My test: Jensen Power 2000.1d - Car Audio Classifieds!
Old 08-26-2013, 07:57 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Default My test: Jensen Power 2000.1d
Ok, I know you guys are going to think I've lost it testing a Jensen, but bear with me here...
I started thinking about the shittiest amps out there. Pyle, Boss, Pyramid, Jensen... I looked at all of them and honestly, I can't believe how many amps these companies make. They were all GROSSLY overrated and cheap looking and nothing really piqued my interest to waste money on. Then I figured I'd see what Jensen had been up to. I came across these "POWER" series and a couple things caught my eye. The first was adequate onboard fusing according to rating and the second was this certificate/birthsheet thing...
Now, the amp I got didn't come with one and that certificate is from their 4 channel, but at least it's SOMEthing. There's obviously some sort of quality control going on over there. And that's a good thing. It's kinda fishy that it made *exactly* rated power on all 4 channels, but I figure they just put the rated number if it passes, so whatev.
Anyway... I searched around for the best price on the mono. They only make one in the "power" series. It's called the "2000.1d" but you know how that goes. It's a 1k and it's not the first time I've seen an amp advertised by "max" power. AudioSavings has 'B' stock ones for $105 shipped. Sure... why not.
It's actually a decent looking amp. I usually don't care for "shiny" anything, but the gloss finish is pretty sharp. I didn't investigate the sink material, but it's a little beefier than other budget 1k's I've handled. It weighs in at a tick over 6lbs.
4awg power and ground. 8awg speaker terminals and (4) of them. And by golly... look at that. 105A worth of fusing on a 1k. Now, that doesn't mean a whole lot on it's own, but it's a start.
Input side is... whatever. The usual suspects here. Cheaper plastic pot adjustment. Can't ask for a whole lot at this price point, I guess. It comes with a bass remote that's a 3.5mm jack. More on the bass knob later.
Here be de' guts. As usual... I'll let you guys play amp expert here.
On to the testing...
Setting it up unloaded. Hold the eff up... 51v? That can not be right. Anybody know how to tell if an amp is full bridge? Because that's a lot of voltage. I'm told the little black box in the lower left hand corner of the guts is a switching transistor. So... half bridge. Sheesh. That's a lot of ACV for a half bridge 1k. Well... whatever.
I only had 1 ohm nominal available today. I fully intend on beating it up later.
Here we have 457w rising to 3.6ohms at 13.2v. Staying pretty clean here.
Getting rise down we get... 789w rising to 2.3ohms at 13.3v. This is where, unfortunately, we pick up a little distortion.
So, rated and apparent power.
Rated power ---- Apparent -
- 450w @ 4 ohms --- 457w @ 3.6 ohms
- 725W @ 2 ohms ---- 789w @ 2.3 ohms
Observed efficency rising to 2.3 ohms - 73%.
Little guy is getting pretty damn close. Now, let's talk about the wave in the last pic. I am going to do something I never do- and that's to cut an amp a little slack. I'll grant you that it's not the prettiest wave in the world. But first... the amp is rated at 2% THD. And second... it's not so much clipped as it is... distorted. I dare say you'd need at least 5-6% THD to even be audible. Especially on the sub stage.
Since I know this little amp at this price is going to be compared to the AP/VVME stuff, I'll go ahead and do it for you.
Here's a side by side of the guts for your convenience.
Here's a side by side of similar apparent power clamps. Both doing ~ 780w. The VVME needing 1 ohm reactive to get there (but at 12v) and the Jensen doing it at 2.3 reactive (13.2v). What you'll notice here is the wave between the two. One is "clipped" and one is distorted. One is going above and beyond it's capabilites and the other is kinda... noisy.
I'll leave my personal opinion out of it and let y'all draw your own conclusions.
So, one little footnote about the bass knob before I'm done here. The knob itself is actually pretty nice. It reminds me of a more expensive amp's knob in its heft and action.
Buuuuuuut.... this thing is garbage. And I mean hot garbage. First of all, most knobs will basically shut the sub completely off at "min". Not this one. It may have attenuated it about half. And second (and more importantly), it distorted and clipped the ever loving hell out of the signal at anything over 1/4 knob. Most knobs will *only* go to where the gain is set. I have a feeling this knob is more like a bass boost. Moral of the story... don't use bass knobs. Especially this one. Geez.
Ok, I'm out.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 08-26-2013, 08:05 PM
0/11 sssss1027
You should test the ssl f2600d it's like 98 bucks or so maybe less try that one out.
Old 08-26-2013, 08:23 PM
FLAstrongman's Avatar
0/11 sssss1156
Feedback Score: 21 reviews
Did you ever mess with the Jensen ATS line that was around about 12-13 years ago?
It was pretty damn nice.
Custom box builds for FL:
Refs: diyma-sold to:Mazda3SQ CA.com-traded:matrxx dude CACO- Sold to: Ajax_6154, brandonb1029, TeejayBee, xx-wade-xx, traded with: papito FLSPL- Bought from:98chevySPL, JBLCAMRY, traded with:97montecarlo, thumpenranger
Old 08-26-2013, 08:37 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
bottom left black box is a relay...most switching trans. Look like mini fets
Old 08-26-2013, 08:45 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
I'll put it on the list.
That's what Murph told me when I told him I was getting this amp. I may have to track one of those down and check it out.
They have a class D 5 channel in this lineup. I was thinkin about it. Lol. Not really enough power on the sub channel to do much with though. The class A/B 4 channel (that looks just like this one) is tempting for the 50-60 bucks they want for it.
Okie dokie.
4x world champ
- Floyd E. Toole
Old 08-26-2013, 09:00 PM
Authorized Vendor
0/11 ssss14115
Okie dokie.
For clarification, it was in a helpful fun fact format, not a pretentious prick angle
Old 08-26-2013, 09:04 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Lmao.
Still doesn't answer the full bridge question!
It's got me very curious because 1). I can't tell just by looking at guts if an amp if half or full. And 2). That fuzzy wave is pretty common on Brazilian full bridge amps.
4x world champ
- Floyd E. Toole
Old 08-26-2013, 09:22 PM
Authorized Vendor
0/11 ssss14115
Lmao.
Page 7 may help
Jensen Power 760 4ch andrewtexas123 Multi-channel Amplifiers 6 07-02-2012 12:16 PM
Jensen HD Radio Module and Jensen Media Link! vitveet Head Units, Processors & EQs 4 07-31-2011 11:44 PM
Who thought a jensen 400 watt amp couldnt do its power? mattintc10 General Car Audio Discussion & Questions 40 09-04-2010 03:12 PM
Power test videos muriloalvares General Car Audio Discussion & Questions 20 02-15-2010 06:12 PM
Autosound 2000 Test CD mennitti Wanting to Buy (WTB) 4 08-22-2009 09:46 PM
