Crossover questions - Car Audio Classifieds!
Old 09-26-2013, 11:55 AM
fireitup's Avatar
0/11 ssssss616
Feedback Score: 31 reviews
Default Crossover questions
Ok i know if i wire 8 ohm speakers to a 4 ohm xover the freqs change. My question is if i wire 8 ohm speakers to a 4 ohm xover what ohm load does my amp see?
Old 09-26-2013, 12:18 PM
SUPER FAST SHIPPING
0/11 ssss31247
the amp sees the load which is on the other end. if it's 8 ohm, it's 8ohm.
12 & 18 dB/octave crossovers get all sorts of out of whack if you use the wrong impedance speaker.
6dB/octave crossovers just operate at a different frequency.
but.. if you have a 12db/octave 5000hz tweeter crossover designed for 4ohm, you can remove the low frequency bypass coil and you'll have a 8ohm 6 dB / octave 3500hz tweeter crossover.
questions about ft-1 crossover fyerbyrd22 (Crescendo) 3 04-30-2013 02:18 PM
Tweeter crossover questions? j5quar3d General Car Audio Discussion & Questions 2 07-24-2012 03:33 PM
crossover and eq questions ja0879 General Car Audio Discussion & Questions 5 05-26-2010 03:00 PM
Using +3db on crossover, few questions.. jbizzle General Car Audio Discussion & Questions 6 03-22-2009 06:58 PM
Crossover Lesson (is your passive crossover labeled correctly?) iamsonic Tutorials & Quick References 0 01-20-2009 08:05 PM
