My test: 6-7k roundup. - Car Audio Classifieds!
Old 11-22-2013, 05:12 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Default My test: 6-7k roundup.
Let's get it on...
First, I want to give a big shout out to Ryan V. (Stovebolt) for his help with the testing. This shit would have taken me a whole weekend without his help. But we knocked it out in one day. Also like to thank him for the use of his truck as the testing grounds.
Disclaimer: Your mileage may vary! This is our test. You may have tested one of these amps and gotten more or less. And as a matter of fact, Ryan's truck is a bit of an enigma because I know a couple of these amps very well and I've gotten better results in my car than we saw in this test. Apparently, his truck is where clamps go to die. BUT... all these amps were given a fair shake and all of the testing and methodology was very consistent.
Speaking of methodology... we set the amps at max clean voltage unloaded with all filters wide open. For the load testing, if the wave was a bit dirty under load, we gave them each a chance to clean it up with a click or two down without handicapping output too much. So, some of the waves will be a bit of a soft clip. If they were still clean, we gave them a click or two up to give them a chance to make as much as they could while staying clean. But trying to stay as "everyday" as we could, we didn't fiddle with them all day. If they stayed dirty under load, them that's their problem.
This is a bit of a break from my normal testing, but I don't show DC voltage in any of the tests. But trust me... voltage drop is of very little concern here. Ryan has his electrical on lockdown. The important part is that all testing was at the same STARTING voltage. It's safe to assume that all of these results are near 14v. Why is that safe to assume? Because caps.
After setting unloaded, we went straight to 1 ohm resistive. Remember, resistive testing has no "rise" and the voltage and current are in phase. This test is similar to the AD-1 amp dyno except that we're showing you the wave and we can take liberty with the distortion or clip (if present). Since there is no rise, voltage = current in a 1 ohm test. That's why there is only voltage shown in the pics. There is no "clamp". Voltage squared is our result. The only break from this is the Crown since it's not a 1 ohm amp.
In between the resistive tests, the resistors were given a chance to cool. Lol.
With the resistors chillin (literally), we moved to the traditional clamping and TermLab result. Nominal load here is .25 (except the Crown) on a pair of Tantric HDD15's in a box that was built for Ryan's truck. Since the cargo area of Ryan's truck was our test bench, we ran leads to the CRX. All numbers are in the kick. The mic, box, seats, etc. all stayed in the same spot the whole time- which is actually difficult to accomplish if we had to shuffle amps in and out of the same vehicle. The same note was played each time.
Okie dokie. On to the testing. These will be in no particular order...
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
spl_robb (11-22-2013)
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Digital Designs M4a
Rated - 5,200w @ 12v. 7,000w @ 14v
Price - $1,550 (dealer quote).
98acv unloaded.
1 ohm resistive. 6,000w. 71% efficient.
Clamp on subs. 6,490w rising to .9ohm. Note: I accidentally had the scope on "hold" in this pic. But you can see from above that it stayed clean under load. No worries here.
Score.
4x world champ
- Floyd E. Toole
The Following 2 Users Say Thank You to TaylorFade For This Useful Post:
Ali888 (11-23-2013), blockburner (11-25-2013)
Old 11-22-2013, 05:13 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
CT Sounds 7000.1d
Rated - 7,000w @ 12.8v
Price - $1,399
87acv unloaded.
1 ohm resistive. 7,000w. 71% efficient. This particular test was done earlier in the day. The battery on the Nano died so we switched to the Velleman. Everything else was the same. I swear. This was also the point at which I decided I needed the little tape name tags since the pics were piling up.
Clamp on subs. 7,930w rising to .8. You can see she got a little clippy here for some reason. The CT didn't like the subs much. Odd. Two clicks down got us a similar wave but only 6,900w. We decided to leave it where it was clean on the resistive test since that's the more accurate one. So, this result is the same settings as above.
Score from the same settings as resistive.
4x world champ
- Floyd E. Toole
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Popcorn Sounds 6k
Rated - 6,000w at 1
Price - Cheap. I don't know.
