benefits of running at .5 ohms - Car Audio Classifieds!
Old 06-02-2013, 01:20 AM
CHRISGIBSON333's Avatar
0/11 ssssss332
Default benefits of running at .5 ohms
I am getting some new subs the 2 18in sundown zv3. I have a sundown 3500 amp. My question is can i run that amp at .5 ohms without problems. Also what are the benefits of running at .5 vs 1 ohm? I am debating on what coil config to get thanks guys.
Old 06-02-2013, 01:21 AM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7525
Feedback Score: 22 reviews
no real benifits of .5 IMO Stick to 1 ....
Old 06-02-2013, 01:28 AM
jheist1991's Avatar
0/11 sssss1070
Benefits of .5 ohm: Helps combat impedance rise, which in turn draws more power out of the amp. Yes, you can run the 3500 at .5 if you have sufficient elctrical power.
Downside: seems to be a bit harder on the amp that 1 ohm, uses more power due to decreased efficiency.
Old 06-02-2013, 01:29 AM
Raptor660's Avatar
0/11 sssss5243
Feedback Score: 32 reviews
ull get a little more power out of the amp.. ull see close to rated power at 1ohm when wiring to 1/2 because of rise.. but it is harder on ur electrical obviously
2005 Buick LaCrosse
HU: Alpine INE-S920HD
Old 06-02-2013, 01:52 AM
0/11 sssssss44
I would run at .5 ohm. The amp will never see anything close to 1ohm because of rise. I did an extisive test on this a while back, results are posted on another site. Your amp will be fine. Be sure you have the electrical to back up that amp,be it 1 ohm or .5 ohm.
Old 06-02-2013, 02:01 AM
SoCalBean420's Avatar
время решает все
0/11 sssss7110
Feedback Score: 42 reviews
you won't hear the difference between the two loads. just producing more heat than anything.
The Following User Says Thank You to SoCalBean420 For This Useful Post:
Andrew2944r (06-08-2013)
Old 06-02-2013, 10:26 AM
0/11 ssssss741
but reading around here most amps that people drop do .5 never hardly get warm as long as they have the electrical. but i can see if ur running stock electrical lol but im gonna assume your not.. and ur box rise will spike and subs get warm then should be 1 ohm.. right?... id try 1 ohm and check ur box rise then see if you can go down to .5 efficiently
Old 06-02-2013, 10:52 AM
IS300IAdeathRow's Avatar
0/11 sssss3693
i vote go to .5ohm but only if you have solid electrical. Im actually dropping my saz3500v2 to .5 soon when i get my new sub. But only bc im rising to 2.6-2.8ohms so hopefully my new box and a dual 1ohm coil sub wil help me get some more power out of my amp.
2013 Toyota Highlander
Build to come.....
Old 06-03-2013, 08:26 PM
0/11 ssssss106
you could make to most effecient box possible and run it at 1 ohm. Most of the time you do hear a difference going from 1 ohm to .5 ohms ,at .5 it will most likely will get louder..and at 1 ohm it will sound cleaner and but maybe not as loud...alot of variables come into play as well..its kind of something you need to try in your own set up to know.
Old 06-06-2013, 03:04 PM
crunkjuice1's Avatar
0/11 ssssss809
get a bigger amp to satisfy your needs in its 2ohm rating?
The Following 2 Users Say Thank You to crunkjuice1 For This Useful Post:
d77543020 (01-31-2014), Notorious97200 (10-10-2013)
Who is running his Soundigital under 1 ohms? Werner D. General Car Audio Discussion & Questions 16 02-19-2013 03:32 PM
Running AB 1000.1 at 0.5 ohms? TheJesus General Car Audio Discussion & Questions 10 12-04-2012 09:23 PM
Benefits of synthetic oil crownvicon26's General Automotive Chat 6 05-03-2011 10:08 PM
benefits bottlefed1 Team Teamless 9 06-28-2010 10:39 AM
Team Shok Benefits headshok (Shok Ind) 5 01-20-2010 11:31 AM
