Do 45's in woofer enclosure help SPL efficiency? - Car Audio Classifieds!
Old 05-11-2016, 09:08 PM
n8skow's Avatar
0/11 sssss1519
Default Do 45's in woofer enclosure help SPL efficiency?
More of a thread to start the conversation - and compare hard data.
I recently built a (musically tuned) woofer enclosure for a single 12" woofer, and wanted to do a before-and-after comparison to try to see if all the extra work (and wood) was quantifiably worthwhile.
I do enjoy seeing the craftsmanship some builders are putting into their boxes - but can someone (or many people) step forward and share some data that shows it actually improves spl efficiency?
My mods were not anything extreme - just a few small 45 degree angles - one added to the 90 degree bend in the slot port, one added in the corner opposite the woofer, and one opposite the port opening.
The data gathered (utilizing a Termlab Magnum) was over a 5hz range where optimal efficiency was found at a modest power level.
Original box:
41hz - 141.5db - 587 watts (7.41 ohms)
42hz - 141.9db - 561 watts (7.72 ohms)
43hz - 142.2db - 568 watts (7.11 ohms)
44hz - 142.3db - 595 watts (6.24 ohms)
45hz - 142.1db - 689 watts (5.41 ohms)
After adding the 45 degree angles
41hz - 141.7db - 668 watts (7.07 ohms)
42hz - 142.0db - 637 watts (7.40 ohms)
43hz - 142.3db - 633 watts (7.06 ohms)
44hz - 142.5db - 663 watts (6.15 ohms)
45hz - 142.5db - 757 watts (5.34 ohms)
From this testing, it would appear SPL has increased very slightly - but so has power (lower impedances). Efficiency appears to have actually dropped in relation of power to SPL...
Thoughts? Data?
National Finals - Oct. 29th & 30th, 2016 in Sedalia, MO
The Following 3 Users Say Thank You to n8skow For This Useful Post:
BoxxcDD (05-11-2016), Chris McNeeley (05-11-2016), graham (05-11-2016)
Old 05-11-2016, 09:35 PM
Red Light Ear Rapist
0/11 sssss1397
What where the specs of the size and tuning of the box?
2013 Subaru Legacy B-Pillar
4 Crossfire v4 18s
2 Crossfire 8x's @.33
1 Crescendo C.2 SQ with a Ampere JM1
3 SINGER 270's + Limitless 100ah 16v + 25ah 12v
Old 05-11-2016, 09:55 PM
BoxxcDD's Avatar
0/11 ssssss730
It could be just the decreases in box volume that the angles displace too.
The Following User Says Thank You to BoxxcDD For This Useful Post:
n8skow (12-18-2016)
Old 05-11-2016, 09:57 PM
BoxxcDD's Avatar
0/11 ssssss730
Not to mention the 45 at the port could of changed the area at the end slightly.
Old 05-11-2016, 10:01 PM
BoxxcDD's Avatar
0/11 ssssss730
Not all boxes benefit from 45s I have tested with and without some gain some flop.
n8skow (05-12-2016)
Old 05-11-2016, 10:42 PM
graham's Avatar
Tinder Douchebag
0/11 sssss7095
I want to know why the tests were done with 41-45hz and not 20-40hz
More air is moved the lower you go (as I'm sure you're aware) so wouldn't these results be a little more useful than up high like that?
team graham
Old 05-11-2016, 11:01 PM
BoxxcDD's Avatar
0/11 ssssss730
All depends on what your going for. His vehicle might have a resonate frequency around that range. Not to many people use 20hz for spl
n8skow (05-12-2016)
Old 05-11-2016, 11:04 PM
BoxxcDD's Avatar
0/11 ssssss730
Crank the volume on 43hz up and let her rip! Lol
n8skow (05-12-2016)
Old 05-11-2016, 11:06 PM
BoxxcDD's Avatar
0/11 ssssss730
Lol Nate I didn't even realize it was you.
n8skow (05-12-2016)
Old 05-11-2016, 11:10 PM
BoxxcDD's Avatar
0/11 ssssss730
Just a idea you could build a slightly bigger box just enough to compensate for angle displacement to see if it is the 45s vs the smaller box. You probably already did this though.
How many cubes per woofer for zv4 18 enclosure and displacement. Mnorwood01 (Sundown Audio) 4 11-07-2013 10:26 AM
Enclosure volume to woofer BlurredVision Enclosure Discussion & Design Construction Help 2 10-26-2013 07:03 AM
WTB: WOOFER PARTS or Mach 5 SPL-15 recone - Need to build two to work in small volume Ronmeister Wanting to Buy (WTB) 0 08-31-2013 07:23 AM
Atomic APX SPL woofer+daily dual 1 ohm PRICED TO SELL!!! Rocken JBL 12" Subwoofers 38 05-04-2011 09:33 PM
[Gone]10" Prototype SPL woofer Forevrbumpn 10" Subwoofers 24 10-11-2009 05:24 AM
