Pair of SA-12s, common chamber enclosure.
3.5 cubes after all displacements with a single 6" aeroport, ~10.5" long
Getting a rather peaky response out of this enclosure in the back of a 2000 Celica hatchback - I'm looking mostly at the below tuning response which is dropping off fairly quickly and was curious if anyone had any thoughts to share on this...
At first I assumed cancellation issues - and have plotted 2 different response graphs with the enclosure firing forward - and backward to compare the two. There was a noticeable ~0.5 db gain across most of the spectrum - but still the very steep drop off below tuning. If I recall, 12db per octave is the typical roll-off? I didn't test low enough frequencies to actually confirm how much roll off I'm getting - but in a visual graph - it looks crazy steep.
And here's the power plot
National Finals - Oct. 29th & 30th, 2016 in Sedalia, MO
