Oxygen Audio Subwoofer TSP's - Car Audio Classifieds!
Old 11-05-2011, 10:02 PM
Audio_phill's Avatar
Too Busy to be here
0/11 sssss2296
Feedback Score: 23 reviews
Default Oxygen Audio Subwoofer TSP's
Alium 380
Re = 3.6002 ohms
Fs = 22.2340 Hz
Zmax = 35.7397 ohms
Qes = 0.4376
Qms = 3.9064
Qts = 0.3935
Le = 2.2365 mH (at 1 kHz)
Diam = 333.3750 mm ( 13.1250 in )
Sd =87288.2828 mm^2(135.2971 in^2)
Vas = 223.9086 L ( 7.9073 ft^3)
BL = 16.8728 N/A
Mms = 247.6916 g
Cms = 206.8685 uM/N
Kms = 4833.9897 N/M
Rms = 8.8580 R mechanical
Efficiency = 0.5285 %
Sensitivity= 89.2482 dB @1W/1m
Air 102 (parallel coils)
Re = 0.9817 ohms
Fs = 37.0458 Hz
Zmax = 20.0988 ohms
Qes = 0.4679
Qms = 9.1114
Qts = 0.4450
Le = 0.7331 mH (at 1 kHz)
Diam = 206.3750 mm ( 8.1250 in )
Sd =33450.6109 mm^2( 51.8486 in^2)
Vas = 18.4928 L ( 0.6531 ft^3)
BL = 8.8022 N/A
Mms = 158.6466 g
Cms = 116.3404 uM/N
Kms = 8595.4639 N/M
Rms = 4.0529 R mechanical
Efficiency = 0.1888 %
Sensitivity= 84.7784 dB @1W/1m
Air Pro SPL 15
4" fw al coil, 2K rms, amazing basket
Re = 4.2467 ohms
Fs = 37.0865 Hz
Zmax = 28.6673 ohms
Qes = 0.8730
Qms = 5.0202
Qts = 0.7437
Le = 1.7891 mH (at 1 kHz)
Diam = 317.5000 mm ( 12.5000 in )
Sd =79173.0434 mm^2(122.7185 in^2)
Vas = 40.5863 L ( 1.4333 ft^3)
BL = 21.4012 N/A
Mms = 404.0621 g
Cms = 45.5785 uM/N
Kms =21940.1875 N/M
Rms = 18.7552 R mechanical
Efficiency = 0.2228 %
Sensitivity= 85.4976 dB @1W/1m
Spiral 15 (junk)
Re = 3.4862 ohms
Fs = 33.6976 Hz
Zmax = 13.3690 ohms
Qes = 1.6761
Qms = 4.7516
Qts = 1.2391
Le = 2.7658 mH (at 1 kHz)
Diam = 314.1345 mm ( 12.3675 in )
Sd =77503.4726 mm^2(120.1306 in^2)
Vas = 45.4757 L ( 1.6060 ft^3)
BL = 13.5767 N/A
Mms = 418.5711 g
Cms = 53.2932 uM/N
Kms =18764.1074 N/M
Rms = 18.6512 R mechanical
Efficiency = 0.0975 %
Sensitivity= 81.9102 dB @1W/1m
will add more shortly
Bought From: Funky Waves, Realbeach, Farmacist Louisiana_CRX, Lingerfelt, ciaonzo, SPY (X2), tristanmay, bigbassjoel, Sound_Around, Good Times
Sold To: alfabit1, Sound_Around, jonalford2087, woodels420, pangullo, chico305, ciaonzo, darkkon, faessle, UNDERGROUND_BUM, JCJR, adrian1185, fast306stang, tristanmay, biggen_bd, mwerling1212, HiloDB1, statonburrell
Traded With: HiloDB1, kn0wledge000, ciaonzo, tristanmay, Jh8909, fritosaregood
Old 11-05-2011, 10:08 PM
Too Busy to be here
0/11 sssss2296
http://ecx.images-amazon.com/images/I/41Qc8bnz2ZL.jpg
Old 11-06-2011, 11:35 AM
my_stealth21's Avatar
TC WHORE
0/11 sssss2110
Aluminum 380 in 3.5 sealed for ear sex !!
Old 11-06-2011, 04:56 PM
Too Busy to be here
0/11 sssss2296
Old 11-06-2011, 04:57 PM
Too Busy to be here
0/11 sssss2296
Old 12-29-2011, 12:24 PM
oslouie's Avatar
0/11 sssss5073
Feedback Score: 69 reviews
That alium 380, is it just a single vc sub? How do you think it will do in 2.7 tuned to 34? I'm asking because I'm looking for a budget 15 and trying to use my old box.
Sent from my EVO 3D using Tapatalk
Old 12-29-2011, 01:19 PM
Too Busy to be here
0/11 sssss2296
Def sound like ass, thats less than recommend for sealed lol. 2.7 @ 34 isnt gonna work well with many 15's I have tested. You're gonna need a low Vas mid Q woofer with an fs 30-35Hz to be musical enough to not be ear fatiguing. A Low Fs Low Qts Medium Vas sub would prob work as well, Alium is S4 coils iirc Vented box for an alium would need to be about 8cu ft net @ 20-22Hz
Old 12-29-2011, 01:20 PM
Too Busy to be here
0/11 sssss2296
And contrary to SD belief, WinISD is a very good tool for comparing driver/box compatibility
oslouie's Avatar
0/11 sssss5073
Thanks
Old 11-14-2013, 05:00 PM
Too Busy to be here
0/11 sssss2296
Been seeing some interest in o2 popping up, thought this may help those not wanting to dig for it.
FS: oxygen audio bullet 8s big d Component & Coaxial Speakers 1 12-28-2010 08:27 PM
Oxygen o2 audio OA2200.2? nismos14 General Car Audio Discussion & Questions 2 11-08-2010 08:43 AM
O2 oxygen audio msand951 General Car Audio Discussion & Questions 22 05-16-2009 03:09 PM
Re: O2 Audio (Oxygen Audio) 2500w amps xpl Recycle Bin 0 08-15-2008 11:23 PM
