JuiceBox Battery - Latest Lithium Iron Phosphate Prototype Load Test Analysis - Car Audio Classifieds!
Old 10-22-2014, 12:22 AM
Active Member
0/11 ssssss846
Feedback Score: 23 reviews
Default JuiceBox Battery - Latest Lithium Iron Phosphate Prototype Load Test Analysis
Detailed Breakdown of Load Test Results.
Testing was done on AutoMeter SB-5DT. This meter uses 2 gauge OFC wire and copper alligator clips. This meter is rated not to exceed 500 Amps. All testing was done on the same day with small 2-3 minute pauses before runs to allow for ample cooling time. Tests were done from Largest, 500 Amps, to lowest, 200 Amps, and no charge was given between tests.
Load Tests (500AMP, 400AMP, 300AMP, 200AMP): All tests were preformed in order, no charging was done in between testing.
500 AMP BreakDown
Starting Voltage: 13.83v
@500 Amp Start Voltage: 12.21v
Duration: 10 Seconds (Machine Thermal Limit Reached)
@500 Amp End Voltage: 11.83v
@500 Amp Average Voltage: 12.02v
Stand Alone Power ( No Additional Power Source)
12.02v x 500 Amps = 6,010 Watts
Stand Alone Power x Common Amplifier Efficiency's
@90% = 5,409 Watts
@70% = 4,207 Watts
@50% = 3,005 Watts
Juicebox Lithium Iron Phosphate 40ah Battery - 500 amp load test - YouTube
400AMP Breakdown
Starting Voltage: 13.34v
@400 Amp Start Voltage: 12.31v
Duration: 17 Seconds
@400 Amp End Voltage: 12.03v
@400 Amp Average Voltage: 12.17v
12.17v x 400 Amps = 4,868 Watts
@90% = 4,381 Watts
@70% = 3,408 Watts
@50% = 2,434 Watts
Juicebox 40ah Lithium Iron Phosphate - 400 amp load test - YouTube
300AMP Breakdown
Starting Voltage: 13.30v
@300 Amp Start Voltage: 12.52v
@300 Amp End Voltage: 12.23v
@300 Amp Average Voltage: 12.38v
12.38v x 300 Amps = 3,714 Watts
@90% = 3,343 Watts
@70% = 2,600 Watts
@50% = 1,857 Watts
Juicebox 40AH Lithium Iron Phosphate Battery - 300 amp load test. - YouTube
200AMP Breakdown
Starting Voltage: 13.26v
@200 Amp Start Voltage: 12.72v
Duration: 22 Seconds
@200 Amp End Voltage: 12.48v
@200 Amp Average Voltage: 12.60v
12.60v x 200 Amps = 2,5020 Watts
@90% = 2,268 Watts
@70% = 1,764 Watts
@50% = 1,260 Watts
Juicebox Battery Lithium Iron Phosphate 40 AH - 200 amp load test - YouTube
Juicebox Battery Online Operations Manager.
The Following 2 Users Say Thank You to Kevin.Ross For This Useful Post:
alacran (10-22-2014), k3n12ock (10-22-2014)
Old 10-22-2014, 12:35 AM
djscrubb's Avatar
Captain $hit disturber
0/11 sssss2332
Very good write up sir
Old 10-22-2014, 09:23 AM
BigBen's Avatar
0/11 sssss3006
Feedback Score: 24 reviews
These really have incredible rebound. I look forward to more testing
Old 10-22-2014, 04:39 PM
0/11 ssssss822
**** something else i want and will get
01 tahoe 80prs
275 & 350 singer alt
2 black cherries
levi iii
2 12's dds tridents
4 cf 8's & vifas xt25's
Old 11-04-2014, 04:44 PM
Sencheezy's Avatar
0/11 ssssss483
Update?
165db with 237 DC Volts
6 15" SSA Evils
3 HV Taramps T60k @.33
18 XS Power D3400s
Add me on SC, FB, IG, and YT @ Sencheezy
Old 11-08-2014, 08:07 PM
SPL Distribution Owner
0/11 sssss2983
Voltage is not indication of SoC level with LiFePO4 batteries. 20-90% typically shares same measurable range.
lithium battery korey_hofer General Automotive Chat 19 07-09-2014 10:44 PM
How to load test a battery? tacomaguy1 General Car Audio Discussion & Questions 8 02-24-2012 11:02 AM
whats this new JUICEBOX battery? infinite913 Car Audio Videos 11 12-19-2011 02:26 PM
Not your average D3100 load test. [email protected] General Car Audio Discussion & Questions 12 04-08-2011 11:59 AM
6 iraggi alts 1000amp load test&single 380 test 98HOEONSIXEZ Car Audio Videos 21 06-11-2010 10:24 AM
