Impedance technical questions - Car Audio Classifieds!
Old 05-16-2015, 11:22 PM
Lock up your daughters!
0/11 sssss1342
Default Impedance technical questions
I understand that impedance rise isn't always a bad thing. Enclosures are often very efficient when impedance is the highest. The two may or may not be related depending on the install.
Will infinite baffle have more or less rise than a ported enclosure? I have gotten different answers from different experts.
So, what is the best way to fight impedance rise? Some full bridge Brazilian amps have special circuitry to help compensate for rise, but they do not completely eliminate it. I am going to run a Taramps 30k, and don't want to wire it low in order to get the full power out of it.
I know that the stronger a motor is, the more drastic impedance rise will be. That is one of the reasons that neo motors have higher rise.
It was brought to my attention that adding a pole sleeve can reduce impedance rise. I had previously thought that pole sleeves were only used in Sundown Nightshades as shims, because there were many different coil options. What material are pole sleeves like this made out of? Aluminum, copper, steel, or something else? I'm guessing most are aluminum and some are copper. Apparently, pole sleeves reduce rise, but also reduce motor force.
What affect does "supercharging" with neo magnets on the pole piece have on rise? The primary purpose of the magnets is to direct more flux back into the gap, according to DD.
Will a copper shorting ring on the tip of the pole piece affect rise? I have heard that it reduces back-EMF, but am not sure.
A far as damping, I have also heard that the amplifier used affects rise. Is there any more public information about amplifier damping factor?
I'm interested in designing and building a neo motor for a 5" b2 coil, and want to get the maximum I can out of my amp.
Does anyone have interesting information about coils?
Copper is more efficient, but it is heavier than Aluminum. Aluminum can handle more power because it dissipates heat faster, and is lighter by volume. Which would yield higher rise. If I had to guess, I'd say aluminum.
Please share any other information you have about the technicalities of subwoofer motors, rise, and/or amplifiers.
Old 05-16-2015, 11:50 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
pole sleeves are exactly as they sound. a sleeve (tube) of material. sleeve helps visualize that its a solid piece. look at a coil former, notice it has a slit/separation. that's to prevent shorting. the pole sleeve AKA shorting ring/sleeve creates a closed circuit to absorb eddy currents.
using a sleeve makes a motor weaker because it makes the gap larger (requires a smaller pole to make room for the sleeve) if the pole needs to be 3.00 OD and the sleeve is .10" thick, you need to shave the pole down to 2.9 thus the gap is "wider"
some are aluminum, some are brass, others are copper. each material has its thermal/shorting/cost advantage/disadvantage
the supercharge option is almost a one sided bucking magnet. the pole is often the weakest link in magnetic loop. placing a magnet in top of the pole (with matching magnetic poles touching) works to increase the strength by making a secondary loop between the top of the top plate and the pole. the bad portion is increased stray flux since the open pole is rather generous in its flux spread
copper on the pole will help in a similar manner that a pole sleeve has. its a shorted material that has the property of magnetic interference/manipulation.
as far as coils, a 5" coil is rather large and IMO its a novelty concept. not entirely a need for a coil that large.
aluminum has a higher resistance then copper obviously. depending on your coil parameters, a copper coil will not be good for a 5". its weight would be insane unless you design the motor as a split gap to keep the necessary wind height minimal. copper can limit the impedance choice you want also. d1 for instance in copper with a 5" diameter wont work out nicely. go with aluminum and due to the body, .010 minimum former.
adulbrich (05-17-2015)
Old 05-17-2015, 12:17 AM
0/11 sssss1342
Originally Posted by Jeffhulbert50 View Post
1. pole sleeves are exactly as they sound. a sleeve (tube) of material. sleeve helps visualize that its a solid piece. look at a coil former, notice it has a slit/separation. that's to prevent shorting. the pole sleeve AKA shorting ring/sleeve creates a closed circuit to absorb eddy currents.
2. using a sleeve makes a motor weaker because it makes the gap larger (requires a smaller pole to make room for the sleeve) if the pole needs to be 3.00 OD and the sleeve is .10" thick, you need to shave the pole down to 2.9 thus the gap is "wider"
3. some are aluminum, some are brass, others are copper. each material has its thermal/shorting/cost advantage/disadvantage
4. the supercharge option is almost a one sided bucking magnet. the pole is often the weakest link in magnetic loop. placing a magnet in top of the pole (with matching magnetic poles touching) works to increase the strength by making a secondary loop between the top of the top plate and the pole. the bad portion is increased stray flux since the open pole is rather generous in its flux spread
5. copper on the pole will help in a similar manner that a pole sleeve has. its a shorted material that has the property of magnetic interference/manipulation.
6. as far as coils, a 5" coil is rather large and IMO its a novelty concept. not entirely a need for a coil that large.
7. aluminum has a higher resistance then copper obviously. depending on your coil parameters, a copper coil will not be good for a 5". its weight would be insane unless you design the motor as a split gap to keep the necessary wind height minimal. copper can limit the impedance choice you want also. d1 for instance in copper with a 5" diameter wont work out nicely. go with aluminum and due to the body, .010 minimum former.
First of all, I'd like to thank you very much for your input.
I numbered your paragraphs to make my responses easier to understand:
1. I did not understand the purpose of the slit in the former. I simply thought it was a cost thing. Formers made of cut and bent sheet metal would be cheaper to produce than thin cast tubes. Is eddy current the same as back-EMF? Inf not, how are they different?
2. Ok, so reducing the size of the steel pole piece makes the gap wider, even though you put more metal around it to make up the space. Makes since since the sleeve materials are not magnetic.
