Measuring Power - Car Audio Classifieds!
Old 07-10-2009, 12:43 AM
SUPER FAST SHIPPING
0/11 ssss31247
Default Measuring Power
Measuring Power
Power Consumption is Direct Current “DC”
Audio Output is Alternating Current “AC”
The same calculations work for both DC and AC power measurement but you have to keep the units consistent!
Using DC readings in an AC calculation does not work and will be completely inaccurate.
Measure the power you are using by taking DC amp and DC volt readings on the power lead and using calculations to figure out watts used.
Measure the power you are producing by taking AC amp and AC volt readings on the speaker leads and using calculations to figure out watts produced.
Both calculations result in Watts
Efficiency is measured in percentage
You can calculate your amplifiers percentage of efficiency by dividing the total watts produced by the total watts used.
Amps times Volts equals Watts
I * E = P
Example: 100 DC amps * 14.4 DC volts = 1440 watts
Example: 13.58 AC amps * 53.0 AC volts = 720 watts
Watts produced divided by Watts consumed equals the decimal equivalent to the percentage of efficiency.
Example: 720 watts / 1440 watts = 0.50 = 50% efficiency
Terms and the corresponding letters used for abberviation in calculation:
I Amperes
E Voltage
P Power
R Resistance
enough power? blkmrideon22s General Car Audio Discussion & Questions 2 06-20-2009 03:52 AM
Rep and Rep Power BlackWaterOp Announcements - Suggestions - Feedback - Support 48 06-15-2009 06:48 AM
Mod Power RidnClean Off Topic Chat 48 11-04-2008 02:20 PM
How to become a CACO Power Seller in the Power Seller Program Patrick Simmons CarAudioClassifieds' Power Seller Program 152 10-20-2008 11:56 AM
How To: Measuring your amps efficiency SPL Guru Tutorials & Quick References 2 10-20-2008 10:59 AM
