Skar VVX 12D2 TSP's (post break-in) - Car Audio Classifieds!
Old 10-25-2011, 10:47 PM
Audio_phill's Avatar
Too Busy to be here
0/11 sssss2296
Feedback Score: 23 reviews
Unhappy Skar VVX 12D2 TSP's (post break-in)
Re = 4.0618 ohms
Fs = 25.8043 Hz
Zmax = 21.2971 ohms
Qes = 0.5991
Qms = 2.5421
Qts = 0.4848
Le = 5.2961 mH (at 1 kHz)
Diam = 250.8250 mm ( 9.8750 in )
Sd = .0494m^2 ( 76.5886 in^2)
Vas = 36.5438 L ( 1.2905 ft^3)
BL = 19.9220 N/A
Mms = 361.0511 g
Cms = 105.3626 uM/N
Kms = 9491.0313 N/M
Rms = 23.0275 R mechanical
Efficiency = 0.0985 %
Sensitivity= 81.9515 dB @1W/1m
Bought From: Funky Waves, Realbeach, Farmacist Louisiana_CRX, Lingerfelt, ciaonzo, SPY (X2), tristanmay, bigbassjoel, Sound_Around, Good Times
Sold To: alfabit1, Sound_Around, jonalford2087, woodels420, pangullo, chico305, ciaonzo, darkkon, faessle, UNDERGROUND_BUM, JCJR, adrian1185, fast306stang, tristanmay, biggen_bd, mwerling1212, HiloDB1, statonburrell
Traded With: HiloDB1, kn0wledge000, ciaonzo, tristanmay, Jh8909, fritosaregood
Old 10-25-2011, 11:15 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
Why the sad face man? Looks legit..Le?
Old 10-25-2011, 11:17 PM
Wingman0121's Avatar
0/11 sssss2171
Hummm the sensitivity could be higher, some subs are around 88dB or higher but most high-power subs are 86dB or below.
Old 10-25-2011, 11:18 PM
Novicaine's Avatar
0/11 sssss6135
It has a low fs though...The mms is 361gs.
0/11 sssss3526
specs out solid to me...i love mine
Team Flex Issues
Temp build
Jvf Custom ssx 12 on DSC 1500
Xs Power
Hertz/Image Dynamics
Old 10-25-2011, 11:45 PM
Too Busy to be here
0/11 sssss2296
It has the sensitivity of your standard 8... Qes is abnormally high so you'll def need more than rms power to get any usable output from it if you tune it for flat response. Def a sub to tune higher than optimum. If the sens was close to listed, it would be a very nice woofer, also, the surrounds are junk. a lil cold and they turn into lead.
The Following User Says Thank You to Audio_phill For This Useful Post:
1mtx1 (10-26-2011)
Old 10-25-2011, 11:53 PM
0/11 sssssss75
yes finally someone admits the surrounds are junk
Old 10-25-2011, 11:59 PM
luises14's Avatar
Loyal Member
0/11 sssss2531
Feedback Score: 30 reviews
The man knows his subs, thanks for the info.
Old 10-26-2011, 12:06 AM
0/11 sssss2171
Yeah those subs wouldn't work in the winter. I had a cheap Sony sub that wouldn't even move when it gets below 40 degrees, some kind of cheap rubber surround. Foam/cloth don't really have that problem but cloth is not for high excursion and foam will crack within 3 years of heavy use.
The tall rubber surround from TC Sounds seems to be the best IMO for now.
Old 10-26-2011, 11:01 AM
Too Busy to be here
0/11 sssss2296
nbr 1/2 roll from tc2K ftw, exceptionally linear and temp stable like no other, tall has non linear compliance throughout stroke
Tags
horrid surround, inefficient, jacob fuller, skar, sundown
Skar VVX-12 Homernuts 12" Subwoofers 16 09-30-2011 02:03 PM
FS: Skar VVX-12 DonH 12" Subwoofers 5 05-17-2011 08:04 PM