3. Thanks for the info. I know I've heard of Aluminum and Copper being used. Brass makes sense since it has a lot of copper in it. Which would be the best if cost was not a factor? Do the materials have their pluses and minuses like everything else seems to have? How do you determine the ideal thickness of the pole sleeve?
4/5. Would neo supercharging or copper shorting ring be better if cost is not a factor?
6. I was thinking that 5" coil because of its thermal power handling capabilities. I want to get a Taramps 30k to power one sub. If you know of any coils that can handle more power daily, I would be more than happy to know!
7. I would like to wire to one ohm nominal, so either dual 2 or dual .5.
I like the idea of dual .5 like my Z, because I can wire 1 ohm for daily and .25 for burps.
However, I have heard that parallel wiring is better than series if both setups wire to the same resistance. Not sure how true it is. My only source is this video: https://www.youtube.com/watch?v=IFFDrWGUDkM
EDIT:
Would you build me a Supergauss neo sub with a 5" coil?? Can you think of any better ideas?
If so, I would really like to talk to you about it
Old 05-17-2015, 12:35 AM
Authorized Vendor
0/11 ssss14115
EMF is EMF, the back portion is simply the device creating reversed emf as apposed to induced. short a coil and move it through the gap or try reading impedance when tapping the cone.
the slit is to prevent the coil from turning the former into an inductor
proper modeling would help simulate appropriate amounts. im not sure if a general rule of thumb exists though.
that's a good question also. faraday law im not 100% on. id guess copper due to its thermal and magnetic conductivity property. downfall being corrosion prevention.
id rather put the "charge" into the assembly instead of adding a device. id also do both shorting rings for minimal inductance and better motor
keep in mind, more power is fine and all but eventually your still getting the same cone area X excursion for general output thus keeping a lot of the power from being used properly. 5" coil will limit you to 18s respectively .
I prefer a fully parallel setup my self to minimize length of the circuit
EDIT:
supergauss is a play on a bucking system. id find 2 motors to base it off of, tear them down and reassemble with appropriate mods. done deal. was going to try it on my n3's but the weight would have been ~145lbs for one sub lol
Old 05-17-2015, 12:49 AM
0/11 sssss1342
Yea, impedance fluctuates even when you're just talking. It's always jumping around when you measure with a multimeter. I heard about some SQ drivers having one coil that was shorted internally to work as a magnetic brake. You mentioned something similar when we were discussing supergauss subs.
Copper would make sense. Seems like copper is one of the best options when audio is concerned. Didn't even think about corrosion though.
So you'd go shorting rings instead of a reversed neo on the pole tip?
I see what you mean about power. The 5" b2 subs are made in 15's. I would like to do one 15 in 5 cubes net tuned low on the Taramps 30k.
I would like to do a parallel for daily, but then I can't wire lower for burps with my M4a. :shrug:
I have those two N3 motors. They're currently built and I haven't even gotten to use them, lol. I'm hoping to finish my baffle tomorrow. It has been a slow build due to work, track, and homework. Summer is coming in a few weeks, but I've still got another year of highschool
Could you base it off the N3 design and not tear them apart? I know a guy who owns a metal machine shop. He made me a custom intake manifold for my go-kart so I could put a moped fuel injection kit on it for 8th grade science fair. I still have the turbocharger for it. World's smallest turbo, about the size of a soda can. He can do any custom tooling of steel for me at a decent price.
Old 05-17-2015, 01:26 AM
0/11 sssss1085
Feedback Score: 23 reviews
The oddball quad coil drivers that either short one or two coils or have a solid former are only like that to manipulate qts by lowering qms. When you put copper/brass/alum in the gap it stabilizes the B field, but a shorted coil or solid former does not achieve this.
Old 05-17-2015, 01:32 AM
0/11 sssss1342
Quad coils are awesome, but you don't see them often.
I am not very familiar with the significance of total Q. I have seen the spec, but don't understand its importance. All information on the subject would be appreciated
Old 05-01-2016, 01:42 AM
bassfreak's Avatar
0/11 ssssss597
real big difference in copper and aluminum is one is diamagnetic and has way higher conductivity properties. alum in the gap really wont do very much honestly..
putting a magnets not shielded on hte tyoke is pretty silly and you can throw the FEA out the window because you going to have some terrible flux lines and flux modulation.
you want to fight impedance? best way it take the resonance out of the alignment and driver. transmission lines help stabilize impedance both electrical and acoustically.
i see NO reason for such huge coils and inductance become very unstable and high.
your much better off with a smaller coil and using shorting rings/cooling techniques.
your going about getting loud wrong. by far the cabin and alignment you use are going to affect acoustical output than electrical input.
The Following User Says Thank You to bassfreak For This Useful Post:
adulbrich (05-01-2016)
Old 05-01-2016, 02:02 AM
Authorized Vendor
0/11 ssss14115
threads rolling up on a year old
Old 05-01-2016, 02:21 AM
bassfreak's Avatar
0/11 ssssss597
well i went threw it. figured id add to it. it surfaced..
Tags
damping, impedance, motor, neo, rise
technical help for rca voltage experiment please slowpoke General Car Audio Discussion & Questions 1 11-24-2012 08:44 PM
Technical Help please (with video) dkahns51 General Car Audio Discussion & Questions 0 06-02-2011 10:14 AM
Technical name for eskamo hats?!! mattintc10 Off Topic Chat 22 03-12-2011 02:35 AM
Another question about some technical stuff mattintc10 General Car Audio Discussion & Questions 8 10-03-2010 09:26 PM
Need technical assistance from mechman hazardous0388 General Car Audio Discussion & Questions 0 05-24-2010 11:53 AM
