removing bose from 2003 tahoe - Car Audio Classifieds!
Old 07-06-2012, 01:52 PM
rmaravetz's Avatar
0/11 sssss1013
Default removing bose from 2003 tahoe
i am wondering if there is a way to eliminate the factory bose in my tahoe without having to run wires to every door for the speakers and all that i know the bose amp puts out strange ohm readings so it kinda works well within its own stuff.
any help would be awesome thinks in advance
Old 07-06-2012, 02:01 PM
jwright0291's Avatar
Big Ballin
0/11 sssss1468
Feedback Score: 23 reviews
Good luck, i gave up on my 05 Sierra, bose shit it tricky.
Old 07-06-2012, 02:30 PM
rmaravetz's Avatar
0/11 sssss1013
The only thing I know of is to run wires to all the locations and run off of aftermarket amps and have the adaptor for the dash
Old 07-09-2012, 07:06 AM
0/11 sssss1898
Running new wires is your best bet.
2002 suburban
Security System
Code alarm
Electrical
Dc power sp270 7 deka 9A31's and lots of 1/0
Headunit
pioneer 880prs
Amps
Sax125.2 front stage 2 Saz-4500's [email protected] 1 ohm
Wiring
lots of 1/0 stinger, tsunami
Mids & Tweeters
Dd w6.5 mids and lanzar opti crossovers and tweets
Subs
4-18" nightshade v2's d2
System Details
Daily driver.
Old 07-09-2012, 08:01 AM
0/11 sssss2429
Feedback Score: 46 reviews
Find the amp, all the input and outputs are there. Cut the connector if you never plan on putting it back and solder the correct wires together. I just did this for a 06 seirra with a Bose system.
The amp was in the center console.
<<sent from your blown amp>>
Old 11-03-2012, 12:28 AM
rmaravetz's Avatar
0/11 sssss1013
I plan on using it again I am trying to do everything so I can put it all back to stock if need be
Old 11-04-2012, 09:21 PM
Blackone1125's Avatar
0/11 ssssss107
Piggybacking off what brandes.cm posted, you will have to find the factory amp and bypass the amp's speaker level inputs/outputs. Give yourself enough room when you clip the wires to be able to reconnect later on. I just did one in my cousin's '01 tahoe and his was located in the passenger floor board close to the underside of the dash. This will allow the power to jump from your source to the speakers without being blocked by the factory amp. I did it in my Acura Legend years ago without any problems, too. Should you decide to convert back to the factory amp later on, just reconnect to the factory plugs on either side of the bose amp that were left over, plug in the factory deck, and you're on your way. Hope this helps.
1998 BMW 540i
Headunit: Stock DSP; Hifonics MX-1
Front Stage: Cerwin Vega 5.25's
Rear Stage: OEM 5.25's
Sub: RE Audio SX 10.4
Amps: Rockford 400.4 & bd1000
Old 11-04-2012, 09:26 PM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
running wires is faster and less hassle then having to take out your console.
I can have the entire interior stripped in about 15 mins. then its just getting the wires through the boot, just used a long needle nose and pushed it through,
Old 11-05-2012, 03:11 PM
tntahoe's Avatar
0/11 sssss1196
Yes you can the speaker wires run under the center console, so you can cut the wires there and then run your amp wires to those, not hard at all just need to find a wiring schematic
2003 Tahoe Build - w/ 3rd row - need ideas PJtoy2 General Car Audio Discussion & Questions 0 12-09-2011 12:49 PM
Want H.O. Alternator for 2003 Tahoe 5.3 PJtoy2 Wanting to Buy (WTB) 7 10-07-2011 11:26 PM
2003 Chevy Tahoe 5.3L tntahoe General Car Audio Discussion & Questions 20 12-10-2010 07:41 PM
2003 Tahoe for $3750???????? Snwbrdr1 General Automotive Chat 28 06-13-2010 01:16 PM
How to: Integrate Nissan Bose and Non Bose with aftermarket equipment. nismos14 Tutorials & Quick References 0 10-16-2008 09:51 AM
