Anyone clamp a SQ2200.1? - Car Audio Classifieds!
Old 12-28-2013, 08:56 PM
0/11 sssssss71
Default Anyone clamp a SQ2200.1?
My voltage doesn't drop below 14.0 and I'm wired at 1ohm so does anyone know what the AQ2200 puts out at, let's say 13.8v at 1.2ohm?
I would think a little more then rated
Old 12-28-2013, 08:58 PM
0/11 sssss1067
AudioQue 2200.1
rising to .9 ohms
-2,538w @ 11.4v
-15.5v - 3,365w @ 13v
AudioQue 2200.1
-.5 nominal. Rise to 1.7
-Drop to 12.8v
-1,900w
ca.com traded w/ beaver1992, p3bumpin, 1phatclipse, spltuscon, profoundwill
ca.com bought from: SPY, audio_phill, ltr450racer690, huricaine
ca.com sold to: millimac247
caco: White91Formula, sleepingciv, 98AckCL23
plenty on Ebay: (Nathan7145)
Old 12-28-2013, 09:08 PM
p4killer's Avatar
0/11 ssssss255
Typical rise is around 2-4 times nominal. Usually higher than 2. Usually lower than 4. So lets call it 3x rise. Meaning to say than although it is wired at 1 ohm (nominal) the impedance changes alot while playing music (reactive) and its usually higher than the starting (nominal) impedance, hence its called rise.
So if you have say 3 times reactive rise. Your amp is seeing 3 times 1ohm = 3 ohm. Thats likely why you dont see much voltage drop, because at 3 ohm your prolly only sending a true say 800 watts.
Now all of that is very toungue in cheek. Actual impedance will vary with alot of different variables especially frequency.
That only way to see what kinda power your doing is by doing a clamp test.. which involves measuring the output voltage with a dmm and measuring the output current with an ac clamp meter. And even then thw results will off because the voltage and current are out of phase, but it will give you a rough ballpark idea of realtime power.
Long story short, how much power your amp is doing doesnt really work like that..
Old 12-28-2013, 10:14 PM
0/11 sssssss71
Yeah I wish I would of dropped to .5ohm but my new subs I got are dual 4:/ no big deal. Does a [email protected] out of the trunk so I guess I shouldn't complain to much
Which amp, SQ2200, or DC2k ABWDEagle General Car Audio Discussion & Questions 22 11-17-2013 02:12 AM
Sq2200 at .5ohm stssilverado General Car Audio Discussion & Questions 17 11-15-2013 03:04 PM
T-Line box. FI Q 12"@SQ2200.1 in 2013 Mustang SanchoR Car Audio Videos 6 10-13-2013 01:02 PM
Anybody use HF clamp? dirt101 General Car Audio Discussion & Questions 5 09-01-2013 11:36 AM
dc 3.5 clamp results? caloriu (DC) 4 12-05-2011 11:36 AM
