Flatline 5k Clamp - Car Audio Classifieds!
Old 10-11-2012, 10:36 AM
0/11 sssssss23
Default Flatline 5k Clamp
This is a test for the new Flatiline 5k amps and the skar 4500
test was done on 18 skar vvx 12's
so test was done at a 1ohm nominal load because we could not get the amps to play 18 subs at .25ohms
both the Skar and the Flatline would go into protect after i would start turning it up
We will do a lot more testing in different setups where we have less subs and can get the rise to stay at around 1 ohm
Skar 4500 Results
Starting at 1ohm rising to 3.8ohms
3696 rms @ 11.8v
149.5 @ 41hz
Flatline 5k Results
Starting at 1ohm rising to 3.8ohms (rise was the same)
3650 rms @ 11.6v (even though it was pulling more voltage it was pulling less amperage)
150.3 @ 41hz (.8db louder)
it sounded less louder though but that because it was cleaner power
The Following 2 Users Say Thank You to BassaholicsAudio For This Useful Post:
Haelmuscle (03-28-2015), rhesketh (12-24-2012)
Old 10-11-2012, 10:47 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Skar 4500 Results
3696 rms @ 11.8v
149.5 @ 41hz
Flatline 5k Results
Voltage drop is directly related to current draw. So the lower the number the more current is being drawn. That or you didn't fully recharge the batteries between tests.
Can you give us so data numbers? ACV,ACA, starting voltage things like that and since you said it was pulling less current I assume you clamped DC amperage as well?
Old 10-11-2012, 10:50 AM
0/11 sssssss23
all test started at 14.0v
we will be testing more ill make sure to write down exact data next time instead of the final result
thanks for the advice
99Bonney's Avatar
0/11 sssss6246
Great power with that rise. What model clamp did you use?
Old 10-11-2012, 10:53 AM
Ja Marcus
0/11 sssss6975
Proto 5k IIRC.
Old 10-11-2012, 10:55 AM
0/11 sssssss23
fluke
and yes amp is a 1 of 1 prototype
Old 10-11-2012, 11:02 AM
regizzle's Avatar
0/11 sssss1427
My baby getting put through her paces
Bassaholics crew:
i made an honest mistake. I apologize.
The Following User Says Thank You to regizzle For This Useful Post:
Old 10-11-2012, 11:04 AM
regizzle's Avatar
0/11 sssss1427
However, was less loud to ear, due to power being cleaner.
Bassaholics crew:
Old 10-11-2012, 01:12 PM
0/11 ssssssss6
Nice ;-)
Old 10-11-2012, 01:13 PM
0/11 ssssssss6
I have 2 subs in a forth and my rise is about the same 3.5 to 4
Flatline Audio FL2 (3k). Clamp and review. TaylorFade Car Audio Product Reviews 37 03-28-2019 01:54 AM
aq1200 clamp? contourbass General Car Audio Discussion & Questions 2 05-09-2012 07:36 PM
anyone clamp a aq 3500d v.1? got160s? General Car Audio Discussion & Questions 3 02-11-2012 06:12 PM
WTB: 2 Arc Audio Flatline baskets 12" O.G. D-Wet Wanting to Buy (WTB) 0 10-03-2010 03:45 PM
Clamp meter TurdFergueson2 General Car Audio Discussion & Questions 2 06-07-2010 01:25 PM
