Front battery termination hub - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Vendors > (Tool Maker) > Toolmaker Price Quote Section
Toolmaker Price Quote Section If you are looking for a quote from Toolmaker, request here. **Note: Toolmaker & Mods Can see new post/threads besides your own **
Old 07-24-2015, 03:48 AM
0/11 ssssss276
Default Front battery termination hub
I've messaged you on Facebook about this as well so you can answer either one.
Need a front, enclosed, distrobution hub that will connect my front battery, alt, underhood fuse box, starter and include 3 2/0 outputs to link the front to rear battery. Inclued is the revised drawing. Not to scale but should give you an idea how the layout is and we can go from there.
Not to scale. This is the positive side only. Negative would only need to be one block with 3 2/0 Inputs to 3 2/0 outputs. This block would be mounted under the positive. Separated of course and concealed in one unit that can be mounted to a metal frame to hold this unit.
The middle section is one piece and there is no fuse on the fuse panel connection due to safety reasons.
no battery up front? Jeffhulbert50 General Car Audio Discussion & Questions 14 08-11-2013 12:48 PM
front battery vs rear battery thegr8cody General Car Audio Discussion & Questions 7 10-27-2012 07:44 PM
Battery Help up front vinniethedon General Car Audio Discussion & Questions 12 03-07-2012 03:07 PM
Wiring battery bank from alt or front battery burzendowski General Car Audio Discussion & Questions 9 02-15-2012 04:36 PM
What to use for front Battery Jager General Car Audio Discussion & Questions 7 05-02-2011 05:55 AM
