HowTo: Wire Multiple Batteries - Car Audio Classifieds!
Old 02-20-2012, 01:17 PM
lxl r00k lxl's Avatar
0/11 ssssss268
Default HowTo: Wire Multiple Batteries
Searched the entire Car Audio Help & Discussion section here at CACO.
I only saw one thread on "wiring" batteries. So i was wondering if any-
one could do a "Howto" with pics and "needed" things. Cause i know i
can't just run 0 gauge wire from alt to batteries and then to amps. How
many fuses do i need? How many runs of 0 gauge? Where do the fuses
go? Whats the best lengths for best results? Difference between series
and parallel? Just an idea...and one i need within the next 2 to 3 days lol
r00k
Old 02-20-2012, 01:25 PM
0/11 sssss8594
Feedback Score: 55 reviews
ok, starters, DO NOT SERIES BATTERIES...u will get 24v...u dont want 24v unless ur running a stetsom amp..lol...
ur gonna need at least one run of 1/0...ive always done from starter batt to back, first battery, then parallel to the second battery, etc, then to the amp...ground wire is the same, but also ground the batteries to the frame in the back...fuse 8" away from each battery, before and after...if u keep ur batts in the back close enough, with nothing to get them cut or anything, u dont need to fuse...in reality, u never need to fuse but why take the chance over a $8 piece...keep your wire lengths as short as possible too...less current loss in shorter distances
Enclosures
Old 02-20-2012, 01:27 PM
jmelton86's Avatar
Something clever.
0/11 ssssss626
You need fuses that are rated for no more than the current rating of the wire being used.
Every positive run should be fused at *each battery.
Usually you wire from the alt to the front battery to the rear battery(ies), but it depends on specific applications.
As many runs as you can afford (basically LoL).
CDA-9855 PDX4.100 GTO14001
Tuning low is great.
KeepItSimpleStupid
Old 02-20-2012, 01:30 PM
gti1.8t's Avatar
0/11 ssssss361
what if you're running multiple batteries? Whats the best way to hook them up? I will be running 2 4 channels & 1 mono
Old 02-20-2012, 01:32 PM
0/11 sssss8594
exactly how i posted above....just run power/ground from the back batts to each amp...PERSONALLY, ive always done a seperate run of 1/0 for my mids and highs amps, coming from my starter battery...if u cant afford to do that, just taking from the back batts works just as well
Enclosures
Old 02-20-2012, 01:36 PM
gti1.8t's Avatar
0/11 ssssss361
I have 2 4 channels, & 1 5500 (2 pos/2 neg)...
would i justt take a positive/negative from 1 battery & split to each 4 channel via 0g. --> 4g splitter? & for the 5500, take both pos & both negs, from the other battery?
Old 02-20-2012, 01:41 PM
0/11 sssss8594
well ur gonna need more than one battery feeding that 5500...what i would do is take one 4ch and 1 pos/neg to one batt and do the same to the other...so ur getting the same current draw from each battery
Enclosures
0/11 ssssss268
Ok...this is a rough sketch but... correct or incorrect?
Old 02-20-2012, 01:43 PM
gti1.8t's Avatar
0/11 ssssss361
nice sketch :P
And as for the 5500, should I get side pos/neg from 1 battery & 1 pos/neg from the other battery?
Old 02-20-2012, 01:44 PM
0/11 sssss8594
^^^go to the amp from battery 3 only...the current capacity COULD be different from batt 2 and 3...likely minimal, but still...and add a negative run from ur starter battery back to the accessory batts
Enclosures
The Following User Says Thank You to fyerbyrd22 For This Useful Post:
05TRAILBLAZER (02-20-2012)
Wiring multiple batteries mrtopnotch561 General Car Audio Discussion & Questions 11 09-09-2011 01:12 AM
wiring multiple batteries mrtopnotch561 General Car Audio Discussion & Questions 2 06-16-2011 12:57 PM
WTB multiple batteries. chunt33 Wanting to Buy (WTB) 0 04-26-2011 09:46 PM
purpose of multiple runs of wire? poundstone General Car Audio Discussion & Questions 36 01-25-2011 11:30 PM
How many watts (RMS) and How to wire multiple 8 ohm speakers? siviog1 General Car Audio Discussion & Questions 5 11-29-2010 06:20 PM
