Sub noise - Page 2 - Car Audio Classifieds
Go Back   Car Audio Classifieds > Manufacturers Support Forum > (Sundown Audio)
(Sundown Audio) Sundown Audio's Online Forum
  #11
Old 01-09-2017, 08:54 PM
1/11 ssssss153
Yea didn't see anything in there and I blew it out with an air wand. I shimmed it the same all the way around but could the voice coil wiggle when moving back and fourth ?
No, you're is!
Old 01-09-2017, 08:55 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14112
the free air video sounds like air noise but the in box sounds like a dust cap
  #13
Old 01-09-2017, 09:02 PM
0/11 sssssss46
Well if it was making the noise before recone its gotta be in the frame or motor. Check the mesh vents or could be loose screws from motor to frame. There's usually a plastic spacer washer under the screw, one could be cracked or missing. Good luck.
  #14
Old 01-09-2017, 10:55 PM
1/11 ssssss153
Yea I guess the video doesn't sound the same as in person, i could gob some more glue onto the cap just in case. When I cut everything out I noticed that one of the mesh vents was cut way too long and may have been hitting the spider so I bent them all flat to the surface and glued them down. I thought that's what the noise was when I saw that but it's still doing it. But yea to check those bolts I'd have to rip everything out to get to them lol aaand then another recone
No, you're is!
  #15
Old 01-10-2017, 07:40 AM
0/11 ssssss209
Originally Posted by Boomintahoe View Post
Oh ya now I hear the rattle. I did notice it doesn't make the rattle on low volume tho,...did you?
Check the dustcap?
Bingo! Got an E8v5 for a Surprise and it made the exact same noise. I carefully took the dustcap off, no noise. Glued it back on and made sure all was tight. I was so happy that's all it was, I purchased another in the YS. Now I have both in a sealed box in my A7 off a Crunch Pro @ 2ohms.
I also got a "Surprise" that was a 10" SD2. It was dusty, that's all. Cleaned her up. Now she's in the wife's A6.
Get yours glued down and bang away!
Pioneer 80PRS,2 sets of Pioneer TS-110 tweeters, Fountek FR89EX 3" midrange, Silver Flute 6.5s, 3HP, 4HP, Zv4s and other stuff.....
  #16
Old 01-10-2017, 08:51 PM
1/11 ssssss153
This morning when I got home from work I tried to mess with the dustcap, I couldn't get it off without demolishing it so I went around the edge of it with some super t glue. It's still doing it when I just tested it so ordered a cap from psi n I'll rip that sucker off when the new one gets here I guess.
No, you're is!
  #17
Old 01-11-2017, 08:19 PM
1/11 ssssss153
Couldn't wait anymore so I cut the cap off, the glue was all the way around the inside rim of the cap so I'm thinking it was on tight. I free aired it cap off and it sounded better but in the box it sounded about the same as before . So I took the gasket off,lined the hole with weather stripping and tried again incase it was seal (I know I should have done that with the cap still on lol) but it didn't change anything. Think maybe cuz it's a sealed box it's somehow messing with it?
No, you're is!
  #18
Old 01-12-2017, 02:48 AM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12346
It's not normal for a sub to be making any other noise besides bass.
'97 4 dr. Tahoe
Alpine 9835
Polk Audio MM6501 coming soon...
Soundstream Rubicon 2500.1d, 4.500
Optima battery/KnuKoncepts Kolossus wiring
  #19
Old 01-12-2017, 06:54 AM
1/11 ssssss153
I know that's why I want it to stop lol
No, you're is!
  #20
Old 01-12-2017, 06:57 AM
1/11 ssssss153
Thanks to everyone for your input! This is why I joined the forum
No, you're is!
In order to be able to post messages on the Car Audio Classifieds forums, you must first register.
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
What is this noise?? Snowdrifter (DC) 56 01-04-2012 08:09 PM
What would cause this noise? sqcrewcab (Fix My Speaker) 10 07-24-2011 11:13 PM
Sub noise LivinLoud General Car Audio Discussion & Questions 9 07-09-2011 08:14 PM
Whine noise through speakers and subs have motor noise got160s? General Car Audio Discussion & Questions 7 06-16-2010 07:59 PM
a whine/ screah noise noise from my sub aturcotte127317 General Car Audio Discussion & Questions 27 10-28-2008 07:50 AM
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
