Brazil vs. Korea vs. "'Merica". SPL round - Car Audio Classifieds!
Old 04-13-2015, 10:25 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Default Brazil vs. Korea vs. "'Merica". SPL round
Since I was bench testing the Banda ICE 4000, I decided to pit it against some similarly sized amps. In case you missed the bench test you can review that here... My test: Banda ICE 4000
I call this test "max useable" because all I do it set them for max clean and then turn them up until they stop gaining on the meter. I record the clamp and score at the highest point regardless of clipping or distortion. Fluke meters were used for the clamping. I purposely did not use the AMM-1. Output numbers are sort of irrelevant here so they are rounded to the nearest 100w. I really only clamped to monitor things in case there was an anomaly and to verify reactives were similar between the amps.
Voltage drop is not recorded but all amps were given the same starting voltage of 14.5v on a large bank of caps.
(3) beefy 3" coils in a daily setup were used so that thermal issues were kept at a minimum. The frequency used was 50hz.
Each amp was wired to .66 nominal and each amp had similar rise to 2.4 ohms.
Banda ICE 4000
- 152.1dB
- 2,900va
Taramps HD4000
- 152.1dB
- 2,900va
Twisted Sounds 3.5k
- 151.6dB
- 2,600va
MMATS 4000
- 151.3dB
- 2,200va
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
The Following 2 Users Say Thank You to TaylorFade For This Useful Post:
expo615 (04-26-2015), jeffdachef (04-14-2015)
Old 04-14-2015, 12:15 AM
0/11 sssss3526
Well....in before the butthurt
Old 04-14-2015, 01:26 AM
0/11 sssssss83
I'm really shocked actually. Maybe disappointed is the word haha.
Old 04-26-2015, 10:06 AM
So Low's Avatar
0/11 sssss1258
So this is a clamp not the SMD AD?
Old 04-26-2015, 10:25 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
I'm guessing because of the clipping. Pretty sure the SMD will shut off in some modes with clipping. Could be wrong on that though.
Current Build:
#60sHereIcome
Old 04-26-2015, 10:29 AM
massivespl's Avatar
0/11 sssss8409
Mmmmm Korea
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 04-26-2015, 10:30 AM
So Low's Avatar
0/11 sssss1258
Probably right about that. It's a comparison test so clamp vs real power is irrelevant but just wondering About the power numbers between these amps
Old 04-26-2015, 10:31 AM
sundownz's Avatar
vendor
0/11 ssss11704
Was that the 0.5 ohm or 1 ohm MMATs amp ?
- Jacob Fuller
- Owner,
Old 04-26-2015, 10:37 AM
Lock up your daughters!
0/11 sssss1342
Never understood how an amp could make less power, but score higher on the meter.
Is that due to harmonic distortion, clipping, or something else?
I know the Brazilians have a higher THD
Old 04-26-2015, 10:48 AM
So Low's Avatar
0/11 sssss1258
THD. Sometimes rail voltage. Say one amp does 5k at 10% THD, the other does 4k at .1%. Chances are the "useable" power is more with the lower THD power, as more of the duty cycle is going towards moving the coil, rather than dissipating heat, resulting in about the same score. I'm making up the numbers here but you get the point.
Those rowboat sized JBL Crown amps had an ungodly amount of AC voltage on tap, and would out score similar class D amps on the meter with less power/VA. A/B is hard to compare directly to class D sometimes.
And I just noticed that Taylor specified VA. I guess I can't read...
The Sheen, round 2 on UStream "phones are trolls" Sonically_Sound Off Topic Chat 0 03-07-2011 10:51 PM
[WTB] Two DC Audio 4XL (SPL) 10" or 12" or 15" BassClub Wanting to Buy (WTB) 9 01-11-2011 01:49 AM
tc912" round two vid DonH Car Audio Videos 11 03-23-2010 02:02 AM
18" mt vids round 2 - bushj311 Bushj311 Car Audio Videos 24 11-28-2009 04:06 PM
3 round 10" ports jj53913 Enclosure Discussion & Design Construction Help 10 05-19-2009 11:27 PM
