HELP with my amp please - Car Audio Classifieds!
Old 08-03-2013, 01:34 AM
Unleash The Beast
0/11 ssssss245
Default HELP with my amp please
I just installed a new amp 1200 watt RMS I have 0 gauge ran to it and spliced down to 4 gauge to fit the terminals. The ground is on the body of the truck which was sanded with a wire wheel to bare metal. all connections are 100% great.
Now with the RCAs and bass remote disconnected, and subwoofer disconnected I connected my oscilloscope and found that there is a roughly 1000 hz wave (the wave looks terrible) as if there is noise coming from the amp. I am wondering if anyone would know what would cause this to happen.
Check out my ride
Did I help you out?
Don't forget to hit thanks ------->
Old 08-03-2013, 01:46 AM
0/11 sssss8594
Feedback Score: 55 reviews
headunit could be clipping
Enclosures
Old 08-03-2013, 01:47 AM
0/11 sssss8594
wait, I just re-read that...with nothing but the power/ground wire in, your getting a signal on you scope??
Enclosures
Old 08-03-2013, 01:49 AM
Unleash The Beast
0/11 ssssss245
and remote of course to turn it on... Yes :/ I think the amp is partially defective but I want to just make sure this is no possibility power or ground cant somehow transfer a dirty signal even though all my connections are good...
Check out my ride
Did I help you out?
Old 08-03-2013, 02:07 AM
VVVVVVVVVVVVVVVVVVVVVV
0/11 ssssss134
Originally Posted by xstingstreetx View Post
that there is a roughly 1000 Mhz wave (the wave looks terrible) as if there is noise commming from the amp. I am wondering if anyone would know what would cause this to happen.
If you found noise at 1k MHz(1,000,000,000,000 hz?), then it is so far beyond audible that it is not even funny. Audible max is about 20khz(20,000 hz)
If you found noise at 1khz, then yes, you do have an issue.
I seem to remember hearing somewhere that class d interferes with fm radio? It used to be a big problem with the first class d amps from the 90's--think Rockford bd1000 era-- IIRC, but was fixed fairly quickly.
'08 Dodge Dakota Crew Cab
Head:Clarion vz401--Mids: Diamond D9-71 component set--Sub: Team PSI platform 2 18"d4 in 4 cu.ft--Amps: Soundstream REF 4.760, Hifonics BXI2610d @ 2ohms(1700 rms)
refs-CA-F: Spooney, mj-tc, Cleansoundz, rc10mike, kmanian, cozce, Spy, ewoevo, stylez12321, stirfri4202,nihl8ion--SSA: sundownz, [email protected], BKOLFO4 --DIYMA: lashlee, nigel1977, Ibizonacid--Here: snyderd758
Old 08-03-2013, 02:14 AM
Unleash The Beast
0/11 ssssss245
It was showing 1000 hz which was steady. I see this as a problem because i cant scope my gains and low pass filters and such. Im sure this is a problem but not sure how to fix it. Wouldn't the antenna be irrelevant since i don't have in the RCAs?
Check out my ride
Did I help you out?
Old 08-03-2013, 02:19 AM
0/11 ssssss134
I was simply trying to find out what freq you actually meant, as there is a huge difference between MHz and KHz.
With that out of the way, how strong is the wave?
Old 08-03-2013, 02:20 AM
0/11 ssssss134
Also, you will never hear 1khz noise on a sub amp, as your xover will likely be cut at 80 hz or less, so you may be fretting over nothing anyway.
Old 08-03-2013, 02:26 AM
Unleash The Beast
0/11 ssssss245
I have never seen an amp do this, I am not able to set my gain/LPF etc due to this noise or whatever it is that is coming though. My scope showed 1000 hz so it would be a kilo hert I believe. I know something is not right here.
Check out my ride
Did I help you out?
Old 08-03-2013, 02:29 AM
0/11 ssssss134
Simply turn on your low pass xover and set it to 80 hz, if noise disappears, it's on the input side, if not it's on the output side. That will go a long way to diagnosing what is wrong
WTB/WTT RE XXX 12" & AMP & enclosure TRADE JL 900/5 laneo Wanting to Buy (WTB) 4 11-24-2012 08:31 AM
WHICH IS BETTER? 4 ch amp @ varying ohm loads per channel OR 4 ch amp AND 2ch amp XORstatus General Car Audio Discussion & Questions 5 05-06-2012 09:51 PM
WTB: Wire & accessories for my amp, subs, & big 3 setup fordking Wanting to Buy (WTB) 7 09-11-2011 06:27 PM
WTB HIFONICS, or US amp , or arc audio amp and o gauge amp kit Jesus805 Wanting to Buy (WTB) 12 07-29-2011 03:43 PM
RF HX2 12's & Kicker Amp - Looking For Wiring & Battery extreme Car Audio Trader (WTT) 2 09-24-2010 10:00 PM
