06-14-2014, 04:42 PM
Authorized Vendor
Knukonceptz fuses
Bought 6 knukonceptz 150 amp fuses, 3 for use, 2 as spares, one to test accuracy of rating.
Well first fuse was 385 amps initial then 280+ for over 10 sec till I stopped. Didn't pop
Decided to test the rest
Knukonceptz fuses don't blow - YouTube
I would not recommended the fuses
06-14-2014, 04:43 PM
Interesting Todd blew these before the audio pipes blew they couldn't handle shit
Edit: I think they were the minis
06-14-2014, 05:30 PM
Awaiting Confirmation
Feedback Score: 33 reviews
thats too bad  i always like knu
2006 grand caravan
sony dsx-s210x
lanzar opti 2k
3 sundown sa8v2d4
t-line unloading at 34
juice box black cherry
06-14-2014, 08:45 PM
Authorized Vendor
these are the mini anl's
on the right, a fuse that seen 300+ amps but didn't pop, left is normal
06-14-2014, 09:04 PM
Tinder Douchebag
But dude, isn't having them loose like that causing a ton of resistance?
team graham
The Following User Says Thank You to graham For This Useful Post:
06-14-2014, 09:28 PM
Authorized Vendor
the fuse is being shorted, the current flow is the only thing being tested. if it was really loose and making a horrible connection then 300 amps wouldn't be able to pass thru. BUT, 300+ did pass thru a 150 amp fuse and it didn't blow. so in a nut shell, loose = irrelevant in this test
06-14-2014, 09:33 PM
Tinder Douchebag
But wouldn't there not be a solid enough connection to get to the actual piece of metal that is designed to pop? It seems like the ends are melting off because that is the only part of the fuse that is completing the circuit.
I'm not saying you're wrong, and if this sounds completely ridiculous than disregard everything I said, but nobody hooks up their fuses like that, lol.
team graham
06-14-2014, 09:36 PM
Authorized Vendor
the center piece, in the test, is still seeing 300+ amps which is the test. if you look in the picture with 2 fuses in my hand, that fuse was shorted with bolts holding the ends as if it was mounted. the only thing it did was melt a hole through the fuse blocks bolt
06-14-2014, 09:38 PM
Maybe horrible QC testing? todds were blowing fast as shit this is indeed strange
06-14-2014, 09:42 PM
Authorized Vendor
they have no standards to follow thru on. one of the few companies that do have them is cooper bussman
Thread Tools |
Display Modes |
Linear Mode
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Knukonceptz 0g Wire, Inline fuse holders, Disto blocks, RCA's, Fuses etc.
gnatnoop |
Wiring, Electrical & Other Installation Equipment |
6 |
11-18-2013 11:01 AM |
KnuKonceptz 1/0, 4 AWG, RCAs, Fuses, Voltmeter, etc
enemyofsilence |
8 |
09-25-2013 11:51 PM |
1/0 Copper Welding Cable, 0-gauge KnuKonceptz, 300amp fuses, RCA's, etc.
LeatherKicks |
23 |
11-30-2011 04:51 PM |
New knukonceptz 1/0 fuse holders with 300 amp fuses
Mgcauctions09 |
3 |
02-08-2010 01:20 PM |
[SOLD] Brand New KnuKonceptz Inline ANL Fuse Holder w/60A & 300A ANL fuses
BlackWaterOp |
9 |
06-27-2009 12:30 AM |
