Sundown SA8 v1.5 enclosure questions. - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Manufacturers Support Forum > (Sundown Audio)
(Sundown Audio) Sundown Audio's Online Forum
Old 02-13-2017, 06:22 PM
1/11 ssssss100
Default Sundown SA8 v1.5 enclosure questions.
Got one of these from the yard sale. I built a box for it that's .75 cubes before sub or port. I used a 3 inch external pvc aero port. It's tuned around 38 now after I made some adjustments. From reading this is on the small side for port area. But according to the calculators if I went with 4 inch I'd be between 25-30 inches long depending on the frequency. Thoughts or opinions? Its in an f350 crew cab , enclosure is behind the center console with the port firing backwards into the back wall of the truck.
Old 02-13-2017, 06:34 PM
0/11 sssssss28
Have you gotten it in the truck? How's it sound?
If you can hear port noise then you could go bigger, these things love to move air
Sent from my XT1585 using Tapatalk
Old 02-13-2017, 06:46 PM
1/11 ssssss100
There is very minimal port noise if I flip up the seat and get near the port. But you cannot hear it otherwise. Do you think it could be louder with more port? Right now it's very smooth and clean sounding , and a fairly flat response . Overall I love the sound. Just curious if anybody thinks there's more to be had output wise.
1/11 ssssss100
It took a lot of experimenting to figure out the best spot within reason in the truck to get the sound where I sit.
Old 02-13-2017, 06:49 PM
0/11 sssssss28
If you're happy with then you can leave it.
The smaller port will help with the box being on the bigger side too.
I haven't experimented much with port size with these, I've always built based off the designs I've done.
Old 02-13-2017, 08:21 PM
1/11 ssssss100
I've done a lot with slot ports and a lot of 8s just never an aero setup.
Old 02-13-2017, 08:29 PM
0/11 sssssss28
All I've ever had in my trunk has been sa-8's. A single v1.5, single v2, and now two v3's.
The last yard sale I was tempted to grab a 10 instead, but its hard when these things just never cease to amaze me.
0/11 sssssss28
What power are you running to it?
Old 02-13-2017, 08:39 PM
1/11 ssssss100
It's on a Rockford fosgate P1000 @ 1 ohm. On a very solid electrical.
Old 02-13-2017, 08:47 PM
0/11 sssssss28
That's quite a bit of power for a 1.5, especially for a box that big.
I believe they were only rated at 400 still.
And the suspension on those is much softer than v2 or v3
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
sa8 questions. box and softparts thericanballer General Car Audio Discussion & Questions 3 09-26-2012 08:05 AM
(4) SA8 Tapped Tline enclosure marcin93 Wiring, Electrical & Other Installation Equipment 1 03-22-2012 08:26 AM
(3) SA8 box - have a few questions k3n12ock Enclosure Discussion & Design Construction Help 1 05-07-2011 12:24 PM
sundown nightshade enclosure questions allout13 Enclosure Discussion & Design Construction Help 7 03-25-2009 04:40 PM
car audio forum, moble audio, car stereo, wholesale car audio, 12 volt, with, amplifier, amp, subwoofer, sound quality, buy car audio, and sell automotive stereo systems for cars Plum is my hero!
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
