Blowthrough: tips, tricks and pics blow through - Car Audio Classifieds!
Old 01-16-2013, 07:27 PM
0/11 sssss1184
Default Blowthrough: tips, tricks and pics blow through
For my next build, I want to do a blowthrough, just not sure where to start.
Any help would be appreciated.
I have a 97 s10 single
Saz 3500
Either dc xl 15 or 2 Aq hdc3 15s
Boughten from:
Jäger, $lick Califa$, it's a Jeep Thing, Bsteinb, vitveet, Slamminhos, Jbizzle, Loganberry, Itru50racer690
Old 01-16-2013, 07:43 PM
bigdhenderson's Avatar
0/11 sssss4981
Feedback Score: 45 reviews
get to cuttin'!!!!
it makes since that if u add an alternator it will add resistants make your MPG go down but i dont see how turning up your volume adds more resistants.
SENSE RESISTANCE
Perhaps a mod could change it to "Massivespfail"?
Old 01-17-2013, 12:12 AM
Wood.'s Avatar
Morning Wood.
0/11 ssssss331
my old tacoma
Wood's lowered Mini-truck cutthrough.
ask anything you need. getting ready to do another blowthrough in my 99 s10. 3500 and 2 15s also... 4th order.
The Following User Says Thank You to Wood. For This Useful Post:
2f150 (11-23-2013)
Old 01-17-2013, 12:22 AM
Radioactiv's Avatar
0/11 sssss1311
Don't do this...
Ranger Build
Old 01-17-2013, 12:35 AM
SUPER FAST SHIPPING
1/11 ssss31247
what wood did replacing the front wall of the bed is optimal but not necessary.
here's my tips;
make sure to round the corners of your cut. using a 3" hole-saw in the corners works well. {drills are consumables}
check the bed side of the blowthrough's bottom clearance before cutting.
check the cab side of the blowthrough's top clearance before cutting.
I use Harbor freight - High Speed Metal Saw - 'body saw'
I shorten the blades about 3/4" and they don't bend as easy.
the blades do not stay in the middle of the guide. just pick a side of the guide and let the blade ride against it.. then you'll be able to cut a straight line.
Accordion Boot Rubber Material Replacement Order by Feet
2f150 (11-23-2013)
Old 01-17-2013, 01:35 AM
Wood.'s Avatar
Morning Wood.
0/11 ssssss331
here's my tips;
nailed it. i only replaced that front piece because it just simply unbolted. when i took the blowthrough out i just put the old piece back in. very convenient...
depending on the tools you have access too is going to decide a lot. i have a welder/plasma cutter so it was fairly simple for me. i have heard of people just using cutoff wheels.
rounding the corners is crucial. join the boot on the bottom. i am getting a bed cover this time around. glassing and sealing the box to the bed was a pain. it leaked at first but got it sealed up finally.
Old 01-17-2013, 08:03 AM
treylittlefield's Avatar
0/11 sssss5201
Feedback Score: 37 reviews
Cut the bed before you cut cut the cab, the cab sits lower than the bed.
I've done 2 blowthroughs in a s10, both with 12s. 15s is gonna be hard with Te height. If you slant them it won't be to bad. If you have any questions feel free to pm me.
Also, the cab vent is right in the way, so best thing is to take out the vent and cut a piece of metal and epoxy it in place.
2000 2dr Blazer
The Following User Says Thank You to treylittlefield For This Useful Post:
2f150 (11-23-2013)
Old 01-17-2013, 01:06 PM
0/11 ssssss767
I remember a build log for this, do you have a link?
Old 01-17-2013, 01:24 PM
sherrod833's Avatar
0/11 ssssss602
Feedback Score: 21 reviews
Originally Posted by Radioactiv View Post
Don't do this...
That's almost unbelievable
Old 01-17-2013, 03:20 PM
0/11 sssss5201
Search my topics, if you know how to. Lol view my profile, then click on one of the tabs and its says view started threads
2000 2dr Blazer
Blowthrough: tips, tricks and pics blow through JuggaloRoso General Car Audio Discussion & Questions 39 06-14-2017 06:57 AM
Pics Blow throughs tylork92 Enclosure Discussion & Design Construction Help 0 12-25-2012 11:40 PM
Doing a silverado cut / blow through need pics please!! burzendowski General Car Audio Discussion & Questions 7 12-07-2010 11:17 AM
Help With SPL Tips and Tricks coddehart General Car Audio Discussion & Questions 22 09-02-2010 05:53 PM
Box tips and tricks... RetroAudioInc Enclosure Discussion & Design Construction Help 5 12-10-2009 10:44 PM
