Sub noise - Car Audio Classifieds
Go Back   Car Audio Classifieds > Manufacturers Support Forum > (Sundown Audio)
(Sundown Audio) Sundown Audio's Online Forum
Old 01-09-2017, 07:19 PM
1/11 ssssss113
Default Sub noise
https://m.youtube.com/watch?v=PiRYDO0qWc4
Can anybody tell me what this damn noise is lol? I got this sd3 as a surprise me item and it made noise, I messed with the leads and put some glue on a spot that looked "iffy" on the surround but it never fixed it. So... I got a recone for it, put that in and the noise is still there!!!
No, you're is!
Old 01-09-2017, 07:47 PM
Boomintahoe's Avatar
Hurtin' Feelins' errrday
0/11 ssss12232
It's doin' work....all subs make noise!
'97 4 dr. Tahoe
Alpine 9835
Polk Audio coming soon
Soundstream Rubicon 2500.1d, 4.500
Optima battery/KnuKoncepts Kolossus wiring
Old 01-09-2017, 07:54 PM
1/11 ssssss113
It's barely moving lol, but this is like a rattle-ish noise
No, you're is!
Old 01-09-2017, 07:55 PM
1/11 ssssss113
https://m.youtube.com/watch?feature=...&v=5W4JRK2e90g
No, you're is!
Old 01-09-2017, 07:57 PM
0/11 ssss12232
Oh ya now I hear the rattle. I did notice it doesn't make the rattle on low volume tho,...did you?
Check the dustcap?
'97 4 dr. Tahoe
Alpine 9835
Old 01-09-2017, 08:33 PM
1/11 ssssss113
It doesn't at really low volume and higher notes like 80hz seem fine at when I turn it up. All the lower tones do it bad. the one i used for the vid was 30hz
No, you're is!
Old 01-09-2017, 08:35 PM
1/11 ssssss113
I pushed on the sub a lil bit when it was in the box and I couldn't hear or feel any leaks so Idk if it's the dustcap
No, you're is!
Old 01-09-2017, 09:03 PM
BallzFast's Avatar
Peel & Seal works!
2/11 sssss7026
Feedback Score: 41 reviews
Is the sub sealed to the box? I had a sub that made that same sound and it was from the gasket not sealing correctly. I used some soft foam under the gasket and the noise went away. Perhaps that is your issue as well?
03 santa fe-EA 200amp alt,JVC AVX840, 2 Sundown Audio SA-8 v3 D2 (in a Ric Thornton built birch ported box) wired to 2.1 ohms on a DB Drive A7-2500.1D(set by dd-1)
Originally Posted by tommyk90
Originally Posted by colorblind83
My game is legit,
Originally Posted by graham
Old 01-09-2017, 09:07 PM
1/11 ssssss113
Yea pretty sure it's sealing up,when I pushed on it I got close and I couldn't hear any air moving. It makes noise out of the box too tho
No, you're is!
Old 01-09-2017, 09:44 PM
Jeffhulbert50's Avatar
Authorized Vendor
3/11 ssss14046
did you check the gap before recone to make sure it was clear?
In order to be able to post messages on the Car Audio Classifieds forums, you must first register.
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
What is this noise?? Snowdrifter (DC) 56 01-04-2012 09:09 PM
What would cause this noise? sqcrewcab (Fix My Speaker) 10 07-25-2011 12:13 AM
Sub noise LivinLoud General Car Audio Discussion & Questions 9 07-09-2011 09:14 PM
Whine noise through speakers and subs have motor noise got160s? General Car Audio Discussion & Questions 7 06-16-2010 08:59 PM
a whine/ screah noise noise from my sub aturcotte127317 General Car Audio Discussion & Questions 27 10-28-2008 08:50 AM
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd. Guest
