DATS vs WinISD vs Torres - Car Audio Classifieds!
Old 01-06-2013, 07:36 PM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
Default DATS vs WinISD vs Torres
So I hav a box with 4 15's sitting in my shop, so I decided to hook up the DATS to see what it was tuned to.
That is my impedance sweep. So the box is tuned to roughly 35hz if im reading the graph right.
The I decided to see what WinISD would give me for my graph and tuning of the box.
10.75 cubes net. tuned to 40.2 hz Port mach is .04
Lastly I used torres box tuning calculator.
I got 41.12 hz
conclude what you wish from the above.
all tests were done with nothing obstructing the port in the middle of a workshop, so no outside factors are involved. I will throw it in the hoopty either tonight or in the morning and see what the DATS says about in car response.
In car graph above.
The initial peak is at 22 hz
tuned to 31 hz In the car (low point)
another drop at 49 hz, which is the cars peak, don't know if that plays a roll in it.
Tuning dropped 4 hz in the vehicle itself
If i'm reading the graph wrong please let me know.
The Following User Says Thank You to btsteinb For This Useful Post:
B-Shot (01-06-2013)
Old 01-06-2013, 08:12 PM
davecubs14's Avatar
0/11 sssss1845
Sweet man! I love seeing this side of car audio. Thanks.
2001 2 Door Blazer -
'11, '12, '13, '14 Meca Street 2 AL State Champ
AL Meca Street 2 Record Holder(151.6)
2012 Meca World Finals - Street 2 - 3rd Place(148.7)
2013 Meca World Finals - Street 2 - 2nd Place(151.1)
2014 Meca World Finals - Street 2 - 2nd Place(152.3)
Old 01-06-2013, 10:27 PM
btsteinb's Avatar
0/11 sssss3573
updated with in car results.
Old 01-06-2013, 10:43 PM
xnewbx's Avatar
0/11 ssssss985
So each program came up with different results then?
Old 01-06-2013, 10:45 PM
99Bonney's Avatar
0/11 sssss6246
So which is accurate? Lol
Do you have any bracing? If so it's not accounted for in Torres. Also, why not plug in box dimensions into Torres and not just port?
Old 01-06-2013, 10:50 PM
btsteinb's Avatar
0/11 sssss3573
Yup, Winisd was the closest, torres wasnt very far off. but WinISD is the ACTUAL tested result.
the DATS is what is accurate lol
all bracing is accounted for. Just calculated that into the gross volume.
I have triple thick face and double thick side walls. just measured inside the box while I had the back panel off changing the port.
Old 01-06-2013, 10:55 PM
HACKMUNCH's Avatar
0/11 sssss3892
Sub up port back?
TEAM TSA 2013
FACTORY BACKED
XS POWER - 4XSPOWER.COM
PSI - PSICARAUDIO.COM
Old 01-06-2013, 10:57 PM
btsteinb's Avatar
0/11 sssss3573
Originally Posted by HACKMUNCH View Post
Sub up port back?
yes sir.
Old 01-06-2013, 11:01 PM
HACKMUNCH's Avatar
0/11 sssss3892
Lol seen that graph before. What happening is ur enclosure us using the rear hatch as an extension of the port and effictivly tuning the port lower. Instead of your port firing straight back now it is L shaped with the back hatchb involved
TEAM TSA 2013
FACTORY BACKED
The Following User Says Thank You to HACKMUNCH For This Useful Post:
n8skow (01-07-2013)
skartisu's Avatar
Clearly Louder
0/11 sssss1436
Good to know
Sent from my HTCEVOV4G
~Team Tantric Sounds~
(2) HDD12's
on a SAZ4500
SkyHighCarAudioCable
DATS help me please btsteinb General Car Audio Discussion & Questions 7 12-27-2012 06:15 PM
WT3 DATS users Anton Miller General Car Audio Discussion & Questions 7 08-06-2012 10:44 AM
Dats woofer tester (wt3) jalm919 Wiring, Electrical & Other Installation Equipment 5 08-05-2012 08:00 PM
Dats woofer tester (wt3) jalm919 Wiring, Electrical & Other Installation Equipment 3 07-27-2012 02:35 PM
Torres v/s Bass Box Pro v/s WinISD sbelew Enclosure Discussion & Design Construction Help 0 07-25-2012 11:25 PM
