My test: Sonido Mask ZX-2000.1 - Car Audio Classifieds!
Old 04-25-2014, 08:36 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Default My test: Sonido Mask ZX-2000.1
I have to say... I am officially sick of this amp. So let's just get the test done and move on with our lives.
Sonido Mask 2000.1
Price - $289
Rated RMS @ 1 Ohm(<1% DISTORTION) 1936W
RMS @ 2 Ohm(<1% DISTORTION) 1300W
RMS @ 4 Ohm(<1% DISTORTION) 1050W
Fuse Rating 150A
I assume these numbers are at 14.4v, but this is a 12v test on 12v batts.
The amp is really not all that bad looking, but anytime anything lights up on the front of an amp, it makes me think it's cheap because it's obviously being marketed to a specific crowd. And I'd rather you spend that money elsewhere than an LED logo. Or cut it out of the cost altogether. But that's me.
You can tell just by picking the amp up that it's lacking either the sink or the guts to be a 2k. Or both. It has a "budget" feel to it. I've handled 1k's with more heft.
Control side. Variable bass boost is a nice feature, I suppose. *If* people knew how to properly utilize it. But most don't. And if they do, they know better than to use it anyway. SSF and LPF. Ok. The pots are actually decent. You would expect plastic pots on an amp like this, but this is Sonido's premium line so I guess it has some bells and whistles. I didn't bother to play with the bass knob, but I dont' have much faith in those 3.5mm ones. And most of you know how I feel about gain knobs anyway. "Tiffany" style RCA's are a nice touch.
Solid input terminals. Not particularly oversized, but at least they're 1/0. Pretty standard on a 2k though. The set screws are phillips head. Yippee. The speaker side fits 8awg no problem and the power and ground fit 1/0 welding without any fuss. I like when the remote is between the terminals. It gives a little bit of seperation between the power and ground- because frayed wire can make for some fireworks.
Guts and some closeups of the board.
Monsters
On to the testing. I apologize in advance for the glare in some of these.
Setting unloaded. This is actually a good bit of voltage for a 2k.
First up is 5 ohms (resistive).
That's 480w @ 5ohms and 13.5v with 73% efficiency.
Next is 2.5 ohms (resistive).
That's 950w at 2.5ohms and 14v with 72% efficiency.
Here's 1 ohm resistive.
That's 1,420w at 1 ohm and 13v with a whopping 62% efficiency. Yikes. That's idicative of a class A/B amp. This pull got past my alt at idle so voltage dropped to 13v. This would be much worse on on most people's system who would be running this amp.
To give this amp every chance to make clean power, I adjusted the volume for each pull so that it remained clean. I don't usually do that (or need to). But in case you're wondering why I did that or what it would look like if I didn't do that, here you go...
That's 1,680w at 1 ohm and 13v and efficiency drops even further to ~ 60%. You don't need to be an expert to see that the wave is pretty squared off there. The problem here is that this is what you would get if you had set the amp at max clean unloaded. The amp just doesn't have the ass to stay clean.
Curious what the amp does at battery voltages after it gets past an OEM alt?
It just gets uglier and uglier. Although... efficiency didn't get any worse. Your coils would be pissed here. Even though most of the people running amps like this have Zv.4's or Lvl5's for some reason.
In case you missed it, here are the in-car comparison measurements with some comparably sized amps. I used max SPL and an SMD AMM-1 in dyno mode here.
Digital Designs M2b
-1.4 - 656w - 142.6db
-.35 - 1,922w - 146.7db
Rockford Fosgate 1500bd
-1.4 - 671w - 143.1db
-.35 - 1,801w - 146.1db
Sonido Mask 2000
-1.4 - 345w - 140.9db
-.35 - 1,392w - 145.3db
Prototype "1200"
-1.4 - 279w - 141.1db
-.35 - 1,150w - 145.0db
This is the part where I usually give my personal thoughts on the amp being tested. Due to the recent events surrounding this amp and the person selling them and his tactics to do so, I am withholding my personal opinion of the amp and I will let the testing and numbers do the talking.
