Digital Designs toolbox free - Car Audio Classifieds!
Old 05-01-2013, 10:17 AM
0/11 sssss2649
Default Digital Designs toolbox free
Got this in my DD Audio's May newsletter. Thought some of you guys might find this useful. It's a free App
DD Tool Box App - YouTube
DD Toolbox iOS App
The DD Toolbox iOS app is officially available for download via iTunes. Inside the toolbox you'll find several useful tools for setting up and analyzing your DD car audio system. Since installers have a lot going on while setting up a system, we designed the DD Toolbox layout to be installer friendly. We made the tool icons extra large, and you're able to easily swipe between tools. The tools included are a Wattage Calculator, Tone Generator, DD Box calculator, About DD page, and to round it out we included a flashlight. A cool DD Toolbox feature not found on other apps, is the ability to use multiple tools at once. For instance, you can use the Tone Generator while punching numbers into the Wattage Calculator, all the while illuminating your trunk with the flashlight. The DD Toolbox is a free download. Future updates will include a paid version with additional tools and an Android compatible version.
Here's a quick rundown of the included tools:
Wattage Calculator: This tool uses Ohm's law to determine the actual amplifier wattage output and impedance rise of your system. You can use this function to construct a power/impedance cure which will help optimize your system.
Tone Generator: This tool is able to generate any tone for 20Hz-20kHz. You can use the slider or keypad to adjust the frequency. This tool can be used in conjunction with the Wattage Calculator to construct your power/impedance curve.
DD Box Calculator: DD woofers and The DD Box system were developed together to extract the highest efficiency from a given box volume. The DD Box system takes the guesswork out of enclosure design by optimizing the tuning, and making woofer recommendations for your music and enclosure space.
Flashlight: Believe it or not this tool gives you the ability to see in the dark. What's even cooler is you can toggle it on/off from every page of the app.
The Following 2 Users Say Thank You to Eocuph For This Useful Post:
512Rodeo91 (05-01-2013), legend654 (05-02-2013)
Old 05-01-2013, 10:41 AM
bigdhenderson's Avatar
0/11 sssss4981
Feedback Score: 45 reviews
F Iphone
it makes since that if u add an alternator it will add resistants make your MPG go down but i dont see how turning up your volume adds more resistants.
SENSE RESISTANCE
Perhaps a mod could change it to "Massivespfail"?
The Following 8 Users Say Thank You to bigdhenderson For This Useful Post:
blkmrideon22s (05-07-2013), cgriffin224 (05-16-2013), Eocuph (05-01-2013), fireitup (05-01-2013), legend654 (05-02-2013), n8skow (05-07-2013), Ryan1126 (05-01-2013), Spena (05-01-2013)
Old 05-01-2013, 10:43 AM
fireitup's Avatar
0/11 ssssss616
Feedback Score: 31 reviews
Originally Posted by bigdhenderson View Post
F Iphone
^^ This
Old 05-01-2013, 10:51 AM
0/11 sssss2649
They will have one for Android too.
Old 05-01-2013, 02:57 PM
0/11 ssssss546
Wait, what?
Old 05-03-2013, 11:29 PM
512Rodeo91's Avatar
Vindaloo'd Smeg Head
0/11 ssssss319
I downloaded and tested it out a little bit, its cool for free.
I like the tone generator it is nice and the signal is cleaner then
some of the other free iPhone tone generators but I wish someone would
put a -3,-5,-10,-15 db adjustment for the generator.
However when clamping an amplifier and calculating wattage you have to take into account phase compensation. Would be nice if it had a spot for the percent of phase compensation. They could make it an option so when you enter a number it applies it to the overall equation and when left blank it skips it.
It seems the programing is using the equations:
Volts x Amps = Watts
Volts / Amps = Rise
So rise is fine as long as the person used an Oscope to make sure they were not clipping when taking VAC AAC readings.
But the Watts good be off by a good bit in some cases.
Why do the work yourself when others can do it for you?
You're the JP of forum searching.
Build Log 8-12s
The Following User Says Thank You to 512Rodeo91 For This Useful Post:
Eocuph (05-03-2013)
Old 05-03-2013, 11:34 PM
qopiyu's Avatar
0/11 ssssss531
Looking forward to the Android version.
Old 05-07-2013, 05:15 PM
n8skow's Avatar
0/11 sssss1519
Even if there is no clipping, voltage and amperage will not be in perfect phase.
You'd need to be able to take a snapshot of both at the same time or know the phase angle difference between them to calculate true wattage, but I digress, you covered the gist of it.
Volts / Amps = Rise
National Finals - Oct. 29th & 30th, 2016 in Sedalia, MO
Old 05-07-2013, 05:43 PM
512Rodeo91's Avatar
0/11 ssssss319
Yes I have been schooled since that post and the proper term would be:
It needs an option to apply the "power factor" in watts calculator. I would pay $0.99 for the app if it did that and the addition of the above mentioned DB adjustment to the tone generator part.
n8skow can you tell me if you can do it with two separate O-scopes and over lay the charts to get time of separation or do you have to do it on the same O-scope. I have an old fluke 92b and cannot find the clamp accessory for it, so I was gonna buy a O-scope that comes with clamp and lay the graphs over each other basically to find the time difference in phase. will this work if I properly Line the graphs up and they are on the same scale of coarse.
Build Log 8-12s
Old 05-07-2013, 05:51 PM
n8skow's Avatar
0/11 sssss1519
Simplest way would be with a dual-trace O-scope (though not the cheapest solution).
I would 'think' there would be some slight accuracy issues using two separate scopes depending on their accuracy/calibration - though that's beyond my range of experience... Perhaps someone else here can chime in?
Free box designs extremechevyman67 Enclosure Discussion & Design Construction Help 74 07-03-2018 04:18 PM
FS/FT Matco toolbox and tools loudwhat? Miscellaneous Stuff For Sale 4 08-14-2012 09:00 PM
Free Box Designs Ryan1126 Enclosure Discussion & Design Construction Help 91 10-02-2011 04:54 PM
[SOLD]Digital Designs 9500G Motor (Free Shipping) Omg Itz Layz Speaker Accessories & Parts 6 03-20-2011 11:50 PM
The Audio Toolbox Terrasonde 20Hz_And_Below General Car Audio Discussion & Questions 0 03-03-2011 01:24 AM
