What makes a good battery? - Car Audio Classifieds!
Old 01-27-2012, 01:33 AM
0/11 sssssss47
Default What makes a good battery?
Alright so I'm looking to run a few big lead acid batteries to run my amp. I was wondering what info I should look for on a battery, like what makes the battery good for car audio? Does it have anything to do with cca? What about ah?
Old 01-27-2012, 01:35 AM
9515ROB's Avatar
0/11 sssss2057
yeah bud you want to run agm not acid batteries. If they are gonna be in your car then you deff dont want to run an acid battery unless you want to blow up or die from the fumes
Being loud is waste of money
880prs/Front-Hybrid Audio Technology Legatia L8 L3 L1v2 3-way/Sub- 3 blown MB Quart RLP-304 shallow mount 12s/Sub Amp- Visonik v2908/4ch- DD C4a
Still got a lot of stuff left to get
Old 01-27-2012, 01:46 AM
0/11 sssssss47
they wouldnt be in the cab but what would you suggest on agm's then?
0/11 ssssss855
^^^^ this if you run flooded cell batteries in your cabin they will release a chlorine type of gas and agm batteries are much stronger ..
Old 01-27-2012, 01:25 PM
0/11 sssssss47
So is anyone going to tell me what attributes of a battery make it better than another battery for car audio or am I just going to get peoples opinions on what I should get?
Old 01-27-2012, 01:35 PM
tacomaguy1's Avatar
0/11 sssss4401
An xs power label
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 01-27-2012, 01:36 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
For one your in the wrong section and two they do make a search function!
There are tons threads asking the same exact question with the info you want.
Old 01-27-2012, 01:58 PM
SpeakerBox's Avatar
*Project 160db @44-47hz*
0/11 sssss1684
Wow, way to welcome a new member. There's a ton of threads with the answers he's looking for so why should this one be any different? If there are tons then link him to one instead of being a smartass with no obvious help. Way to contribute your vast amount of knowledge on the FNG.
Anyways, if it were me and I was looking for some nice AGM batts that won't break the bank, I'd go with some used Deka's or some agm battery that has a decent aH rating. They can usually be had for a decent price and they'll hold up to some abuse. I'm no battery expert so I don't know what makes each one better than the other but if I had to guess I'd say there's a laundry list of things that some companies skimp on such as amount of lead inside the battery, the post pad size for better contact, the construction design, etc. I'm sure there's more but again, I'm no expert. Hope this helped you out a bit.
New Image Motoring
FatMat Sound Deadner
Singer Alts
No advertising images in sig
The Following User Says Thank You to SpeakerBox For This Useful Post:
JAYARE2007MAG (01-27-2012)
Old 01-27-2012, 06:15 PM
99Bonney's Avatar
0/11 sssss6246
Honestly I don't even look at specific specs. Run what's proven to do what you want them to do. Ask around and see what batteries others are running to get an idea. Good luck!
2006 Tahoe
Subs- 4 Crossfire xs v2 15s
Amps-Crossfire 8k
Batts- 6 xs 3100s, 2400
Alts- 3 Mechman SMD 340s
Old 01-27-2012, 06:19 PM
99Bonney's Avatar
0/11 sssss6246
Also, most of the actual specs your going to be looking for probably won't be posted. Most of them youd probably have to test for it yourself.
2006 Tahoe
Amps-Crossfire 8k
who makes good mids and highs that dont cost an arm and a leg like focal and hertz? SiPPiNOnSuMBuD Sound Quality Area 21 01-04-2012 11:00 PM
Good Battery Charger jrplayer36 General Car Audio Discussion & Questions 4 02-15-2011 09:24 PM
is this good for a battery?? mrbashful210 General Car Audio Discussion & Questions 7 04-21-2010 03:16 PM
What makes the IDMAX so good? hornedfrog1985 General Car Audio Discussion & Questions 19 04-14-2010 12:36 PM
who makes the good SQ stuff? urmarvin General Car Audio Discussion & Questions 8 06-04-2009 10:39 AM
