help using DSO nano o-scope - Car Audio Classifieds!
Old 02-23-2012, 04:30 PM
beatnbronco's Avatar
0/11 sssss2284
Default help using DSO nano o-scope
can someone help me?? i bought a dso nano 201 and so far it's a paper weight. i connected it to the speaker outputs and followed the instructions on a few youtube vids but i don't get it. for instance..i the vid the guy says "with bass turned off"..does that mean with the amp turned off, gain all the way down, or is there some feature on the o-scope i don't see where i can turn the bass off from the o-scope? i've tried to change the wavelength but all it is is a scribbly line across the screen and all it does is stretch into a long scribbly line or short scribbly line..i need to get a rounded end wavelength on this thing..does someone know a link with step by step instructions on how to use it? this is the one i have. i will keep searching for instructions till i figure this out. thanks
Old 02-23-2012, 06:33 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Feedback Score: 67 reviews
Don't make it so complicated. Turn all the processing off or set to "flat" on your HU and/or EQ. It's basically just like doing it with a DMM. Volume at 3/4.
Disconnect the sub and hook the probe to the positive and the little ground to the negative and adjust the X and Y axes (left/right and up/down on the "D" pad) until you see your wave. Adjust the gain unitl you get the wave you want.
What size amp are you trying to set?
4x world champ
4x world record holder
Welcome to the world of SPL.
- Floyd E. Toole
Old 02-23-2012, 09:42 PM
0/11 sssss2284
sounds easy!! i'm trying to set an optidrive 6000d. i have an epic 160 but i had the enhancer turned off. so i need to set the high, mid, and low on my HU to 0? should i turn off the loudness and turn down the SLA? what about the bass boost and other adjustments on the amp? those affect the output too don't they? could clipped signals be causing my subs to smell nasty? sorry so many questions bro but i'm learning. i'm upgrading the firmware right now too...
Old 02-23-2012, 09:46 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
Yeah, turn everything to zero or flat. No boost or loudness or anything.
Do you have the 10x probe for it? The little nano with the 1x probe is really only good for ~ 3k, unfortunately. You may not get a good reading because you'll be maxing it out.
4x world champ
- Floyd E. Toole
Old 02-23-2012, 09:53 PM
Ajax_6154's Avatar
i want more bigger db's
0/11 sssss2369
mine has the 1x couldnt use it on my bc3500, but worked great on my 1000c4
Vehicle: 2011 VW GTI Autobahn
Deadning: 50sq ft of AT 60, Front Stage: CCX65 on a 1000c4, Sub: Eminent Audio EA1000 10's in 4.9ft3 at 35hz on a BC3500d at 1ohm
i dont like 12's they cant hit the lows like 10's
Old 02-23-2012, 10:23 PM
0/11 sssss2284
the probe has a 1x and 10x switch on it..it's on 10x now. what about bass boost, subsonic boost and all that other stuff on the amp?
Old 02-23-2012, 10:31 PM
TaylorFade's Avatar
SPL Retard
0/11 ssss12327
You use bass boost on your amp? Naughty. Turn it off. And leave it off. Forever.
Subsonic and all the other "filters" are fine. Unless you have your LPF set at 50hz.
The thing with turning processing off is that you want the cleanest signal you can get and testing with a 50hz tone, all of that B.S. will alter the signal.
4x world champ
- Floyd E. Toole
Old 02-23-2012, 10:46 PM
0/11 sssss2284
sorry(slaps himself on the hand), no bass boost from now on. i'll give it a go through tomorrow morn. i always wait till late in the day when i ask questions, i need to stop that. i have to test my mla module tomorrow too, my voltage is the same with and without it when it worked awesome when i first bought it...a month ago!! thanks guys, i'll post results when i'm done
Old 02-24-2012, 02:59 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
From what I understand the V201 is only good for 80VPP.
Old 02-24-2012, 03:24 PM
0/11 sssss2284
when i figure out what that is i'll be able to reply with something more intelligent
ARM DSO Nano O-scope 06GTMIKE Wiring, Electrical & Other Installation Equipment 6 02-03-2012 05:31 PM
DSO NANO question HELP Ajax_6154 General Car Audio Discussion & Questions 2 10-20-2011 09:18 PM
ipod nano pokerchip11 Wanting to Buy (WTB) 2 03-16-2011 04:17 AM
wtt n3 nano sleepingciv Car Audio Trader (WTT) 9 02-19-2011 07:11 PM
o scope sheldonfromltown General Car Audio Discussion & Questions 4 05-21-2010 06:16 PM