Unloaded. Now, this might seem impressive, but this is just a snapshot of voltage going ape shit. It was jumping between 70v and 200v and all points in between and I could NOT get a wave worth looking at from it. So... I don't know WTF to do with this thing.
1 ohm resistive. 5,100w. 60% efficient. And umm... one billion percent THD.
Clamp on subs. 5,700w rising to .9.
Score.
4x world champ
- Floyd E. Toole
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
American Bass 750.1
Rated - 7,673w @ 1
Price - $1500-1600 (dealer quotes)
Unloaded. 94acv.
1 ohm resistive. 6,200w. 72% efficient. Little clip.
Clamp on subs. 7,100w rising to .8. Little mo' clip. Not too bad.
Score.
4x world champ
- Floyd E. Toole
CortezDTV (11-22-2013)
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
JBL Crown 6000GTi
Rated - 1 x 8110W @ 4 ohms. 1 x 7400W @ 1 ohm
Price - (Discontinued) - $1,500+ used.
Holy hell. Got voltage? 235v. Jeebus.
5 ohm resistive. I know it's "rated" for 1 ohm, but it's Ryan's amp and he says it makes more power up here. So, 5 ohms it is. 5,200w at 5 ohms. 62% efficient.
Clamp on subs. We rewired the subs to a 4 ohm nominal. I have to show this because it's some seriously sexy shit.
3,200w rising to 12.5ohms
Since we were getting 3x rise, we decided to rewire to 1 ohm nominal.
6,400w rising to 3 ohms. Trust me... it's clean.
A/B powa!!!
4x world champ
- Floyd E. Toole
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Sundown Audio NS-1
Rated - 6,500w @ 1
Price - $1,799 (Amazon)
*Please note that this test was done fairly and accurately to my satisfaction, but was, in fact, not done by me. BUT... it was done concurrently with the CT at a later date than the rest of the roundup.
Comparison pic.
Unloaded.
1 ohm resistive. Juuuust getting into a solft clip. Maybe. Still pretty clean to me and better than some of the others.
5,800w. 72% efficient.
Clamp on subs.
6,550w rising to .9
I don't have a pic of the score. But the SPL portion was done in Ryan's truck for this one. Same box, same subs, same electrical. The CT was tested first as a baseline since it was the loudest in the other testing. So that there is no confusion between the score in my CRX and the score in Ryan's truck, I will just say that the NS-1 was...
.7db down from the CT. Assuming the scores scaled the same way, that would put the NS-1 ~ 157.9 in the CRX.
4x world champ
- Floyd E. Toole
Old 11-22-2013, 06:25 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Wrap up.
Ok, so recap and in order of power made.
CT Sounds 7k - 7,930w - 158.6db.
American Bass 750.1 - 7,100w - 158.2db
Digital Designs M4a - 6,490w - 158.0db
JBL Crown 6000 - 6,400w - 158.2db
Popcorn Sounds 6k - 5,700w - 157.1db.
Not surprisingly, the amp that made the most power was the loudest. What is surprising (to some) is the amp that's 4th out of 5 in terms of apparent power was tied for 2nd in score. There's something to be said for A/B topology there. Even though I think it's some sort of hybrid.
Dollar per watt/score... I'll have to begrudgingly give the nod to the Popcorn. Even though I don't know how much they are. Assuming they're $800 or so? That's 14 cents a watt. Which is 3 cents cheaper than the CT. But I'd trust the CT waaaaaaaaay more than a Popcorn. The other (3) come in at ~ 22-23 cents per watt. Still a bargain for the quality of amp you're getting, IMO.
My thoughts...
CT Sounds - solid performer. Made the same power at 10.5 dcv as it did ~ 14v. This is great news for battery guys. That puts it in DD territory as far as low voltage beastliness. It's also a big bish if you're into that kinda thing. The white is clean but makes scuffs, scratches, smudges stick out like a **** on a fish. The pots on this amp were the "cheapest" of the bunch. I don't care for the plastic Phillips head pots. It's not a deal breaker. Just an observation. Bass knob/Voltmeter also earns bonus points from me. It has a clipping indicator on it too, but it's not of much use. It started flickering around 40acv when it made over double that clean. No surprise there since I've been telling y'all forever that those things are just a light show.
