MTX 9500 MOTOR adapter plate. - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Vendors > (Tool Maker)
Old 03-05-2012, 09:12 PM
XORstatus's Avatar
0/11 ssssss552
Default MTX 9500 MOTOR adapter plate.
I have and MTX 9500 mortor with a 4 inch VC.
The mounting holes for the basket are extremely wide set and wont fit usual baskets.
The motor has a upper heat sink that sits on the top plate.
My thought is to remove this heat sink and replace it with a 1 (or so) inch ring that would be a direct replacement, that utilized the existing mounting holes.
This ring would have additional holes which would be used to mount standard baskets.
What do you think something like this would cost?
Would this even be possible?
Old 03-05-2012, 09:36 PM
Inferno333's Avatar
0/11 sssss3845
Feedback Score: 44 reviews
Do not loosen the bolts for the aluminum ring! It is bolted to another ring on the other side of the top plate.
Your best bet is to just get a ring to bolt around it with another bolt pattern.
Old 03-05-2012, 09:38 PM
0/11 sssss6075
I think ToolMaker just posted about being busy and not doing new orders. Don't mean to poach business but I could probably do it. He'd just charge considerably less.
bigdhenderson's Avatar
0/11 sssss4981
Feedback Score: 45 reviews
Old 03-05-2012, 09:41 PM
0/11 ssssss283
Its extremely easy to re attatch that ring.
Old 03-05-2012, 09:46 PM
Inferno333's Avatar
0/11 sssss3845
I'm just going by what Dave said about them.
Old 03-05-2012, 09:50 PM
XORstatus's Avatar
0/11 ssssss552
I understand if one removes two bolts from this heat sink then swivel this ring around.
reattach the two bolts to the under ring. then remove the last bolt.
THis method keep the bottom ring attached and in alignment.
Old 03-05-2012, 09:53 PM
0/11 sssss4981
have you found a basket yet? I'll consider selling my basket, adapter, and a badass cone for the right price...
Old 03-05-2012, 09:56 PM
XORstatus's Avatar
0/11 ssssss552
Ive found a 12 spoke basket shipped for 30 bucks.
Im trying to decide between a 12 spoke and a 6 spoke.
I understand that the 6 spoke allows for a larger spider, will this ONLY allow for greater xmax?
I need help deciding which basket would be best for my application.
What basket and adapter do you have?
Old 03-05-2012, 10:16 PM
0/11 sssss4981
Are you okay man? You really dont remember reading my thread or Pm'ing me several times?
Mtx 9500 motor Joshlongfellow Broken & Non-working equipment 1 01-04-2012 09:05 PM
mtx 9500 motor 4 inch vc lilsoccersully Broken & Non-working equipment 6 11-29-2011 01:24 PM
Wtb: mtx 9500 motor TheLow Wanting to Buy (WTB) 2 07-25-2011 05:30 PM
MTX 9500 motor bobbarker Speaker Accessories & Parts 24 06-27-2011 01:23 AM
mtx 9500 12 or motor Rd4me Wanting to Buy (WTB) 2 06-23-2010 12:22 PM
