Adjustable idle for $1.99 - Car Audio Classifieds!
Old 11-18-2011, 04:26 AM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Default Adjustable idle for $1.99
The alt in my CRX literally makes zero at idle. I mean, the car runs on batt power only. So, I used to have to stuff something into the throttle to keep it open a bit to keep my rpms up and see some voltage/amperage. I saw some very successful competitors doing the same thing at a show (you know who you are Lol), so I thought I would share my little idea for anyone else who has to do that and needs those 1200 rpms that USACI caps idle at. I'm sure other orgs have similar restrictions too.
This is a "gang valve." I bought it at WalMart for $1.99. Apparently, it's for aquariums or some shit. I found a vacuum line on my intake manifold that, when you remove it, will send the rpms up. I cut that line, installed the valve and left that part of it wide open. The other side of the valve is open to the atmosphere and remains closed during normal operation. Anytime you need to adjust the idle, just open it up a bit until you get 1200rpms. Easy peasy. Took me like 2 minutes.
If you want to get really fancy, you could run the vac lines inside the vehicle and mount the valve (or a nice one) inside so you can adjust from the cabin and not even have to go under the hood.
Vid of it in action.
Adjustable idle for $1.99 - YouTube
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
art1618 (01-10-2012)
Old 11-18-2011, 05:04 AM
RE_XXX's Avatar
0/11 sssss3181
Thats a good idea!!!
Later model vehicles with TCMs and CPUs, you can buy a plug that adjusts your idle electronically or you can buy one of those power programmers that do it.
Amps- Crossfire XS-8X
Wire- 6 runs Stinger
Old 11-18-2011, 05:16 AM
0/11 ssssss133
you could also chip and tune an obd1 ecu
this will
  • allow you to set rpm max at 1200 on chip
  • allow you to turn off the eld
  • allow you to increase hp/tq
  • remove speed governor
use one chip for competing and one chip to drive the car, simple. The ELD is what can also restrict your alternator from performing at max load.
Old 11-18-2011, 05:30 AM
SacTownBully84's Avatar
0/11 sssss3682
Feedback Score: 51 reviews
So which one of these mods mentioned above will work on my 98 Taurus w a 3.0 24v dohc?... thanks.
98 Taurus
: CRESCENDO : AT : SKAR : MEMPHIS :
Skar zvx-15 d1
3cubes net @ 30hz
NENDO 3KWP @ .5 ohm
TEAM FUK YO COUCH
Old 11-19-2011, 04:15 PM
LEN671's Avatar
BASSHEAD from Guam!!
0/11 sssss1148
^^^^x2 on what he said. But on a 2000 Dodge Stratus ES 2.5L V6.
DC LVL5 12's
3 - KINETIK HC2400
1 XSPOWER XS7500
1 - ALPINE 9886
2/0ga. WIRE THROUGHOUT
Team DC Audio 2012
Old 11-19-2011, 07:42 PM
Wingman0121's Avatar
0/11 sssss2171
I'll just go buy a pet rock and tell him to sit on the gas pedal
The Following 3 Users Say Thank You to Wingman0121 For This Useful Post:
cgriffin224 (11-26-2011), djm4rshm2llow (01-02-2012), tony30cl (11-12-2013)
Old 11-19-2011, 08:05 PM
Active Member
0/11 ssssss846
Feedback Score: 23 reviews
Should/could patent this and sell them for 20 a pop. Little research and trial and error and this could be a hot item. Large profit margin would allow for ample advertising.
Old 11-19-2011, 09:50 PM
0/11 sssssss45
the easiest place to mount one of those on most cars is on the vaccuum line that goes into the brake booster. most cars have them on the driver side at the very back of the engine bay. its about a 3/4 inch hose that goes into the brake booster and it usually pulls right off, or has a hose clamp. MAKE SURE YOUR CAR IS IN PARK OR YOUR E-BRAKE IS SET BECAUSE YOUR BRAKES WONT WORK WITH THE VALVE OPEN OR THE HOSE DISCONNECTED.
Old 11-19-2011, 09:53 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
this will
That sound much more expensive, time consuming and annoying than a $1.99 valve.
I tried that, but feeding it became a hassle.
I like the way you think.
4x world champ
- Floyd E. Toole
Old 11-26-2011, 08:51 AM
0/11 ssssssss5
you really should put a filter on that.
when the valve is open you are sucking unfiltered air right into your motor, not the best thing to do.
Adjustable Voltage 1 Loud Explorer General Car Audio Discussion & Questions 3 07-11-2011 06:44 PM
up my idle? Nd_6037 General Automotive Chat 19 09-18-2010 09:19 PM
Adjustable Air Shocks??? SpeakerBox General Automotive Chat 13 02-18-2010 06:38 PM
