Changing the way I test amps. And why "clamping" is flawed. - Car Audio Classifieds!
Old 08-27-2013, 09:33 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Default Changing the way I test amps. And why "clamping" is flawed.
In the ongoing effort to provide ever increasing accuracy and legitimacy of my test results, there were two rather exciting additions to my test "bench" today.
The first isn't a big deal to you, but it's a "must have" for me in the DC voltage drop battle since I've been using a cheapo batt charger for power. Caps are fine for short bursts, but even a rather healthy number of banks starts to drop pretty low on sustained testing. And it takes my little charger forever to keep up. So... a 100A / 13.8v power supply gets to handle voltage duty now. I hope to add more powa, but holy hell these things are pricey.
This thing is my new best friend.
Second, and more importantly... I got a bank of fixed resistance. What you see here is 5,000w worth of fixed resistors with different ohm loads available depending on how I configure them.
What's the big deal, you say? Well... I'll tell you. One really awesome thing about these is that I don't have to tear up subs to test amps. Or wake the dead while doing it. But that's just a bonus.
The other thing that's cool here is the "fixed" part. As in, a purely resistive load as opposed to an inductive load (like subs). If I configure these to a 1 ohm load... that's what I get. 1 ohm. No "rise."
Now we will science...
When we measure the current and voltage on an inductive load like subs, the current and voltage are out of phase. It's just the nature of the beast. Basically what that means is that we are measuring them at different times. The further they are out of phase, the larger the difference between the "real" power and the "apparent" power.
Real power, apparent power and power factor are sort of a difficult concpet to grasp, so if you need to Google, I'll wait...
Here's a pic to illustrate what I mean. Even though the peaks are the same here... you can see the difference in the phase. Known as the "phasor angle." And actually... if you can measure or know this angle, you can calculate the real power. Fwiw, these look to be ~ 50* out of phase.
If you measured these two, you'd wind up with a false high reading of about 36%. This is why we see 1k's doing 1.5k "apparent" power.
Here's another pic. You can see in the first one that even though the current and voltage have different peaks, they're in phase. These are the same two measurements except that one is a purely resistive load and the other is an inductive load. These happen to be 90* out of phase. It's just for illustrative purposes since all this would probably do is generate heat. Lol.
Aaaaaaanyway. This all means that all of our clamps on subs are false high readings. How false? That's difficult to say for your clamps, but I can show you on an amp I tested today.
The amp in question is irrelevant, but it was setup exactly the same in both tests. The only major difference is that one test is on a sub and the other is on the resistors. The difference between the "rise" and the resistance here is pretty negligible. As is the .3 dcv difference.
Here we have the inductive test. As in... clamped on a sub. The result I got here is 789w rising to 2.3 ohms.
Now, here's the exact same amp and the exact same settings- except on the resistors wired to 2.5 ohms. Result... 542w @ 2.7 ohms. (note: the "rise" from 2.5 to 2.7 is due to the inaccuracy of this type of current clamp.)
Holy hell I can get long winded.
So, this amp is doing 789w "apparent" power, but it's really only doing 542w "real" power. You guys following me here?
This is the concept behind the AD-1 amp dyno. And why they are all high and mighty about it being the only "real" results and being superior to "clamping" blah blah blah. And technically... they're right. BUT.... since clamping on subs is the end user industry standard across the board, I will continue to include apparent power clamps in my results. Only now, I have another data point to include in my testing.
tl;dr. I haz meters and stuff. Suck it.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
The Following 16 Users Say Thank You to TaylorFade For This Useful Post:
666WMD (08-27-2013), Aero_d2 (08-27-2013), AlwaysLearning (08-28-2013), AudiophilesEngineering (11-15-2013), blackfive (01-31-2015), BlackWaterOp (11-03-2013), brandon_s0854 (09-05-2013), CLRagland1 (11-30-2013), dirt101 (08-27-2013), iamsonic (08-27-2013), jheist1991 (08-27-2013), kn0wledge000 (01-21-2014), momofx (09-17-2013), naughtyca (08-28-2013), nkrell11 (09-05-2013), TeamPSI (09-09-2013)
Old 08-27-2013, 09:40 PM
I always wondered why people now days use subs instead of resistors to test amps. Back in the 90's it was the other way around.
Old 08-27-2013, 09:41 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
I likes the load bank... would clamping follow more along dynamic power ranges and fixed load be more "tru" continuous rms
Old 08-27-2013, 09:43 PM
dirt101's Avatar
0/11 ssssss956
Love it, what will be the power "cap" with this setup?
Old 08-27-2013, 09:44 PM
Turn it up's Avatar
0/11 sssss1933
Good stuff!
HiloDB1's Avatar
0/11 sssss3158
This is also how most amp manufacturers produce those nice birth sheets you get with your amp. They use a fixed resistance instead of a reactive load.
Old 08-27-2013, 09:46 PM
goatskindreams's Avatar
Do you even demo?
0/11 sssss1797
Power supplys are a big investment. Cb radio base stations are just as addictive as car audio. People spend stupid money on there set-ups
Old 08-27-2013, 09:48 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
I suppose we can look at it that way. but I hesitate to use that terminology. "Max" or "Dynamic" power when including it. I'll come up with something more generic for those who didn't happen to read this.
Well... the bank is rated for 5k continuous, but I'm curious to see if they can handle more in bursts.
And they have much, much, much more expensive "meters" than I do. Lol.
I'm working on it!!
4x world champ
- Floyd E. Toole
Old 08-27-2013, 09:49 PM
0/11 sssss2429
Feedback Score: 46 reviews
Will be some sad people when they find out actual power of their amp is low! lol
Sent from my DROID RAZR using Tapatalk 4
The Following User Says Thank You to brandes.cm For This Useful Post:
Old 08-27-2013, 09:51 PM
djscrubb's Avatar
Captain $hit disturber
0/11 sssss2332
nice man!!!!
clamping strapped amps? jdmferio13 General Car Audio Discussion & Questions 7 07-25-2013 07:12 AM
Nightshade v.3 15" Free Air Test -- Formerly "Monster v.2 Prototype" sundownz (Sundown Audio) 100 02-16-2013 04:01 AM
Clamping strapped Amps Staralpha1 General Car Audio Discussion & Questions 1 10-09-2010 10:47 PM
changing amps nuboot Team Teamless 9 06-02-2010 03:18 AM
Thinking about changing amps? teamsubgopoof General Car Audio Discussion & Questions 4 02-07-2009 07:12 PM
