What Terminal Post option to select on "6 - 1/0 ga Bolt On Battery Terminals"??? - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Vendors > (Tool Maker)
Old 08-22-2013, 03:18 PM
0/11 sssssss13
Default What Terminal Post option to select on "6 - 1/0 ga Bolt On Battery Terminals"???
I'm wanting to order two sets of Toolmaker 6 - 1/0 ga Bolt On Battery Terminal for a system I'm putting together...
The Batts I've ordered are one, XS Power D3400 w/551 IBar for the front and one, XS Power D5100 for the rear...
With the XS Batts, I also ordered 2 sets of the "580 Short Top Post Adapters", But I am not locked into using those,
If I'm going to order and use these nice Distribution Blocks/Battery Posts, I want to use whatever is going to give me the best connections...
The question I have is, Which way will connect to the batteries I mentioned best and What option should I select to order them
6mm-1/4"
3/8"
3/8" Threaded Stud
SAE Top Post
Thanks
Old 08-22-2013, 03:39 PM
1loudmonte's Avatar
Team Incriminator Audio
0/11 sssss2167
Feedback Score: 36 reviews
I ordered battery terminals from tool maker for a kinetic hc 2000 and I choose to go with the ones that bolt to the battery instead of the ones that slide over the post. To me this method provides a more solid connection. He should have ones for your battery that bolt as well. Hope this helps you.
(2015 MECA Street 3 World Champion)
2004 Dodge Ram Single Cab 1500
3 Incriminator Audio Judge 15s
3.25:1 Ratio 4th Order Blowthrough
1 x AA 9.0 TFHE, 2 x AA 150.4
4 X Crossfire XS-M8's, 2 x PRV Tweets
The Following User Says Thank You to 1loudmonte For This Useful Post:
smullen (08-22-2013)
Old 08-22-2013, 05:05 PM
0/11 sssssss13
Thanks; I think your right, but I'm just not sure which one of those options to pick...
Thats really what I was looking for...
6mm-1/4"
3/8"
3/8" Threaded Stud
SAE Top Post
Then if I order the blocks in one of the three option in Blue, what accessories do I need to order from XS power to bolt up to these
I want to get this all ordered as soon as possible, so I can get everything in and get on with the install... I'm dieing for some good beats...
Old 08-22-2013, 05:36 PM
0/11 sssssss13
6mm-1/4"
3/8"
3/8" Threaded Stud
SAE Top Post
Looks like those Posts I ordered come with M6 Bolts that I think will work, but not sure which of these for sure...
6mm-1/4"
3/8"
3/8" Threaded Stud
Sorry to Overcomplicate this... I want to make sure and get the right stuff the 1st time and avoid returning and exchanging a bunch of parts...
Old 08-22-2013, 05:48 PM
1loudmonte's Avatar
0/11 sssss2167
You would need to do the 6mm-1/4" option as your battery uses m6 hardware.
Old 08-22-2013, 06:23 PM
0/11 sssssss13
Right one... Thats what I was looking for...
Toolman,
If I order 2 pairs of these tonight, what kind of ETA am I looking at
Old 08-22-2013, 06:28 PM
0/11 sssssss13
That was supposed to say Right On!!! and Thanks too BTW...
I couldn't find the edit button from my stupid phone's browser...
Old 08-22-2013, 06:32 PM
1loudmonte's Avatar
0/11 sssss2167
IIRC he is backed up right now so it might take a little longer than normal to get them.
Old 08-23-2013, 02:13 AM
0/11 sssssss13
Hmmm, well, I went ahead and ordered my two pairs tonight...
We'll see how long they take...
After I gett'em and gett'em in, I'll get some pics up in the tread for posting pics of Toolmaker's goods...
Thanks again.
Scott
Old 08-24-2013, 06:32 AM
toolmaker's Avatar
Mstr of mtl
0/11 sssss2192
the least amount of connection points, connecting to the battery will give you the best performance.
E-mail -
Help select my "sq" front stage strpperpolef150 Sound Quality Area 35 07-22-2011 07:30 PM
Terminal/bolt size tacomaguy1 General Car Audio Discussion & Questions 10 05-25-2011 10:57 PM
wtt" Stinger battery terminal sleepingciv Car Audio Trader (WTT) 3 05-03-2011 10:00 PM
WTB: pair of 4" coil 15" baskets standard 5" 6 bolt pattern rachidfunaki Wanting to Buy (WTB) 0 10-10-2010 05:41 PM
12" 4" coil opening, tsns bolt pattern klown78 Wanting to Buy (WTB) 6 09-09-2010 07:05 PM
