HELP!!! Stripped Screw - Car Audio Classifieds!
Old 02-10-2012, 08:04 PM
Kingdom of Solitude
0/11 sssss1254
Default HELP!!! Stripped Screw
I have to say this... Why dont Subwoofer manufacturers use hex bolt head screws when the connect the basket to the Motor.
Anyway, I have a HDC3 motor with two stripped screws that are becoming a pain in the arse. anyone have any ideas on how to get them out with house hold items and not misaligning my Pole Piece.
Thanks
Youtube Channel
Old 02-10-2012, 08:17 PM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
Try using a bigger head with an impact driver
Old 02-10-2012, 08:35 PM
Kingdom of Solitude
0/11 sssss1254
how to check whether or not your motor is misaligned
Youtube Channel
Old 02-10-2012, 08:39 PM
FatBoy2's Avatar
That was crafty.
0/11 sssss1790
Dill the head and use an easy out
Or you might can get a pair of vice grips on the head and back it out. Depends how much is grabbable.
Old 02-10-2012, 08:41 PM
kreapin's Avatar
threw the hood
0/11 ssssss894
Feedback Score: 17 reviews
i read was stripped screw and thought it said stripper screwed
I had to click
Old 02-10-2012, 08:55 PM
SUPER FAST SHIPPING
0/11 ssss31247
because they use the correct size bit and an impact driver as well as a bonding adhesive. {and because they would like you to buy another when the first one dies}
you can; find a 12 point socket which does not fit over the head but is close, then use a hammer and hammer that socket onto the screw until it either breaks or is flush to the surface behind.
then use a ratchet/breaker bar/whatever to loosen/remove the screw.
Old 02-10-2012, 09:01 PM
Kingdom of Solitude
0/11 sssss1254
I had to click
ayyy its friday go blow some 1$
in the words of K hart " You got it ball out"
Youtube Channel
Old 02-10-2012, 09:07 PM
Kingdom of Solitude
0/11 sssss1254
Got them out the hard way. I used a 5/32" bit to drill the screw and break the head at which point the basket came off then I used some regular pliers to take out the screw shaft. not to mention it was a ***** to do since the pliers want to do one thing and one thing along and that is stick to the top plate or pole piece.
However i do need something that will clamp down on a at least 2 thread or so the pliers are not getting enough grip to countersink the screw. any ideas.
I also though I misaligned my motor but realized it is just super effin dirty from the 2-4 winds of copper inside and some metal from the screw stripping.
Any idea on how to get those 2-4 strands of copper out of the gap?
I immediately thought tweezers but they are to wide and metal to say the least.
Youtube Channel
Old 02-10-2012, 09:08 PM
Kingdom of Solitude
0/11 sssss1254
if you guys want some pics let me know i can upload some !
Youtube Channel
Old 02-10-2012, 09:12 PM
SUPER FAST SHIPPING
0/11 ssss31247
chop stix
Tags
basket screws, stripped screw, subwoofer motor basket connection
stripped sub output screw... now what swong46 General Car Audio Discussion & Questions 6 11-14-2010 06:46 PM
Stripped Screws on sub.. RidinSwangaz General Car Audio Discussion & Questions 5 09-21-2010 08:29 PM
stripped screws? Dunbar91 General Car Audio Discussion & Questions 5 08-19-2010 09:23 PM
Stripped screw removal tips? tez4life General Car Audio Discussion & Questions 10 04-28-2010 09:38 AM
I just stripped my wire and... pyromanaic414 General Car Audio Discussion & Questions 17 01-22-2010 07:52 PM
