Voice coils "rated power handling" - Car Audio Classifieds!
Old 05-18-2016, 09:57 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
Default Voice coils "rated power handling"
this is a side note from my other thread here to keep it related to that thread where needed.
the following test was done on a transformer stepping power down to 12.5v AC nominal.
Test/example uses a sundown SA motor with pole vent / gap vents and a non vented former
point of the test- a coil can not be rated a given power handling.
reason- a voice coil needs to be used in a proper gap, and motor with good cooling to stay at proper heat levels especially when in high power ranges in relation to there overall diameter and mass of wire.
issues that cause less power handling- a coil being too loose on the pole piece with hurt handling due to lack of heat transfer between the inner wall of former and outer body of pole.
lack of cooling performance in the motor being used. bad cooling or lack there of (no air transfer with general pressure) to aid in heat transfer via air. this is a BIG issue and is displayed with the testing below.
test example A-
12.37v AC
1.41 A
~ 17.44 watts
4 ohm nominal
ambient temp- 71.2f
All stock venting used / unblocked
highest recorded temps- 96.94 - 97.05f
test example B-
12.44v AC
1.42 A
~ 17.66 watts
4 ohm
ambient temp- 71.2f
Pole vent closed
highest recorded temps- 100.15 - 100.22f
test example C-
12.39v AC
1.40 A
~17.34 watts
4 ohm
ambient temp- 71.9
No pole vent or gap venting
highest recorded temps- 99.00 - 99.10
as can be seen, and assume each test was a different motor with different cooling, the resulting efficiency is very different especially at ~17 watts. as the power level goes up, the changes would be exponential to these results.
as ive been designing coils, ive been asked many times what the "power handling" is for my coils so im making this as a preset reminder that there can not be a such thing as there are far too many factors when the coil is in use.
209native (05-19-2016)
Old 05-18-2016, 10:02 PM
Lock up your daughters!
0/11 sssss1342
Possibly one of the reasons why DD Z's handle so much power? Tons of exposure to ambient air.
I used to touch my coils between songs to see how things were doing, haha
My Silverado:
Old 05-18-2016, 10:05 PM
Authorized Vendor
0/11 ssss14115
yes and no. simply hanging a coil out there will not work. has to be organized air in the sense that the air is channeled and pressured across the coils face to make a transfer.
and open coil wouldnt last long
Old 05-18-2016, 10:58 PM
0/11 sssss1342
The pole vent may be small, but a lot of air is moved through it.
Not just simply a coil left out in the air
My Silverado:
Old 05-18-2016, 11:21 PM
Authorized Vendor
0/11 ssss14115
pole vents main usage is noise reduction. the rest of the pressure running past the former ID and pole is whats cooling
Old 05-18-2016, 11:28 PM
0/11 sssss1342
Oh, gotcha
My Silverado:
Old 05-19-2016, 04:24 PM
BigBen's Avatar
0/11 sssss3006
Feedback Score: 24 reviews
Interesting to note, the JL 13tw5 uses an external coil, the motor is inside it.
Old 05-19-2016, 04:49 PM
Authorized Vendor
0/11 ssss14115
tw5 uses a normal motor ?
coil in gap, neo under pole formation
Old 05-19-2016, 05:02 PM
BigBen's Avatar
0/11 sssss3006
I don't believe so.
Old 05-19-2016, 05:20 PM
BigBen's Avatar
0/11 sssss3006
Maybe? Maybe it was another slim sub I'm thinking about where the coil rides outside
4" Voice Coils RustyWCA Speaker Accessories & Parts 12 04-22-2013 12:59 AM
FS - 3" Voice Coils bwoodroof Speaker Accessories & Parts 8 09-10-2011 09:37 AM
Need 2.5" Voice coils Dunbar91 Wanting to Buy (WTB) 15 06-10-2011 11:35 PM
3" voice coils tangelo95 Wanting to Buy (WTB) 2 04-19-2011 06:44 PM
Voice coils read higher than rated? bergend2 General Car Audio Discussion & Questions 18 02-27-2011 05:40 PM
