Coil Placement for Underhung Explained - Car Audio Classifieds!
Old 11-17-2013, 02:20 PM
0/11 sssss4511
Feedback Score: 52 reviews
Default Coil Placement for Underhung Explained
After a good deal of looking around and asking questions on where to set the coil in the gap for a underhung build I decided to make something for those who actually search.
You take the Top plate height and subtract the coil height and then divide by two. That is how far down your coil sits in the gap.
2" top plate height, 1.5"ww
2"-1.5"=.5"
.5"/2=.25"
The coil would sit .25" below the top plate.
Thanks to Jacob and Shane for helping me out with guidance.
its not always about cone area people, dont forget to determine the displacement of comparing multiple sub setups.
sd x xmax=total displacement
The Following 3 Users Say Thank You to tc3k101 For This Useful Post:
FLAstrongman (11-17-2013), n8skow (11-20-2013), RowdyFlat4 (12-08-2014)
Old 11-18-2013, 08:44 PM
BKNIGHTS's Avatar
0/11 sssss2949
Feedback Score: 61 reviews
center of coil to center of top plate. I mark center of coil. Then another mark above that the distance of half the top plate width. Now you can lower the coil into the gap until the top mark reaches the top plate.
Old 11-18-2013, 08:54 PM
Veteran Member
0/11 sssss3359
thats how you build a normal woofer. apparantly underhubg is different though from the equation given
Old 11-20-2013, 01:00 AM
0/11 sssss4511
What it sounds like you are talking about is how to set a coil in a overhung motor. Underhung and overhung and two different things.
Refer to this thread if you must
how to set coil elevation
Yep math to do overhung which most subwoofer use now a days.
Old 11-20-2013, 02:33 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
The normal method still works provided you have enough former to see the mark. In under or over the coil is still centered on the top plate in almost all situations.
Current Build:
#60sHereIcome
Custom Av2 Underhung Driver + Ti Basket + CF Cone + Copper Coil + TC Spaced Spiders! Beerdrnkr 12" Subwoofers 5 01-19-2013 09:15 PM
Custom Av2 Underhung Driver + Ti Basket + CF Cone + Cooper Coil + TC Spaced Spiders!! zeuslicious 12" Subwoofers 4 11-05-2012 09:48 PM
Life Explained in Graphs Oldbass38 Off Topic Chat 3 04-05-2011 08:06 PM
cabin gain explained lincolntc690 Tutorials & Quick References 1 06-13-2009 12:10 AM
