Interesting EMF Audio article about gauss - Page 3 - Car Audio Classifieds!
  #21
Old 05-16-2015, 10:41 AM
Lock up your daughters!
1/11 sssss1327
Originally Posted by tymoto21 View Post
Well look at the DDz super strong motor
Without tuning properly and wiring low impedance rise will kill any power you hoped to use
Iirc a guy by me tested his pair of 15's and had rise from 1 ohm to 8 ohm at his best score
If used properly can take gobs of power and get stupid loud
Yes, higher motor force equals higher rise.
I had my Z on a Banda 7k and took every bit of clean signal in a ported box.
I then had it on my M4a in a sealed box. Could not go full tilt on the amp before the sub was stressed. Rise in the sealed box was probably less.
What kind of power did he have his on?
Old 05-16-2015, 10:43 AM
mega fatty
1/11 sssss5957
Iirc this is due to the motor design I will look for the thread
I couldn't find it but I think Jeff wrote some info about it
And it was like 7k for the pair
With a sealed box you will loose cone control the lower you play
My hcca was tuned to 32 and if I plugged the port good lord it would flex
  #23
Old 05-16-2015, 10:57 AM
1/11 sssss1327
Yea, didn't like to play low in the sealed box, unfortunately.
Ported was awesome though
  #24
Old 05-16-2015, 12:06 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Originally Posted by adulbrich View Post
what motor is on the sub that is your avatar?
b&c ipal
  #25
Old 05-16-2015, 12:25 PM
1/11 sssss1327
Originally Posted by Jeffhulbert50 View Post
b&c ipal
Thanks! That motor looks delicious
Neo?
  #26
Old 05-16-2015, 01:09 PM
0/11 sssss1085
Feedback Score: 23 reviews
There are ways to combat the rise on powerful motors, but they are not common with the SPL crowd and they come with some compromises.
Thwarting back-emf by means of a pole sleeve or ferrofluid can drastically reduce the impedance peak. The compromise with the pole sleeve is a loss in motor force, and the compromise with ferrofluid is that it is not conducive to high excursion drivers and needs a lot of motor venting to be stable. However, in addition to the back-emf control of both of those options another benefit is they both help with cooling.
Alumapro Alchemy and the old school PPI pro flat piston subs are two that I can think of which come stock with ferrofluid in the gap and their impedance curves are shockingly flat right out of the box.
  #27
Old 05-16-2015, 02:04 PM
Authorized Vendor
0/11 ssss14115
Neo?
Radial neo
  #28
Old 05-16-2015, 02:15 PM
1/11 sssss1327
Would "supercharging" with a neo magnet on the pole piece or copper shorting rings affect rise in any way? I'd be interested in that if anyone can provide more info.
Interested in the pole sleeve like NS drivers have, but the ferrofluid sounds messy. Is that like liquid ferrite? Ferrite dissolved in a solvent? May google later, but I have to leave for work right now
Radial neo
Sweet
  #29
Old 02-04-2017, 09:51 PM
Haelmuscle's Avatar
0/11 sssss1817
Hello Brothers,
My take here and it proves what Mr. Fuller is saying, for SPL you'd need low mass, the lower the mass the higher the sensitivity would be, and for SPL purposes you should look at sensitivity, for musical setups just look for something that sounds good, cuz you know the more sensitive the speaker is the bigger the box you need to play low...
Kindest Regards.
Tags
emf, force, gauss, motor, strength
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
Emf audio? jprophet123 General Car Audio Discussion & Questions 59 03-25-2015 09:24 PM
EMF audio YOLO line.... SINTORMAN General Car Audio Discussion & Questions 171 10-15-2014 09:04 AM
Very interesting home audio enclosure Boomintahoe General Home Audio/Video 3 06-10-2013 03:47 PM
What is this with sundownaudio? emf audio? etc.. Novicaine General Car Audio Discussion & Questions 177 05-28-2013 12:41 AM
Find whats wrong with this article headshok General Car Audio Discussion & Questions 29 07-13-2009 10:08 AM
car audio forum, moble audio, car stereo, wholesale car audio, 12 volt, with, amplifier, amp, subwoofer, sound quality, buy car audio, and sell automotive stereo systems for cars Plum is my hero!
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
