SW8200 TSP's / 64Bit WT2 vs Klippel Accuracy - Car Audio Classifieds!
Old 11-08-2011, 02:47 PM
Audio_phill's Avatar
Too Busy to be here
0/11 sssss2296
Feedback Score: 23 reviews
Default SW8200 TSP's / 64Bit WT2 vs Klippel Accuracy
I was lucky enough, thanks to diyma, to compare my work against a Klippel... Heres the results. Not the exact same driver, hence the lil differences.
Klippel results from a Eclipse SW8200 12" LMS driver. (supposedly tricky to pull lms tsp's accurately)
My results from Eclipse SW8200 12" LMS driver.
Re = 3.2856 ohms
Fs = 22.0150 Hz
Zmax = 23.5699 ohms
Qes = 0.9382
Qms = 5.7920
Qts = 0.8074
Le = 1.0685 mH (at 1 kHz)
Diam = 256.5400 mm ( 10.1000 in )
Sd =51689.2299 mm^2( 80.1185 in^2)
Vas = 87.1135 L ( 3.0764 ft^3)
BL = 10.5028 N/A
Mms = 227.7101 g
Cms = 229.5200 uM/N
Kms = 4356.9180 N/M
Rms = 5.4381 R mechanical
Efficiency = 0.0931 %
Sensitivity= 81.7071 dB @1W/1m
Bought From: Funky Waves, Realbeach, Farmacist Louisiana_CRX, Lingerfelt, ciaonzo, SPY (X2), tristanmay, bigbassjoel, Sound_Around, Good Times
Sold To: alfabit1, Sound_Around, jonalford2087, woodels420, pangullo, chico305, ciaonzo, darkkon, faessle, UNDERGROUND_BUM, JCJR, adrian1185, fast306stang, tristanmay, biggen_bd, mwerling1212, HiloDB1, statonburrell
Traded With: HiloDB1, kn0wledge000, ciaonzo, tristanmay, Jh8909, fritosaregood
The Following User Says Thank You to Audio_phill For This Useful Post:
my_stealth21 (11-08-2011)
Old 11-08-2011, 03:09 PM
SoCalBean420's Avatar
время решает все
0/11 sssss7110
Feedback Score: 42 reviews
wow, Phill. you have a text and hopefully you can help out
thank you, for sharing with us! hey post some more, Homie (plz)
“We can ignore reality, but we cannot ignore the consequences of ignoring reality.”
― Ayn Rand
Old 11-08-2011, 06:42 PM
my_stealth21's Avatar
TC WHORE
0/11 sssss2110
WT2 ftmfw
Old 11-11-2011, 01:03 AM
thumper21's Avatar
Blow-thru KING
0/11 sssss1919
is that with the woofer tester 2 system from woofertester.com?
And not the Dayton thingy for clarification
Speed and SQ
Old 11-22-2012, 07:17 PM
Too Busy to be here
0/11 sssss2296
woofertester.com
Tags
klippel, subwoofer, sundown, tc sounds
winisd vent mach accuracy. jt_buck Enclosure Discussion & Design Construction Help 68 06-08-2011 12:53 AM
Sundown SA-12 Klippel Test sundownz (Sundown Audio) 9 06-07-2011 06:22 PM
[SOLD] LNIB Eclipse SW8200 bumpin buick 12" Subwoofers 3 02-03-2011 09:01 PM
Eclipse SW8200 Recone? jaybee (Fix My Speaker) 10 07-18-2010 06:39 PM
