the production model will test even better since I did a hyper-extended pole compared to the standard height pole extension on the sample but I haven't had a chance to actually re-do the test -- but I have verified in FEA and via doing similar comparisons with Klippel on other drivers with the same changes what the result would be.
The SA-12 is a production unit -- and most people know how an SA-12 sounds; and most people love it. It has what I would consider a good but "standard" suspension.
Notice how dramatic the FS shift is even at 2" p-p travel ? Many people that own an SA tend to push them all the way to 2.25-2.5" or so p-p travel (hard bottom is 2.65" p-p) so there would be even MORE parameter shifting.
Even more stand-out is the QTS shift over stroke since it is caused by both BL and CMS shifts.
Anyone with a box modeling program handy can tell you what THAT much shift in Fs and Qts will do to the response (VAS also shrinks along with CMS).
Now lets move onto the Z v.4
The FS shift at 2" p-p is almost non-existent by comparison. The Klippel tester ran out of steam before pushing the suspension to it's limits. Typically CMS limit is defined as a 50% shift which would be ~0.0875 mm/N on the graph; use your imagination and you can see that is around 4" p-p total travel.
Onto the Qts shift -- still MUCH better than the SA-12; and on production with the BL being more symmetrical thanks to the hyper-extended pole you would see more like a range of 28-35% or so here. The reason for this not being as low as the FS shift is that I am not using a "flat BL" topology. If I were to implement something like XBL^2 this shift could be as low as the FS shift over stroke... and I do plan to offer drivers with our new platform AND flat BL at some point.
So, again, anyone with box modelling software can do the experiment themselves and model up what the driver does with a large amount of parameter shift compared to a lack thereof.
So hopefully that explains what you are hearing when you hear a new platform driver compared to a more traditional suspension driver. It is simply a LACK of distortion; there is nothing actually missing -- the drivers are not "missing the highs" -- they are just flat over stroke; they are only missing the *artificial* upper-bass spike created by traditional suspensions over stroke. In other words... they just aren't adding something that isn't really there.
So the question you have to ask yourself is do you WANT a flat and low distortion response or not ? Be honest. Some people don't like their distortion to be that low... and in general CMS related distortion is 2nd order and sounds relatively pleasing (like tube amps).
That being said... the new "SPL" cones will create a CMS curve that looks more like the SA-12 graphs; they will create the traditional sound with the upper-bass spike. When they are available order your driver accordingly to what you like You can think of the new platform subs with "SPL" cones as a higher displacement version of the Z v.3 woofer -- so if you like those you would like a new platform driver with the "SPL" cone.
*UPDATED 2/21/15*
Furthermore; many folks are putting these drivers in large (over sized) enclosures AND also tuning them LOW (30 Hz and below) -- this creates a bottom-end that is SO strong that the upper-end is much quieter by comparison. The drivers are very neutral in terms of what they do to the input (low distortion design = true to original source) -- so the enclosure is really dictating the response and giving the illusion of a lacking upper-end response.
I prefer a more moderate enclosure size and tuning -- this evens out the response and doesn't create such a massive peak under 30 Hz.
Of course -- this falls on the taste of the listener
- Jacob Fuller
- Owner,
The Following 4 Users Say Thank You to sundownz For This Useful Post:
jones82joshua (05-22-2014), OpenGL (12-19-2018), pickle250 (08-17-2015), SINTORMAN (05-22-2014)
Old 05-21-2014, 10:18 AM
Inferno333's Avatar
0/11 sssss3845
Feedback Score: 44 reviews
Nice explanation Jake.
Old 05-21-2014, 10:28 AM
0/11 ssssss416
I tried to pay attention, but I already knew all this and once you mentioned linear BL drivers, I lost concentration.. Did you just say XBL^2 drivers with Sundown durability and build quality as well as those very linear spiders...
For real tho, how long.. I want one lol.
The Following User Says Thank You to T3mpest For This Useful Post:
So Low (02-28-2015)
Old 05-21-2014, 10:46 AM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
More like the sound at a concert with good sound system? More air movement on the lows? I have not been lucky enough to experience...yet
Old 05-21-2014, 11:04 AM
sundownz's Avatar
vendor
0/11 ssss11704
Honestly I don't have a time frame -- but it is a goal of mine to re-introduce a strong XBL^2 driver to car audio and make it even better than ever by pairing it to our linear suspension platform
- Jacob Fuller
- Owner,
Old 05-21-2014, 11:07 AM
KTMrida4life's Avatar
0/11 sssss2271
Feedback Score: 33 reviews
So Jacob, how does a standard zv3 12 compare with the SA 12 and zv4 15? Is it somewhere between the 2 as far as the fs shifting over stroke or does it shift as far as the SA 12 does?
Also, would zv3s perform well in the same box that SA 12s are doing excellent in? It's Alan Coates old box if that sounds familiar, 8 SA 12s 14.75 cubes tuned to 30. SAs are mounted traditionally, would I want to invert zv3s for max airspace or not necessary?
It's better to keep your mouth shut and give the impression that you're stupid, than to open it, and remove all doubt.
Mistakes are how you learn; try not to learn too much at any one time.
Old 05-21-2014, 11:11 AM
sundownz's Avatar
vendor
0/11 ssss11704
The Z v.3 has a pretty traditional set of curves. It will have a little less Qts shift since linear x-max by BL is higher than the SA and that is a product of CMS and BL shift -- but the FS shift will look about the same.
They are often directly swapped into SA boxes with a good deal of success.
- Jacob Fuller
- Owner,
The Following User Says Thank You to sundownz For This Useful Post:
KTMrida4life (05-21-2014)
Old 05-21-2014, 11:47 AM
andy75's Avatar
0/11 ssssss788
Are the sa8v2's along the same lines as a low distortion driver? I've noticed that mine are really flat up high, or I guess I should say that there is not that upper frequency spike that you speak of.
Old 05-21-2014, 01:28 PM
sundownz's Avatar
vendor
0/11 ssss11704
Yes they are; they have a pretty nice CMS curve as well.
- Jacob Fuller
- Owner,
Old 05-21-2014, 02:09 PM
0/11 ssssss103
This really makes me want a zv 4 now. Very informative.
Sundown/TC Sound killer6 18" Subwoofers 2 06-11-2013 10:45 PM
Sundown rebuilt for sound quality barros57 eBay 0 12-16-2012 11:47 PM
Sound difference between a 12" and a 15"? andes11 General Car Audio Discussion & Questions 11 12-18-2010 12:06 PM
difference between tc sounds lms-r 12 and sound splinter rlp 12 cwruck General Car Audio Discussion & Questions 6 10-02-2010 04:19 PM
sundown amps old vs. new heatsink difference? murkr General Car Audio Discussion & Questions 1 09-26-2010 04:28 PM
