6 1/0 gauge input longways Battery terminal - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Vendors > (Tool Maker) > Toolmaker Price Quote Section
Toolmaker Price Quote Section If you are looking for a quote from Toolmaker, request here. **Note: Toolmaker & Mods Can see new post/threads besides your own **
Old 03-01-2013, 02:47 AM
0/11 sssssss39
Default 6 1/0 gauge input longways Battery terminal
I plan on connecting 4 kinetik hc1800 together with 2in x .25in copper or aluminum bar from the hardware store. Would like to do bus bars with built in inputs but due to the placement of the batteries, the bar may require some flex due to the curvature of the boats hull. Hence the quarter inch thin 2 inch wide bar. Anyways I would like to have bat terminals with 6 1/0 gauge inputs and one 8 gauge input and obviously a hole for fasting to the battery with the bus bar between the battery and the terminal. I want the terminals to be long ways so all of the terminal will rest on the bus bar for maximum contact and all of my wires will come off the same direction. Need one for pos of for neg. What would something like this cost? Alum and copper price please. Also I want the wires to connect from the outter edge of the battery, not lie over top of the batteries. Do you see what Im trying to describe?
Thanks
Old 03-11-2013, 08:22 AM
0/11 sssssss39
Default Changed to XS Power XP2000
Toolmaker,
Ive actually changed my setup design and will be using 4 XS Power XP2000 and I will be needing bus bars for those. I dont have the batteries yet, but since they are pretty common, you may be able to go ahead and make the bus bars if you know how they will be spaced. I will need 6 1/0 gauge direct inputs and one 8 gauge direct input. Pricing for aluminum and copper please. PM me if you can do it without the exact bat dimensions and I'll get the spacing dimensions to you.
Thank you
Rockford Fosgate Battery Terminal 4 or 0 Gauge 07denali Wiring, Electrical & Other Installation Equipment 0 06-21-2012 02:13 PM
0 gauge, battery terminal, connector and more t.hybrid Wiring, Electrical & Other Installation Equipment 46 10-02-2011 11:17 AM
12 set screw input battery terminal block Wildbillpb Wiring, Electrical & Other Installation Equipment 10 05-02-2011 12:43 PM
8 gauge spade terminal edouble101 Wanting to Buy (WTB) 0 12-10-2010 04:07 AM
Triple 1/0 Gauge Battery Terminal... Patrick Simmons General Car Audio Discussion & Questions 9 11-11-2008 10:07 AM
