do dual inputs help with voltage drop? - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Vendors > (Tool Maker)
Old 12-06-2011, 05:33 AM
MERQUE's Avatar
0/11 ssssss622
Default do dual inputs help with voltage drop?
what experience have you guys had with using aluminum dual input blocks and voltage drop? this is for a 1800 rms amp.
Old 12-06-2011, 05:42 AM
chrishova's Avatar
Eight 12''s
0/11 ssssss703
Yes, I think it's the 2 runs of 0 gauge that help, I have 2 neg and 2 pos coming from the front and I saw a difference...
'97 Grand Prix GT 3.8
5 Black Cherries
Eight SA 12''s on a DDz2
Old 12-06-2011, 05:44 AM
MERQUE's Avatar
0/11 ssssss622
in running an extra run of 0 gauge?
Old 12-06-2011, 06:06 AM
chrishova's Avatar
Eight 12''s
0/11 ssssss703
yes, I even ran neg all the way to the batt., and still grounded to the chasis in the trunk...
5 Black Cherries
Old 12-06-2011, 06:26 AM
0/11 sssssss21
Simply answer? Yep..
Here's a voltage drop calculator ---http://www.thecarpcstore.com/cms/index.php?option=com_content&view=article&id=47&It emid=63
When you have more than 1 run, simply half the wire distance everytime you double the amount of wire.. eg...1 run copper -15 ft... if you have 2- 15ft runs put in 7.5 ft.. 4 runs would be 3.75 etcetc.
Old 12-06-2011, 07:09 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
I have not seen anyone use dual inputs on an 1800 watt amp. It doesn't pull enough current to require it. And its not helping voltage drop as much as allowing more surface area for the current to travel thru.
If your getting anything over .5v drop you need to look at other things then adding dual inputs.
Old 12-06-2011, 07:27 AM
MERQUE's Avatar
0/11 ssssss622
well i was trying to plan ahead because i was planning on eventually getting another amp and strapping them
Old 12-06-2011, 07:34 AM
Ja Marcus
0/11 sssss6975
Even then your only around 300A divided between them. If your using 1/0 you should have no problems passing that current.
Old 12-06-2011, 07:42 AM
0/11 sssssss21
Gotta disagree.. regardless of how many amps your gear needs, the more area the current can travel through, the less drop there will be. Did you try using the calculator? Electricity is science..it works well
It's not about being "able" to pass the current, its about losing the least amount of it. More current at the gear, more power to the speakers..
The Following User Says Thank You to Soulmusic For This Useful Post:
05TRAILBLAZER (12-09-2011)
Old 12-06-2011, 08:20 AM
Prohibited Sellers/Buyers
0/11 sssss1285
I have dual 1/0 on each of my AP1500's. Not saying you are wrong that it might be over kill, but isn't that what Car Audio is all about... Overkill!!!
Voltage Drop 1-12-t1 General Car Audio Discussion & Questions 22 06-16-2011 09:47 AM
voltage drop help Xtremelegend General Car Audio Discussion & Questions 10 06-02-2011 11:45 PM
Voltage drop anyone? AMI CUSTOMS General Car Audio Discussion & Questions 14 03-11-2011 05:18 PM
Voltage drop?? king ranch General Car Audio Discussion & Questions 15 12-02-2009 07:01 PM
Voltage Drop gbo559 General Car Audio Discussion & Questions 31 07-26-2009 07:41 PM