You be the judge.
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
97_eldo (04-25-2014)
Old 04-25-2014, 08:40 PM
0/11 sssss1882
Wow. I knew to stay away. That wave looks scary.
Thanks for the info, and as usual. Great testing.
Old 04-25-2014, 08:43 PM
0/11 ssssss741
another awesome test!
Old 04-25-2014, 09:31 PM
0/11 ssssss227
Since this test is done upto clipping im guessing a certified 1%thd test would be a bit less
Old 04-25-2014, 09:57 PM
twentyhurtz's Avatar
0/11 sssss1335
..... You forgot to rub it in for them by posting the frequency by the scores..
The Following 3 Users Say Thank You to twentyhurtz For This Useful Post:
B-Shot (04-25-2014), power-fanatic (04-26-2014), shizzzon (04-26-2014)
Old 04-25-2014, 10:18 PM
IS300IAdeathRow's Avatar
0/11 sssss3693
Feedback Score: 42 reviews
Great testing as always fade, Still amazes me that some toolbag had the Gaul to say the sonido mask was on the same level as an m4a lol when it's not even in the running with an m2b lol
2013 Toyota Highlander
Build to come.....
Old 04-25-2014, 10:35 PM
0/11 sssss2090
A salesman job is to say his product is the best. Having T-Fade testing his product, amp, may not have been part of the plan.
Old 04-25-2014, 11:22 PM
B-Shot's Avatar
Bass Enhanced
0/11 sssss1733
What is napping on Facebook? I don't use it but I imagine it pretty entertaining
Old 04-26-2014, 12:00 AM
bumpin buick's Avatar
Loud Noises
0/11 sssss9731
Feedback Score: 31 reviews
That's Okay Taylor Ill say it for you. People like this are a bad example for the new comers to this sport who dont know better, they look at these results and believe them, they dont know better to look further into them and that is a true shame. Its hurting this sport. Having gobs of youtube videos, does not increase your knowledge on the matter. I truly wish Brad would try to learn something so he could pass it on to his followers but he seems pretty close minded.
I think anyone and everyone who does 1st party testing should have to state that when giving results, so they should be taken with a grain of salt. He works for the company, "designs" and sells their products.
The part that takes me back is he considers what he did to be a TEST. No controlled variables and no data was taken besides a score. Nothing was kept even, not battery voltage, coil temperature. If he knew how to use a scope or a multimeter, maybe we could see what was going on and why he got the scores he did, that is saying he didnt mess those up from the get go. I question how the amp was set, my guess is everything was set wide open for gains.
I'm glad a professional went out of his way and spent his time and money to do an honest test to set the truth straight with no connections to the company or companies he tested against the amp. So thank you Tfade.
The Following User Says Thank You to bumpin buick For This Useful Post:
Old 04-26-2014, 12:01 AM
SPL Distribution Owner
0/11 sssss2983
Can we get a TFade-2006 Certification standard set soon?
The Following 3 Users Say Thank You to shizzzon For This Useful Post:
djscrubb (04-26-2014), jheist1991 (04-26-2014), walwalka (07-01-2014)
Sonido Mask... Louder than a DD M4a? TaylorFade General Car Audio Discussion & Questions 123 04-22-2014 07:19 PM
Sonido Mask and company. Clamp + SPL TaylorFade Testing & Scientific Data Discussion 14 04-17-2014 12:41 PM
Honda civic build with ct sounds and sonido mask myjaja Build Logs 16 04-07-2014 02:41 PM
Sonido Mask zx2000.1 fivedollapizza General Car Audio Discussion & Questions 46 03-20-2014 11:15 PM
Autosound 2000 Test CD mennitti Wanting to Buy (WTB) 4 08-22-2009 09:46 PM