Side note on the CT: it's the only amp here with triple inputs. Ryan only had (2) spare leads so we tested it first with just duals. But we agreed to test all the amps the way they were designed. Fwiw... The 3rd input was worth .2 on the meter.
AB 750.1. I've got love for the VFL's. What I don't care for is AB's ratings of them. They've seemingly gone to "max" power ratings. The amps are solid enough. They don't need inflated rating to sell them. Do they? Bonus points for the AB being 18v stable. It would walk these others once you get past the 16v CT and 15.2v DD. But... That doesn't help the 12v guys. It's also a big ass amp physically. It dwarfs the M4a in size, but not so much in score. Still way up there on my recommend list even though I feel like it underperformed here. Most efficient of the bunch by what probably amounts to margin of error.
M4a... Oh how I love thee. Smallest amp in the bunch and perhaps a bit of an underdog in this one. It fell short of DD's 7k rating, but still made the most power per sq in of real estate. Low voltage monster. Bulletproof as they come. Doesn't like .25 much so it took a slower roll to get it there but it did fine. We tested the protection circuit pretty good finding the sweet spot on the roll. .35 is the lowest I'd recommend burping this one. Has the lowest operating voltage of all these amps. 15.2-15.3 or so is all you're likely to be able to run. Not a concern for 99% of people but its nice to have a little cushion in the voltage.
JBL Crown... This is one of those holy grail type amps. Its hyooooj. Entirely impractical. Not so efficient and 1,000% awesome. Do want. This test absolutely demolishes the efficiency myths floating around about this amp. It's really a gigantic, retardedly bad ass SQ amp. It's also a 2 channel so it was bridged here. It ALSO only has single inputs. And I'm now cursing the fact that we didn't test it with duals. Just might have caught that big white bish. This amp is just plain sex and the output test was just for funsies but it impressed me even though I've heard it before. This amp will be mine. Oh yes... It will be mine.
Popcorn Sounds... GFY.
Sunown NS-1 - Most expensive amp in the test. More optimized for high voltage operation so it was maybe at a disadvantage in this one. Still did well at 14v, but this one and the AB would really start stretching the others out with more voltage if that's your thing. This amp is basically an M4a that is operational to 19v. Which is awesome considering how much I like the M4a.
4x world champ
- Floyd E. Toole
The Following 18 Users Say Thank You to TaylorFade For This Useful Post:
Ali888 (11-23-2013), BIGJEFF64 (05-01-2014), brad0069 (11-26-2013), bump4life (03-19-2014), CLRagland1 (11-22-2013), CortezDTV (11-22-2013), cthedinger (11-26-2013), dasinde91 (02-13-2014), enemyofsilence (11-07-2016), EpicenterDesigns (11-26-2013), k3n12ock (11-22-2013), KTMrida4life (11-22-2013), LoudnProud (11-23-2013), n8skow (01-24-2014), nino23 (02-26-2014), SINTORMAN (11-23-2013), vetkilr (11-22-2013)
Old 11-22-2013, 06:31 AM
0/11 sssss1027
Where is the rest of the info on the other amps?
Old 11-22-2013, 06:43 AM
0/11 sssss3986
SLOW!
DD Z-SE Test thawaxshop Car Audio Videos 17 04-03-2012 01:30 PM
6 iraggi alts 1000amp load test&single 380 test 98HOEONSIXEZ Car Audio Videos 21 06-11-2010 10:24 AM
GM-Chrysler Merger Rumor Roundup: Deal To Be Done By Halloween Patrick Simmons General Automotive Chat 7 10-22-2008 10:18 PM
Heart of Texas Mustangs 8th Annual All Ford Roundup ~ McGregor TX ~ 09-27-2008 Patrick Simmons Car Show Feeds 0 09-22-2008 03:02 AM
