voltage regulator - Car Audio Classifieds!
Old 03-31-2012, 10:42 PM
0/11 ssssss133
Default voltage regulator
anyone got any guidance in hooking up one of these blue box voltage regulators from mechman
pics would be awesome.
Old 04-01-2012, 12:36 PM
0/11 ssssss133
Default audioarsonal's videos
Originally Posted by audioarsonal View Post
Last edited by iamsonic; 06-04-2012 at 10:36 PM. Reason: adding audioarsonal's videos
Old 04-01-2012, 12:51 PM
treylittlefield's Avatar
0/11 sssss5201
Feedback Score: 37 reviews
what you need help on? just hooking it up?
2000 2dr Blazer
Old 04-01-2012, 01:01 PM
0/11 ssssss766
ground, power , feed. adjust voltage. done
05 ford f-160
4 18'' dc audio level 6
2 dc 9.0ks
singer 400a
@44hz
Old 04-01-2012, 01:28 PM
0/11 ssssss133
yeah.
Old 06-01-2012, 10:19 PM
bigdhenderson's Avatar
0/11 sssss4981
Feedback Score: 45 reviews
would also be interested in a tutorial on this. Doesnt a relay have to get wired in as well?
Old 06-01-2012, 10:33 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
Ill make one up this weekend.
Old 06-02-2012, 08:09 PM
0/11 sssss4981
Also would like to know if theres any differences in wiring if you are running two seperate c charging systems. I tried google searching this but came up with nothing helpful
Old 06-02-2012, 08:37 PM
BudgetBass's Avatar
0/11 sssss1366
I'm curious too. I know nothing about regulators as I've never had to hook one up. Can you hook them up to any alt or do they have plugs just for external regulators?
Sent from my Huawei-U8652 using Tapatalk 2
Under Construction
The Purple Astro
8 OA 18's
Hifonics Sampson
300A EA alternator 9 batts
Old 06-02-2012, 08:47 PM
psychoacoustics's Avatar
Veteran Member
0/11 sssss3830
Feedback Score: 50 reviews
yea if you have 2 different charging systems its different
but the field wire goes to the alternator
the batt + goes to the battery that the alt will be charging
and then ground it
a relay isnt necessary but cant hurt
any wire should work fine speaker wire is completely adequate keep the box close to the alternator
The Following User Says Thank You to psychoacoustics For This Useful Post:
bigdhenderson (06-02-2012)
voltage regulator. murderedtahoe General Car Audio Discussion & Questions 1 06-30-2011 06:07 AM
External voltage regulator Audioatg Wiring, Electrical & Other Installation Equipment 3 11-18-2010 07:41 AM
Iraggi Voltage Regulator TurboFox General Car Audio Discussion & Questions 0 05-29-2009 03:03 AM
external voltage regulator help Slam General Car Audio Discussion & Questions 1 10-23-2008 10:46 AM
