Battery talk, please educate me. Im a newb - Car Audio Classifieds!
Old 01-24-2016, 02:49 AM
0/11 ssssssss7
Default Battery talk, please educate me. Im a newb
After sifting through multiple novel length posts about different battery types, ive come away with a question.
12v batt vs 16v batt on a 12v(14.4v charge) charging system.
To keep a constant voltage around an amps sweet spot of 14v, use a 16v battery. Not a 12v? But operating at this higher voltage draws more amperage and depletes the stored energy much faster?
As the alternator loses the ability to keep up with the amplifiers draw, the amplifier sucks the life from the batteries. When this happens the voltage reduces to or below the batteries resting voltage? Which causes a decrease in amplifier output due to lower voltage, as well as using less stored amperage from the battery as a result of lowered voltage?
I'm not an engineer, or a competitor. Just trying to figure out the best place to be battery wise. My 320a alt and measly 3 battery bank doesn't get abused nearly as well as most of you guys setups it seems. But as I'm considering jumping into the 10kw sub amp bracket I'm trying to line up my ducks ahead of time.
The main question is, will I see a more constant 14v at the amplifier under load, with the vehicle running using a 16v battery as opposed to a 12v battery? Will this degrade the higher voltage battery much faster?
Thanks for reading my lengthy post.
Old 01-24-2016, 03:20 AM
KickinBlazer's Avatar
0/11 sssss1122
its not recomended to mix 12v and 16v batteries....as you know good AGM 12v batteries rest at around 12.8 to 13v....and can take upwards of 15v constant voltage....on the 16v battery they ususally rest at 16.8 to 17v...and charge around 18v or so you will have to have a seperate charging system for 16v+ because the vehicles electronics doesnt like anything over 15v....so unless you want to spend extra money for a seperate charging system and 16v batteries then just add a battery or 2 to your current bank and call it done....and no its not recomended to hook up a 16v battery to a 12v source...it will not be good for either battery....however you do have the option to go with 14v batteries that charge around 16v....you can run the electronix in the vehicle with a stepdown module to reduce the voltage but again more money...so imo just add a battery or 2 to your current bank....
if its to loud your to old!
Old 01-24-2016, 05:06 AM
drunkenwhippeT's Avatar
0/11 sssss1629
floating the 16v battery at 14.4 will leave it pretty well dead. Same cell voltage of a 12v battery that's only charged to 10.8 volts. Won't get squat for current from an undercharged battery, and it will just sit and sulphate it's cells. You'd be better off with 12v batteries, if you'll be charging at 12v levels.
Old 01-24-2016, 05:48 AM
doug118's Avatar
0/11 sssss4674
Did you mean a 14V battery? There's 12v, 14v, and 16v. You definitely can't mix 16v and 12v but people do run 14v batteries in some cars and get away with it as far as their stock electrical goes
Old 01-24-2016, 05:52 AM
Just want to point out that as voltage drops current increases, not decreases. That's why amps blow from under-voltage. Voltage multiplied by current (kind of) equals power, so to make the same power with a reduced voltage you need more current.
Old 01-24-2016, 09:45 AM
mega fatty
0/11 sssss6008
What batteries do you currently have?
5-6 decent agm batteries and a nice 320a alt should support a 10k with no problem
You could look into a dual alt but we can cross that bridge once you have a decent battery bank and wire to support it
Old 01-24-2016, 10:05 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
You can run 16v batteries in the rear if you run a second dedicated alt charging them at 18v. It will be a stand alone system just for your amp or amps. You can not have them connected to your 12v system in any way.
My game is legit,
Old 01-24-2016, 11:07 AM
0/11 sssss1070
Charging System Basics
there's much more information available to you with a simple google search OP, but the link i posted is a good start
Old 01-24-2016, 02:16 PM
0/11 ssssssss7
Sorry I didn't clarify. I wasn't intending to mix batteries, but switch battery types. I forgot about 14v batteries. Currently I have 3 xsd3400 and a 320a alt. Was considering grabbing 2 more with the rebuild. And no one makes a dual bracket for my Gm 4.2li6 motor.
When it comes to mixing battery sizes of the same brand do you actually gain extra capacity or is it hindered by the smaller battery? For some reason I'm under the impression that you only get the sum of the lesser.
1 40a +2 60a yields 120a total. (just using random numbers as an example)
Old 01-24-2016, 02:17 PM
0/11 ssssssss7
And thanks to all you guys for responding.
please watch and educate yourself! SoCalBean420 Politics and Paranoia {tinfoil hat} section 11 11-21-2015 04:29 PM
Someone educate me on sub top assemblies doug118 General Car Audio Discussion & Questions 58 08-17-2015 12:33 PM
someone wanna educate me about pioneers splvictim20 General Car Audio Discussion & Questions 14 07-13-2010 03:09 AM
Another newb in AZ Lnh New Member Orientation 11 03-30-2010 05:53 AM
educate me (components) Ryan1126 General Car Audio Discussion & Questions 2 09-24-2009 05:47 PM
