2005-08 gm trucks free higher alternator voltage charge - Car Audio Classifieds!
Old 10-06-2011, 02:25 AM
burzendowski's Avatar
0/11 sssss1736
Default 2005-08 gm trucks free higher alternator voltage charge
Found some interesting information on newer gm trucks. 2005-2008 gm half tons. Silverados tahoes escalades denalis. The alternator has a few modes of charging. A economy gas saving mode and a higher output voltage under tow modes. I monitored my voltage and found it drops into 12s and 13s after running for a minute or two. There's a voltage control module clamped around the negative post on my truck. I found a gm write up on how to bypass the voltage change. It's just turning the tow haul mode on. Here's the section from the forum I found it on.
Some owners may comment that when towing or hauling a camper/trailer that their auxiliary battery for the camper/trailer battery will not stay charged. In most cases, this concern is blamed on the new Regulated Voltage Control (RVC) system. While the new RVC system does reduce the generators targeted output voltage to 12.6-13.1 volts when in "Fuel Economy Mode", this feature is bypassed if the tow/haul feature is enabled. With the tow/haul feature enabled the system will stay in "Charge Mode" and the targeted generator output voltage will be 13.9-15.5 volts, depending on the battery state of charge and estimated battery temperature.
Recommendation/Instructions:
To correct this concern while towing or hauling a camper/trailer use the Tow/Haul feature.
Note: A second way to increase the generators targeted output voltage to 13.9-14.5 volt, is to turn on the headlights.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
Old 10-06-2011, 02:26 AM
0/11 sssss1736
Here's the link the the page I found the write up on
GM-Trucks.com Nbs - Battery And Volts (tsb?)
Old 10-06-2011, 09:24 AM
0/11 sssss1736
Wow no interest
Old 10-06-2011, 09:44 PM
Matt3824's Avatar
0/11 sssss3754
I'm gonna have to try that. Nice find.
Old 10-07-2011, 10:11 AM
0/11 sssss1736
no problem
Old 11-06-2011, 11:15 AM
0/11 sssssss85
I have some kind of fuse link BS on the positive side of my battery. I wonder if it's the same thing. Except I doubt it's for towing in an infiniti.
Lower nominal/higher voltage input Wood. General Car Audio Discussion & Questions 0 08-04-2011 03:43 PM
do i need higher output alternator? crandolph General Car Audio Discussion & Questions 2 07-26-2011 01:23 PM
Brand New 200 amp High Output Alternator for Chevy/ GM 5.7L Trucks and Cars jrod1050 Wiring, Electrical & Other Installation Equipment 17 05-10-2011 11:36 AM
New 2005 - 2007 Honda Civic alternator MECHMAN General Car Audio Discussion & Questions 0 08-16-2010 10:23 AM
Question about a 2005 Navigation/Expedition Alternator Njaykaplan General Car Audio Discussion & Questions 1 11-17-2009 01:30 PM
